Drivetrain DFIC mods
Old Jan 17, 2007 | 10:58 AM
  #26
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by JS
Yes Jaoquin, cut a square diagonally. Or maybe take your half rounds and mill some flats to aproximate desired shape. I don't think you actually need a true sharpe point, just relaxing the edge should help. You're just trying to break up the turbulence there.
I will look into that, but there isn't much left of a 1/4" rod after you mill half of it off.
Originally Posted by DrPhilGandini
Jaochin: Darn it--I sketched this mod when I got my DFIC last year--but the kudos always goes to he/she who brings it market first (no Alta-nertive for me!)
ANyway--better to be second cab off the rank than third, or fourth, so I got the airfoil sections from the hobby store this morning, and will put them on my DFIC when I remove it to install the thermal blanket.
Good one, my man!! Nice work--since I will be using different material, we can compare notes.
btw, my IC efficiency measurements are coming along really nicely. I've finally got 4 probes now, and really, it's the delta between the air in the airbox and the air in the intake manifold that really counts. Pretty constant +20 in traffic and +10 on the freeway. Airbox temps are never more than +2F of ambient thanks to the FAD!
cheers,
Thanks Phil, do you have pics of the airfoil sections?
BTW, thanks for all the testing/measuring you're doing, i'm sure i'm not the only one who appreciates it.
FOR JOEL AND PHIL: The correct spelling of my name is: Joaquin
Old Jan 17, 2007 | 11:20 AM
  #27
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Joaquin--sorry about the spelling (I actually do know it, but took it from Joel's post being lazy--sorry!)
The section is simple to describe: 1/4" short dimension, 3/4" long dimension, half round at front, tapered to small dia. round at rear. Exactly an airfoil section. I bought it from a RC plane hobby store in 3ft lengths for $6 each. I plan on cutting it lengthwise at the max short dimension to produce a hollow half round like yours for the entrance and a 1/2 long taper for the exit of the IC. I will JBweld like you and see how it flies
THanks to you, I'm all inspired again, even though it's been so darn cold here in the little Apple (cookie) that temperatures inside the engine are so darn cold... you could close everything off and it would still work.
cheers,
Old Jan 17, 2007 | 11:37 AM
  #28
Partsman's Avatar
Partsman
Legion_of_Doom
cheers,
You're right about the cold, the cold just smacked us here yesterday.
The airfoil sounds like it would work, just one thing though, if the sections you will be using are hollow it might be a little difficult to J-B weld them to the core unless they have some thickness to them.
Glad i'm able to inspire you again. I couldn't wait to get this done for two reasons:
1) I wanted to obviously accelerate the airflow through the DFIC
2) NAM has been kinda dead lately with stuff like this
BTW, no worries about the spelling, just messing with you and Joel.
Old Jan 17, 2007 | 12:41 PM
  #29
Peter@M7Tuning's Avatar
Peter@M7Tuning
Nice work, Joaquin!! Looks like it should do the trick!
For the rest, this would help on exit, but other's have answered correctly that a trailing edge like the rear of a wing would be the optimal shape. A wedge on the front end of an airflow would seem like a good idea, but it really isn't. Sharp edges like that tend to stir the airflow into vortices, which are not a happy condition when you want nice, laminar flow.
Old Jan 17, 2007 | 12:49 PM
  #30
MSFITOY's Avatar
MSFITOY
Maybe a wedge shape here. Take a piece of sq. stock and split from opposite corners? Don't think you'll need much of a run off for air to merge together without the turbulances from the flat edge.
BTW. nice work.
My original persuit was to find a 1/4 aluminum spar for model airplanes which has the proper air foil section but was not able to find one that size
Old Jan 17, 2007 | 12:56 PM
  #31
Peter@M7Tuning
A wedge shape would not be good for the airflow. The angle, 45*, would be way too drastic to do anything, and you'd just be adding weight to your IC.
Old Jan 17, 2007 | 02:35 PM
  #32
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks, it's about time you chimed in here.
I'm still working on the outlets, I want nice, happy laminar flow.
Check with DrPhil, he found airfoils that should work.
Old Jan 17, 2007 | 05:26 PM
  #33
Peter@M7Tuning
I've been busy! I'll have something fun to show this weekend, I hope!
But not as fun as your work, certainly!
Old Jan 17, 2007 | 05:35 PM
  #34
Partsman's Avatar
Partsman
Legion_of_Doom
Something fun? Hmmm... could be anything!
Old Jan 17, 2007 | 06:19 PM
  #35
jonnieoh's Avatar
jonnieoh
Good work guys. This is great reading--improving on an already great product. Grassroots creativity and inventiveness. (is that a word? If so, is it even spelled correctly?)
