Drivetrain Mod bug finally bit
Old Jan 22, 2007 | 03:22 PM
BRG4ME's Avatar
BRG4ME
Mod bug finally bit
Hi,guys Im looking for some insight.I have a 2003 cooper s close to the 10,000 mile mark.Now Im looking to get a miltek exhaust ,JCW airbox,15 percent pulleyand finally some KDWS 205/45/17.My question is any body running these tire the stock eufories are great but my zo6 rides way more compliant thanks Marco
Old Jan 22, 2007 | 03:24 PM
1nf3rn0's Avatar
1nf3rn0
They are great tires for all season. If youre looking for the best tire, check out the Falcon RT-615. They are a summer only tire, but i have never been more satisfied with any other tire.
-Blake
Old Jan 22, 2007 | 03:29 PM
jonnieoh's Avatar
jonnieoh
You will find lots of threads about "ditching the run-flats". The main reason for doing this, you will find, is that the ride can be much more comfortable with normal tires.
As a matter of fact, the MINI suspension was developed to have regular tires, and it was only at the last moment that MINI decided to ship the cars with run-flats, (I think due to BMW's strong stance on this). That is what Motoringfile states, anyway.
So, if they actually had developed the car's suspension with run-flats in mind from the beginning, perhaps there would be less of us saying, "ditch the run-flats".
I believe the new '07 models coming out, (the R56), the suspension has been developed for use with run-flats, so hopefully new buyers will not have such a harsh ride.
So, long story short, the best way to have a more compliant ride, is to go with normal tires, most agree.
Search for "Ditch run-flats" and you'll see lots of threads...
Old Jan 22, 2007 | 03:46 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Sounds like a plan.
The Milltek exhaust will be fine, any cold air intake, 15% pulley (maybe GIAC ECU reflash or equivalent) and (add an adjustable rear swaybar).
BF Goodrich g-Force T/A KDW2 in 205/45-17 should be fine ($118 each)
300 treadwear AA traction
Tests-
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=35
Handles well in wet or dry, a little noisy.
Maybe consider some light weight wheels.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Moddedmafia
Sep 1, 2015 09:52 AM
maytulip32
Aug 27, 2015 04:59 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
massmini03
Aug 12, 2015 11:19 AM
