Drivetrain Please I Need your Help (Headers)
Old Dec 12, 2006 | 08:01 PM
harhoosh's Avatar
harhoosh
Befor 1 week ago i was hearing a voice from my headers... i ignor it,,i keep driving till yesterday morning.. i start my engine,, Suddenly My headers Blow Off i think :S .. i dont know how to explain because my english is not much good,so my headers is very very noise now :S they told me its the Silencer :S .. i called the dealer they told me it cost u 1000$ Dollar :S
there is any solution for it ..or i have to buy a new Silencer ..or headers ???
Old Dec 12, 2006 | 08:06 PM
MINI Monkey's Avatar
MINI Monkey
Was it the header or the exhaust? Do you have a photo of the damaged part? Both can be bought in the aftermarket and the installs are something you could do yourself.
Old Dec 13, 2006 | 01:56 AM
harhoosh's Avatar
harhoosh
Actually i dont have the damge part.. because it cant be seen .. its jst noisy sound.. from the headers.. i hear the voice its under the engine exactly .. so i think the sound its coming from the end of headers if iam not wrong :S
Old Dec 13, 2006 | 03:44 AM
NMgokart's Avatar
NMgokart
If possible, get the car up on a lift and try to pinpoint the leak. Could get lucky and just need a gasket. BTW, silencer = muffler, and that's at the back of the car. $1000 is probably for a replacement cat. Aftermarket options are available for less.
Old Dec 13, 2006 | 09:15 AM
heimata's Avatar
heimata
My friends brand new JCW MCS had his header loose 2 weeks ago, we dont know why and the sound was awfull, maybe you should check first.
If any parts are out, time for new but get aftermarket, it is cheaper and really worth it.
Old Dec 13, 2006 | 10:37 AM
jymontoya's Avatar
jymontoya
What year is your car?
The CAT assembly is a part of the header, so your only bet outside of the dealer may be getting a new header & cat assembly.
Check my thread:
https://www.northamericanmotoring.co...hlight=headers
for more options.
Old Dec 13, 2006 | 12:11 PM
stevecars60's Avatar
stevecars60
This has broken flex joint written all over it...
Old Dec 13, 2006 | 08:19 PM
harhoosh's Avatar
harhoosh
MY car is JCW 03
the sound is coming from here
check the attachment.. and tell me if it can be fixed or i have to replace it
Old Dec 13, 2006 | 08:36 PM
Wake|MCS's Avatar
Wake|MCS
You could have a new flex pipe welded on I guess... I'd just take this as a reason to go aftermarket...
Old Dec 13, 2006 | 09:13 PM
harhoosh's Avatar
harhoosh
so do u mean that i can buy this part only ?? or i have to buy the headers package ??
how much is the flex pipe ??
Old Dec 13, 2006 | 09:29 PM
Wake|MCS's Avatar
Wake|MCS
You could have an exhaust shop weld on a flex pipe for you.. don't know how much that fix would cost. If you have MINI do it they'll replace the entire header assembly and it'll cost you like $1,000.. Or you could go with an aftermarket header and it'll cost you a little less than that but you get the performance gains..
Old Dec 14, 2006 | 01:49 AM
stevecars60
There might be an OE header complete over in the Market Place, there was the other day. It could be fixed or you could post WTB.
To fix the problem some shops have the flex material ( flex joint ) Monroe comes to mind & they could weld a new piece.
Good luck with how ever you fix the problem.
Old Dec 14, 2006 | 02:46 AM
harhoosh's Avatar
harhoosh
IF they couldnt weld it .. wut about this type of headers ? Is it good ??
[FONT=Arial]Megan Racing MINI Cooper Header ?[/FONT]
[FONT=Arial]While this is one of the most economical headers on the market it sure looks, performs and feels like headers that cost 3 to 4 times as much. Made by Megan Racing specifically for the MINI Cooper and Cooper S, this is a great way to squeeze even more power from your engine. Has two ports for O2 sensors but has a straight pipe in place of the Catalytic Converter. For use on off road applications only.[/FONT]
Is it make sense ? it cost only 199$ ??
Old Dec 14, 2006 | 04:35 AM
stevecars60
Yes.
The Megan is the best bang for buck header IMHO. It would cost around $200 to fix what you have anyway. Even a used OE piece would cost more than the Megan.
Best of luck
Old Dec 14, 2006 | 04:49 AM
harhoosh's Avatar
harhoosh
wut do u mean by OE and IMHO ??
so do u recommand me to oreder it ?? dose it gives me more power than the stock 1 ??
for your information
The Headers information is:
my car is a daily use.. so its perfect ?
sorry for my stupid questions :(
Old Dec 14, 2006 | 05:02 AM
gmcdonnell's Avatar
gmcdonnell
OE is "original equipment" - that's something that came with the car or in the case of a replacement part would come from the dealer.
IMHO is "in my humble opinion", and is just a short way of saying that the writer believes what he's saying to be true but allows for the fact that others may have a different point of view.
Old Dec 14, 2006 | 05:19 AM
harhoosh's Avatar
harhoosh
AHA OK THX = )
This is My CAR :(
Old Dec 14, 2006 | 06:10 AM
jymontoya's Avatar
jymontoya
I disagree. Many MANY MANY people with the Megan header had the test pipe/ resonator piece fail on them, leaving them with little more than an OBX header. I'd go with the OBX header, 4-2-1 design means a wider powerband, and a 2.5" collector means it will flow well at the top end too.
Old Dec 14, 2006 | 07:25 AM
stevecars60
The OBX is a good choice too. If you need a cat & you want the flex joint the OBX is a little harder to deal with. The OBX does not have a flex joint, it has a spring loaded swivle. On the plus side, it's a simple bolt in. Like the Megan it will bolt right to the existing exhaust system.
Old Dec 14, 2006 | 11:05 AM
Paul Webster's Avatar
Paul Webster
AHA OK THX = )
This is My CAR :(
Wher abouts are you in the world??
Old Dec 14, 2006 | 12:31 PM
harhoosh's Avatar
harhoosh
OBX
MEGAN
STOCK HEADERS
I NEED THE WHOLE PACKAGE .. WHICH ONE IS THE BEST AND GIVES ME MORE PERFORMANCE
CAN I DRIVE MY CAR WITH OPEN HEADERS ?? I THINK THERE IS LOSE PRESURE AND AIR LEAK.
DO I'LL FACE PROBLEMS IN THE FUTURE??
Old Dec 14, 2006 | 02:55 PM
stevecars60
OBX
MEGAN
STOCK HEADERS
Where do you live?
Are the Megan or the OBX easily available to you?
Do you need the car to pass emission standards?
The stock header is quite expensive compared to the Megan or the OBX. So it is a good idea to replace the original header with either the Megan or the OBX.
Old Dec 15, 2006 | 12:24 AM
harhoosh's Avatar
harhoosh
Actually i live in bahrain (Middle East)
nuthing available here in my country...
jst now i come from garage,,, they told me its the Flix pipe totally damged
so wut do u recommand me guyz .. plzz soon as possible
Old Dec 15, 2006 | 02:41 AM
harhoosh's Avatar
harhoosh
Look To The Pic...
This Part Of My Headers Is Damged .... I Went To The Garage He Told Me I Can Fix It But Its Not Gurantee
Old Dec 15, 2006 | 05:24 AM
stevecars60
No you should not drive the car with this kind of problem..
You should fix it. If the flex is replaced ( as a unit ) it should last for a while. At the least it will buy some time to purchase a performance header of your choice.
Best of luck.
