Drivetrain Bad experience with Alta Twubo kit
Old Dec 21, 2006 | 05:13 PM
  #101
Trickle X's Avatar
Trickle X
Here are the thickness differnence between a Gen 1 & Gen 3.
Attached Thumbnails Bad experience with Alta Twubo kit-gen1-thickness.jpg   Bad experience with Alta Twubo kit-gen3-thickness.jpg
Old Dec 21, 2006 | 05:19 PM
  #102
Trickle X's Avatar
Trickle X
The welds far exceed any of the previous models. The welds had to be much hotter to weld the thicker material and out of all 3 of the previous manifolds this Gen 3 is the only one that you can actually see the weld come through the inside. This is a good thing. Also to be noted, all welds have been ground down on the inside and no overlap of tubing is in the way of flow like prior Gens.
It looks like this manifold should perform much better, but only time will tell. And for the record, I run my afr at wot at 11.5 tops and on this last manifold (still on car and not in any of the pix) it started cracking with moderate driving around town & no WOT runs as I needed this to last as long as possible as its my only means of transportation till the TT gets repaired. I will be installing the new manifold tomorrow afternoon.
Old Dec 21, 2006 | 05:20 PM
  #103
nypepper's Avatar
nypepper
Originally Posted by sr20de
Zero involvement with either, except for being a loyal customer. I am running this Kit with 550cc injectors, Alta FP, Apex AFC and the new Alta intercooler. All of is which I moniter through an LM-1. However, I did have a manifold crack, which was taken care of with ease through a vendor, who got my manifold from Alta within a couple of weeks. I have spoke with Jeff a couple times and he is a very reasonable person, who always is more than willing to help in anyway he can. I'm just astonished at all the bad mouthing, when my experience and I'm sure many others has been 100% different from Eastside's.
Where is all the support for Alta? They make great poducts that actually work, and for the most part never fail. Seems like everyone is hung up on the manifold issue, even though they are working towards a solution.
great products except for the rust issues on both the light bar and the air diverter
i've seen both first hand on other minis, so none of this surprises me
Old Dec 21, 2006 | 05:28 PM
  #104
Eastsidemini's Avatar
Eastsidemini
pix
Thanks Tricklex for the pix best of luck to you with the install.
Old Dec 21, 2006 | 06:50 PM
  #105
sr20de's Avatar
sr20de
Originally Posted by miniflop
If you can't see that is a welding issue there is no part in arguing here. Why isn't ALTA backing this?
12.3 is NOT too lean for a boosted car , especially one that is only running that for a few seconds. This is a street car not a full blown race car. You might want to talk to someone who knows the stock ECU better than what you appear to. I seriously question buying any ALTA products after seeing those photos and these responses to them.
Bill
For a reliable street set up w/ a stock bottom end 12.3 is too lean. For a drag car probably not. But if you like to run on the verge of detonation than that's fine. I personally would like to run a little more conservative, and keep my rods in the block.
Old Dec 21, 2006 | 06:53 PM
  #106
PGT's Avatar
PGT
nevermind
Old Dec 21, 2006 | 07:47 PM
  #107
Fast05's Avatar
Fast05
Wait Perrin (I mean Alta ) produced a part that was subpar? NO WAY!!!!1
Heat control and the welds would have better penetration
Paging EDGE <beep> <beep> Paging Edge :impatient
Old Dec 21, 2006 | 07:50 PM
  #108
JustJAY's Avatar
JustJAY
What is your infatuation with Edge? Almost every post you make, it has Edge in it
If you want to report something, click on that triangle on the top right of every post.
Old Dec 22, 2006 | 06:00 AM
  #109
rubyred3's Avatar
rubyred3
+1 to that, sounds awfully lean for not only a boosted car (although it depends a lot on how MUCH boost), but especially for a car that is getting some of its boost from a roots blower. For reference, the WOT AFR of a JCW car (which I think we can agree is pretty reliable) is down around 10:1 (actually dips even lower at redline). What boost level are you running (another important question thats gone unanswered)?
Old Dec 22, 2006 | 07:01 AM
  #110
miniflop's Avatar
miniflop
Have you ever run a twincharged car or even seen one?:impatient
Bill
Old Dec 22, 2006 | 09:11 AM
  #111
MarioKart's Avatar
MarioKart
Vendor
Bill
Bill, why would you ask a question like that, you give your 2 and even 3cents all the time about peoples moded cars yet your car is bone stock. Don't point the finger so fast.
Old Dec 22, 2006 | 10:59 AM
  #112
BTBYAGRL's Avatar
BTBYAGRL
seen one, yes, own one, no, but as Mariokart pointed out, theres a lot of literature out there that allows you to understand things like this, its all fluid mechanics, chemistry, and thermodynamics, all things that I DO understand quite well, and when coupled with my experience in tuning other engines I feel my commentary can contribute to this discussion, so I thought I'd share it.
Experience aside (as I don't feel it necessary to quote my resume for you here), do you care to address my actual statement, instead of simply trying to undermine my credibility? If you disagree with what I said, I'm all ears to why you disagree with it, and I'm anxious to hear how you feel about using that A/F ratio on a twincharged car. Use your apparent "experience" to explain it to the "noob" (as you seem to think I am), rather than trying to hold it over their head to insult them. . .
