Drivetrain Rogue Exhaust
Old Apr 21, 2003 | 05:09 PM
Hotelcalif's Avatar
Hotelcalif
Anyone have a Rogue exhaust on a Cooper.I am having a constant problem and would like to know if anyone else is.
Old Apr 21, 2003 | 06:59 PM
dandp's Avatar
dandp
I have the Rogue on my MC...what problem are you having?
Old Apr 22, 2003 | 01:18 AM
bobbydanger's Avatar
bobbydanger
I have it too. whats the problem??
Old Apr 22, 2003 | 01:46 AM
Graham's Avatar
Graham
I have a Rogue system for my Cooper S.
When I fitted it, it touch the bodywork in two places and I had to remove the lower part of the rear fender.
The main problem, however, is the low frequency noise inside the car at 3,000 to 4,000 rpm.
Currently i've removed the system but would be interested in any suggested solutions. :???:
Old Apr 22, 2003 | 02:01 AM
Hotelcalif's Avatar
Hotelcalif
The thing keeps coming loose at the slip joint.It has the wide band type clamp.I have to retighten about every three months.I have thought about trying to find someone to weld it.I have tightened it as much as possible but still works loose after a while.
Old Apr 22, 2003 | 04:44 AM
MiniPilo's Avatar
MiniPilo
I'd try putin some Lock TIght on the bolt that hold the clamp together. That might help your situation
Old Apr 22, 2003 | 06:13 AM
jlm's Avatar
jlm
cut a slit in the outside tube so it can squeeze down when clamped; about the width of the clamp band
Old Apr 22, 2003 | 11:05 AM
Hotelcalif's Avatar
Hotelcalif
I think the clamp streaches ,not the bolt coming loose.Has anyone had their stainless welded?I think it takes a TIG welder.
Old Apr 22, 2003 | 11:31 AM
retroom's Avatar
retroom
After tightening the bolt flatten a couple of threads to prevent the bolt from turning. This won't prevent you from taking the bolt off later.
Old Apr 22, 2003 | 12:28 PM
asodestrom's Avatar
asodestrom
I have a rogue that I bought used form CSBRGMINI. I have not installed it yet. I am waiting for my break-in to be complete before I install it. It has been welded into one piece and CSBRGMINI says it worked out great. Don't know where he had it welded.
Andy
Old Apr 23, 2003 | 05:12 PM
Hotelcalif's Avatar
Hotelcalif
Tonight I have removed the old clamp and replaced it with a heavy duty muffler clamp.We will see what happens.
Old Apr 23, 2003 | 05:24 PM
bobbydanger
BAAHAAAAHAAAAA too noisy?? TOO OLD!!! trade in your mini for a Cadilac before you give the rest of us a bad name.
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
embiggenedmini
Oct 15, 2015 12:36 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
