Drivetrain junk inside my IC
Old Feb 2, 2007 | 08:49 PM
  #101
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by M7
I will cut the core in two so we can see the contaminants...sorry Partsman
That's ok, Peter. Just make sure you give DFIC #xxxx a proper ceremony and burial after the autopsy.
Old Feb 3, 2007 | 03:58 AM
  #102
stevecars60's Avatar
stevecars60
The Important part of the issue
Originally Posted by PARTSMAN
That is definitely cool. It doesn't surprise me that Peter is going out of his way to help you out.
I still have your stock core(in pieces) here to experiment with.
Yes you will, as long as you figure out what happened before you put the new one on.
The 'what happeened" part is key......
Old Feb 3, 2007 | 03:59 AM
  #103
pmello's Avatar
pmello
After putting 3 IC's on and off multiple times(?) could it just be boot material? This may have been discussed, but I didn't want to go back 4 pages (be gentle). PARTSMAN: Once I get the DL-32 in and working (hopefully today) we should hookup for some testing. It will be portable (connected to a UniChip harness)!
Old Feb 3, 2007 | 09:18 AM
  #104
Partsman's Avatar
Partsman
Legion_of_Doom
That sounds cool, Paul. I'm right in Westerly now.
Old Feb 3, 2007 | 09:41 AM
  #105
Bahamabart's Avatar
Bahamabart
Peter, wants to put tha band saw to it. I'm sure a piece will end up at the shop in the "this could happen to you if your not careful section" . I just hope there is no little plaque w/ my name on it .
Old Feb 3, 2007 | 09:44 AM
  #106
Bahamabart's Avatar
Bahamabart
Peter thinks it was 1 time event - something got in either at the dealer or when I installed the DFIC. I checked my loaner IC and its clean/spotless.
Definetly an X-file.
Old Feb 3, 2007 | 09:54 AM
  #107
Dr Obnxs's Avatar
Dr Obnxs
Don't be so sure...
your degradation wasn't instant. Also, if it was an event that started with a lot of stuff, and tapered off, you'll have no clue as to the rate of degradation now.
Please, please, please take off the intake parts and have a look see. It's not much time. And if the problem persists I'll get to say "I told you so!" and you wouldn't want that.....
At a kilo buck a shot!
Matt
Old Feb 3, 2007 | 10:38 AM
  #108
stevecars60
For sure it was a one time deal, but it took 6 months to completely contaminate the IC. Glad the loaner had no tell in it. I would pull a horn off anyway. As Dr O says just to be on the safe side, nobody likes an "I told you so" especialy a whyneeeee 1.
Old Feb 4, 2007 | 07:25 AM
  #109
Bahamabart's Avatar
Bahamabart
Didn't take 6 months - i've seen boost problems for a while, I just thought it was my boost guage and ignored it. UGH!
The good news is the M7 says that the 6th IC purchased is free.
Old Feb 16, 2007 | 11:20 AM
  #110
Bahamabart's Avatar
Bahamabart
Replacement arrived today .
I inspected my loaner stock IC - no crap inside.
I inspected the DFIC 3 times - okay it was 4 times .
Popped it on and went out for a romp. Boost is back ! I'm getting boost all the way to redline (7,200) reaching just 14.5 lbs.
Baby is back - ran great . Next step back to the Dyno to redeem my poor performance at MyMini Dyno Day.
Don't ya just love happy endings
Old Feb 16, 2007 | 12:12 PM
  #111
Partsman's Avatar
Partsman
Legion_of_Doom
Happy endings are great!
Nice Bart, glad you're back making boost again.
Old Feb 16, 2007 | 12:49 PM
  #112
jymontoya's Avatar
jymontoya
Yay! Happy endings are the best! Hey! I've got a question!?
Where are you measuring boost from? I used the NPT adapter from my Autometer boost guage package to plug into the post intercooler port on my DFIC.
The reason I ask is because I only make around 15 psi at redline in 2nd. I'd test 3rd, but my current location doesnt allow me to safely do this This is with my 19%, which I thought should be making a bit more (see other thread) But perhaps it's just the pressure drop seen from the tap point at the post intercooler side of the DFIC?
One of these days I'll battle with this winter weather and go into my cold garage and swap it to see if that makes a difference! But if I'm going to do that, I might as well put on the new M7 intercooler boots, afix the new foam sealant, empty my OCC, reinstall my engine damper, install my Koni Coilovers, install my IE fixed camber plates, install my H-Sport Comp. front and rear sway bars, finish "rolling the inner fender lips", remove and replace the stupid melting clear turn slignal, change my oil.... GOOD GOSH! Does anyone else have a list like this with a garage full of parts needing time to do it!?! Getting married in a couple of weeks, maybe I'll have time after this whole wedding thing is done? :D
Sorry to get lost like that... Groomsbrain...
Old Feb 16, 2007 | 12:58 PM
  #113
Bahamabart's Avatar
Bahamabart
Originally Posted by jymontoya
Hey! I've got a question!? Where are you measuring boost from?
I'm tapped in via the "traditional place" - the vaccum line under under the right horn. I'm using a VDO guage w/ a scale of 1-15lbs of boost so I get good reads (I get incredible needle action ). W/ my set-up I should spool up to 14.5lbs of boost and thats what I am hitting again.
W/ a 19 you should be higher and chances are its the guage. I had tried two other brands previously and got less of a read (also wider scale). Using the same "wiring", I plugged in the VDO and got a perfect read so I kept it.
Old Feb 16, 2007 | 02:04 PM
  #114
DarkMiniCooperS's Avatar
DarkMiniCooperS
Great news!!
I am very happy for you!
Check you PM.
USNAE2
16
Jun 17, 2022 07:17 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
potterstein
Oct 1, 2015 07:10 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Emnotek
Sep 29, 2015 07:37 AM