  #113
BTBYAGRL's Avatar
BTBYAGRL
oops, posted under the wife's SN, btw, this is rubyred3. . .
Old Dec 22, 2006 | 11:14 AM
  #114
miniflop's Avatar
miniflop
Mario,
It's because I took the time to go find out from someone who actually had a twincharge and tested it for quite some time. Does that make me the expert? No, but I have more of a clue what is going on with the car than most on this thread. My car is not stock anymore but thanks for asking.
Bill
Old Dec 22, 2006 | 11:16 AM
  #115
goaljnky's Avatar
goaljnky
Still, I have one for and one against the antenna. Need more opinions.
Old Dec 22, 2006 | 11:28 AM
  #116
rubyred3's Avatar
rubyred3
Mario,
Bill
So what was the A/F you were running on that twincharged car that you tested and at what boost level? I'm interested in your experience, you correctly pointed out that I do have no experience with tuning a twincharged engine, although I still think I have a "clue"? Also, lets not get into flaming each other, its hot enough in here, I'm interested to hear what you have to say, and would appreciate that you would at least evaluate my statements based on their content, not based on whatever lack of background you think I have on the topic.
Everything I know about boosted cars says thats a little lean for even a turbo car, let alone one with the inefficiencies associated with a roots blower being part of the system (tends to heat the air up more than a turbo; although I probably don't need to tell you that, that was more for the benfit of others who might still be reading).
Old Dec 22, 2006 | 11:30 AM
  #117
miniflop's Avatar
miniflop
So what was the A/F you were running on that twincharged car that you tested and at what boost level? I'm interested in your experience, you correctly pointed out that I do have no experience with tuning a twincharged engine, although I still think I have a "clue"? Everything I know about boosted cars says thats a little lean for even a turbo car, let alone one with the inefficiencies associated with a roots blower being part of the system (tends to heat the air up more than a turbo; although I probably don't need to tell you that, that was more for the benfit of others who might still be reading).
If you read my post you would understand it wasn't my car.
Bill
Old Dec 22, 2006 | 11:44 AM
  #118
rubyred3's Avatar
rubyred3
Mario,
Bill
I'm confused then, what did you take the time to go find out from this person then? I got that it wasn't your car, but I thought you were claiming to at least know something about it. I thought your statement was saying that you had helped test this other persons car, but apparently that was incorrect as well. Or were you just going out of your way to try and say that I DON'T know wht I was talking about b/c you went and saw this car? I'm just confused now, what are you saying?
Old Dec 22, 2006 | 11:59 AM
  #119
miniflop's Avatar
miniflop
If youtake the emotion out of it , I think you can read the posts as I posted them. It was very clear that I talked to the owner of the car who tested it for years. I am sure he had more experience with the car than the current ALTA owners since he had his before ALTA ever even made a kit.
The highest recorded ALTA kit horsepower has been 280hp, they made over 375hp with a smaller turbo. I would be inclined to think they have a better idea of how to make power out of the twincharge than what is being presented here. I am in no way an expert just relaying the information from the person who actually had the car. If you would like to talk to him personally I am sure he would be glad to talk to you at length.
Hope this helps your confusion on the subject.
My apologies if I offended you.
Bill
Old Dec 22, 2006 | 12:29 PM
  #120
jaridp's Avatar
jaridp
Originally Posted by Eastsidemini
Thank you Robert. 2 different manifolds with cracked at the same place. If any of you want to throw $$$ away, buy the Alta "Terrible" I mean "Twubo" kit. They will promise you with replacment "Terrible" I mean "Twubo" manifold. And try not to ask for Adam I've heard he's a JERK.
Isnt this reguarded as slander? I understand you are upset but this is no way to resolve an issue. Name calling? Come on now....
Old Dec 22, 2006 | 12:55 PM
  #121
rubyred3's Avatar
rubyred3
Bill
Offended I don't think is the right word, as I said, just confused as to why you tried to call me out on a lack of experience, as you seem to have even less relevant experience yourself:impatient. I talked to the helix people at the Dragon about their twincharged car, I guess I'm as much of an expert as you on the topic.
I'm willing to let it go though if you are, lets get this thread back on topic shall we. . .
Old Dec 22, 2006 | 01:14 PM
  #122
miniflop's Avatar
miniflop
The reply was posted to the board in general, it just happened to be under your post. Again we go back to the kits, even Helix has only made about 250hp so are they as experienced as the guy making 375hp? Definitely something to think about. I really can't tell how relevant your experience is either but knowing what others have done versus the crowd making 50% more horsepower I will go with leaders. This should end my post on this subject but if you want to pm me feel free to do so.
Bill
Old Dec 22, 2006 | 01:19 PM
  #123
saifa's Avatar
saifa
No problems with the Alta antenna personally. I know a few other guys that have them as well. No one has expressed any problems with reception.
Seann
Old Dec 22, 2006 | 01:24 PM
  #124
rubyred3's Avatar
rubyred3
um, if it was to the whole board and just coincidince that it was below my post, why did you quote me in your post?
sorry to belabor this topic, but call me out and I'll call you out. . .
Old Dec 22, 2006 | 01:26 PM
  #125
miniflop's Avatar
miniflop
I was using that as an example of the thread. It was not the best of examples based on the number of posts that now clutter the thread.
Bill
