Drivetrain unichip help......
Old Jan 14, 2007 | 12:46 PM
trickedmotoring's Avatar
trickedmotoring
unichip help......
so i just installed my unichip..... first off i dont know which switch controls which map.... and i the little light doesnt do anything... i need some help. i think it feels better but im not sure if its working right... help..
Old Jan 14, 2007 | 01:01 PM
stevecars60's Avatar
stevecars60
Is this the new "Q" chip? If so:
There is no light, only on the early model
When the "O" is pushed in the setting is 91
When the "I" is pushed in the setting is 93
If the above settings are the tune you purchased. Some get 93 - 100. Reguardless the switch works the same way "I" is the more agressive setting.
Old Jan 14, 2007 | 01:21 PM
trickedmotoring
ya i have the older one.... and i am running 93 at all times... loving florida. but there are 2 switches one yellow and one yellow with a red stripe.... and with a little led light.... the light is not illumiated is it not supposed to be pr what.... im not sure how it works.
Old Jan 14, 2007 | 01:30 PM
newbs49's Avatar
newbs49
Red light should come on for the race map.
Old Jan 14, 2007 | 01:51 PM
stevecars60
You win
Old Jan 14, 2007 | 03:58 PM
trickedmotoring
hmm.... no light.... so what about the second switch..... whats that all about.
Old Jan 14, 2007 | 04:56 PM
newbs49's Avatar
newbs49
What second switch are you talking about.
Old Jan 14, 2007 | 05:04 PM
onasled's Avatar
onasled
Yea, the unichip came with two switches. The other was for the future IC mister that we were promissed by Webb, which never ever happened, even though it was a strong selling point.
Wish I could remember which was which. Sorry
Old Jan 14, 2007 | 05:28 PM
newbs49's Avatar
newbs49
There was a second small white plug which was for future mister that you never plugged in. Only one black toggle switch which you either mounted in the car or left under the hood. Check the unchip you have laying around. Sold mine last week had only one black toggle.
Old Jan 14, 2007 | 05:34 PM
onasled's Avatar
onasled
..as I remember Larry you were one of the earliest unichip owners from Webb. I think that the two switch thing came right after your install.
I know that many here know the answer to this question and will most likely post here in the next two days.
Old Jan 14, 2007 | 05:54 PM
newbs49's Avatar
newbs49
You may be right about a second switch on later models. I was one of the very first guinea pigs back then.
Old Jan 14, 2007 | 06:48 PM
trickedmotoring
ya... i would really like to know which is so i can hide it.... but ya.. i wonder if its even working.... i have it all pluged in but no light, its and led so makes me wonder that it shouldnt be out. with the car running right im thinking its working, but im not sure if the unichip if it wasnt working it wouldnt effect the car.... someone. guide me in the right way
Old Jan 14, 2007 | 07:04 PM
newbs49's Avatar
newbs49
Where did you get the Unichip from if you don't mind answering. If you got it from a vendor can they help you or is this the one off ebay last week.
Old Jan 14, 2007 | 07:30 PM
trickedmotoring
no prob. i picked it about two months ago from a local here in fl. i just got around to installing it today.
Old Jan 14, 2007 | 08:33 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Just my experience (I have the 2-switch Unichip), but I can't tell the difference between the maps with my popo dyno. Now, it is commonly known that mine is not calibrated as well as other's, but I can tell you that I could detect a big difference between no-Unichip and Unichip installed. Of course, it's rare for my car to have pure 101 octane in it...(which is what my Map B is set for--but this year at the track I intend to see what it can do!)
cheers,
Old Jan 15, 2007 | 04:36 AM
pmello's Avatar
pmello
If you have a two switch Unichip(old), It's the switch with yellow wires going to it. I just taped the switch to the red LED because I kept forgetting witch switch was which. If you flip the switch to (1), the red LED should light up. I've been doing a lot of work finding wiring pinouts with the Unichip harness yesterday so I can hook up a Innovative DL-32 dataloger....
Old Jan 15, 2007 | 04:39 AM
onasled's Avatar
onasled
PAUL !!!!
CALL ME!!
Where you been?
You need to come visit.
Old Jan 15, 2007 | 08:30 AM
cooldaddy's Avatar
cooldaddy
same experience; there's a clear increase in low-end torque with the Unichip installed on my car, it's much easier to pull away. I also feel no difference between the 2 maps but I can only use crappy 91 octane locally...
cheers,
Old Jan 15, 2007 | 08:41 AM
onasled's Avatar
onasled
I never felt any difference between maps, even when I was tracking with 100. Now, you can get your car tuned by a certified unichip tuner and he can might be able to do a better job, but the fact is that tuning for 100 octain does little for the final power numbers. It just helps the car run cooler.
Old Aug 27, 2007 | 08:55 PM
MoB-NorCal's Avatar
MoB-NorCal
where is the octane switch with the Q version i have no instructions bought the car with it
Old Aug 28, 2007 | 04:09 AM
stevecars60
It's a simple on off switch ( I-O, I = high test ). You will need to ask the original owner where they put it. The older version has a light in the switch when in high test mode.
bADbOYbECK
41
Oct 16, 2015 12:39 PM
MeanGRN
Jul 29, 2006 08:26 AM
ftbt
Apr 25, 2004 08:06 AM