Anyway, keep this thread going!
Old Jan 17, 2007 | 06:25 PM
  #36
maxmini's Avatar
maxmini
Nice work Partsman ! Hd I known I would have packed my DIFC in my carry on when I came home for XMAS and had you work on mine. I wonder how well that would have gone over with the X-Ray security system ?
Randy
M7 Tuning
Old Jan 17, 2007 | 06:44 PM
  #37
Partsman's Avatar
Partsman
Legion_of_Doom
Randy
M7 Tuning
Thanks man. The guys on the X-ray would have been like WTF is that?
I should have brought you up to the shop where I do all my mods. The guy who owns it is a very good friend of mine(he even gave me a key to the place), I think he digs modding the MINI as much as me.
Old Jan 17, 2007 | 06:47 PM
  #38
Partsman's Avatar
Partsman
Legion_of_Doom
We'll try to keep it going. Will said he would do back to back tests with mine and his to see the difference. I would then have to put the stock one back on.
Old Jan 21, 2007 | 04:01 PM
  #39
DrPhilGandini
OK, Joaquin, here's my version. Airfoils dissected and (JB)welded on. Extremely light, and hollow for good thermal conductivity (!)
The exit foils:
and it's all siting on a M7 Aerogel blanket. New M7 boots to boot!
Measurements tomorrow...
Old Jan 21, 2007 | 04:19 PM
  #40
Partsman's Avatar
Partsman
Legion_of_Doom
The exit foils:
Where are the pics? That's just not nice.
Old Jan 21, 2007 | 04:21 PM
  #41
DrPhilGandini
I see them...on my post, and yours. I'll post on my server tomorrow, but until then, it's public space.
Old Jan 21, 2007 | 04:25 PM
  #42
Partsman's Avatar
Partsman
Legion_of_Doom
Email or PM them to me and i'll post them, I don't want to wait until tomorrow.
partsman109@yahoo.com
Old Jan 21, 2007 | 04:43 PM
  #43
jonnieoh's Avatar
jonnieoh
Yeah, they aren't showing up for the rest of us in cyberspace yet!
Please remedy this injustice.
Old Jan 21, 2007 | 05:16 PM
  #44
Partsman's Avatar
Partsman
Legion_of_Doom
I'm waiting for DrPhil to send them to me.
Paging DrPhil...
Old Jan 21, 2007 | 05:19 PM
  #45
TonyB's Avatar
TonyB
just have him put them in his gallery. from there it is easy...
Old Jan 21, 2007 | 06:00 PM
  #46
Partsman's Avatar
Partsman
Legion_of_Doom
That would work too. DrPhil, are you listening?
Old Jan 21, 2007 | 06:20 PM
  #47
DrPhilGandini
Sorry, this public posting of photos is not my usual method. I've sent them to Partsman--I am sure he can get them up here shortly.
No time to drive today, but the install went well--Peter (M7) said those new boots were easy to install, and they are way better than my Altas. btw, my old boots looked pretty beaten--maybe they were leaking a little boost...
Ambient might be 30s tomorrow! Ouch.
The blankie is cool, too. Fits well, but there may be some problems with the big holes for mounting and the DFIC diverter--others will have to post experiences to see if there's a trend here.
Tomorrow, more.
Old Jan 21, 2007 | 07:07 PM
  #48
Partsman's Avatar
Partsman
Legion_of_Doom
Sorry it took me so long...
Very nice DrPhil! That looks like it should work...
The Aerogel looks pretty sweet too...
As a side note Phil, grind off the 1/4" dummy bungs on the front of both the inlet and outlet tanks, you're able to get a better seal that way. You can see what i'm talking about in my pics in the first post.
Old Jan 21, 2007 | 07:11 PM
  #49
M7's Avatar
M7
Tomorrow, more.
Thank you Phil...
The boots were not an after thought, and as such engineered with a softer durometer silicone and less numbers of polyester ply's.
As for the gromet placement....It should fit perfectly as we tested them on 3 different cars, as seen in the first image.
Secondimage shows the new DFIC grille, it mounts in the DFIC diverter
and prevents large birds and other stray un-wantables in your IC.
Peter
M7 Tuning
562-608-8123
M7 Aerogel Heat Shield
M7 Ultimate DFIC Grille
Old Jan 21, 2007 | 07:17 PM
  #50
Partsman's Avatar
Partsman
Legion_of_Doom
This is very nice, Peter. Great job. Do you have any pics with hood open?
