Drivetrain Please I Need your Help (Headers)
Old Dec 16, 2006 | 07:12 AM
  #26
harhoosh's Avatar
harhoosh
Im Going for the Stock 1..
there is much difference between the stock and Megan ???
The headers how many HP dose it gives u ??
Old Dec 16, 2006 | 11:35 AM
  #27
stevecars60's Avatar
stevecars60
Yes.
Depending what other mods you have & which header, 4 - 12 hp.
Old Dec 16, 2006 | 11:50 AM
  #28
herbie hind's Avatar
herbie hind
so do u mean that i can buy this part only ?? or i have to buy the headers package ??
how much is the flex pipe ??
if you live near ma. i can let you have my stock cooper s header . but don't know if it'll help on the works.
Old Dec 16, 2006 | 03:30 PM
  #29
SayGoodbye's Avatar
SayGoodbye
http://maps.google.com/maps?q=bahrai...-a&sa=N&tab=wl
Old Dec 17, 2006 | 02:55 AM
  #30
harhoosh's Avatar
harhoosh
CAN I FIX STOCK HEADERS FOR MINI COOPER S on my Mini JCW ??
b4 i buy 1 ...
can i have links for Megan Headers and OBX ..
which 1 is better to buy ???
i need the links to oreder the headers.. i Need sumthing SURE 100%
Old Dec 18, 2006 | 10:20 AM
  #31
stevecars60
Megan http://www.outmotoring.com/megan_rac...er_header.html
OBX http://www.helix13.com/mini/products/exhaust
Old Dec 19, 2006 | 08:46 PM
  #32
harhoosh's Avatar
harhoosh
thx man
Old Dec 20, 2006 | 12:11 AM
  #33
002's Avatar
002
Look To The Pic...
This Part Of My Headers Is Damged .... I Went To The Garage He Told Me I Can Fix It But Its Not Gurantee
Is this a picture of the header on your car or just an illustration? Are you sure that the damage is at the flex joint and not the weld at the precat just down stream? I have repaired two of these where the precat weld had cracked.
Old Dec 20, 2006 | 04:36 AM
  #34
harhoosh's Avatar
harhoosh
No its not my headers.. jst i want to explain to you .. where is the part which is damaged
Old Dec 20, 2006 | 08:38 AM
  #35
stevecars60
thx man
You're welcome.
Best of luck...
Steve
Old Dec 20, 2006 | 09:25 PM
  #36
002's Avatar
002
It can crack at the output side of the pre-cat. If you don't know what that is , it is the next object down the pipe after the flex pipe that you circled. It looks like a small version of the main cat, because it is. you can see it from under the car. Fallow the pipe from the main cat up towards the pre-cat, where the pipe welds to the pre-cat you will see hairline cracks in the pre-cat side if the weld. Most likely on the swaybar side of it. It may eve be completey apart and loud, like mine was.
It is pretty easy to repair, but I would find someone that is willing to remove the header, cut the pre-cat heat sheild about an inch back and then weld it back together. Otherwise it may leak and or crack again.
Or just replace it with an obx header while it's apart.
Old Dec 20, 2006 | 09:50 PM
  #37
harhoosh's Avatar
harhoosh
which header is better and give me more performance ??
OBX or Megan ??
what about the sound ?? is it noise ??
Old Dec 21, 2006 | 06:03 AM
  #38
jymontoya's Avatar
jymontoya
My suggestion would be the OBX.
Old Dec 21, 2006 | 07:02 AM
  #39
Bahamabart's Avatar
Bahamabart
OBX or Megan ??
I think both are good choices. Two different designs - 4/2/1 or 4/1 - one designed for more mid focus the other more top end focus.
I have the OBX and have been very happy with it. There are a lot of posts that discuss install which you need to read.
header up.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:13 PM
PhoR53
Sep 30, 2015 06:54 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:11 PM
