Drivetrain quality head s
Old Nov 10, 2006 | 06:16 PM
  #26
obehave's Avatar
obehave
Originally Posted by Johan
Good deal You had me worried for a sec. I was thinking you meant 210 with just the head. Just to let you know too I have 2 Spec stage 3+ clutch kits. Ones going on my mini and I'm going to sell the other one. Stupid on me why I have two. -- Johan
That's right taunt me with your clutch package
Old Nov 10, 2006 | 07:24 PM
  #27
herbie hind's Avatar
herbie hind
I'm hoping that the 210 that you want is after the 62 and pistons? I have a good source for pistons too. There 430 with rings. I want to get a pic of the domes though before I buy them.
man i was just looking at wisecos with the tuff coat . i posted a thread on this . they're 460.00 with rings and pins but the coating bumps um up more. they do the skirts and i think the dome(though not a dome) for detonation. anyone tried these?
Old Nov 10, 2006 | 07:31 PM
  #28
herbie hind
Originally Posted by stevecars60
The fact of the mater is, why not bigger valves, is what most head builders do. In the big picture bigger valves can't hurt, it's just how big. All valves float. Unless you are using pneumatic followers, springs are too slow with conventional followers. There is an instance where the valve spring stalls in harmony with the momentum of the follower. There are all kinds of spring arrangements, types and presures that are used to control the float. So when someone tells you that the valves have been known to float at 6k, how do they know? Unless there is a very radical cam with a high ramp speed ( barely noticeable slap), you can't detect the slap.
The valve springs are matched to cam events so they are not too heavy or lite. There is a lot of thought a good head builder will put into all aspects of the finished product.
It sounds like Johan & Obe have a good sourse for building heads. At a good cost for performance too. You wanted recomendations. So, talk to a tuner who will give you what you want & they will tell you what you need & how to get there.
yep i plan on calling their guy ; two happy customers here on nam and a fair price is good start . granted that 650.00 is a base price. i'm not after earth shattering h.p. now . i'm pretty happy with around 170 -180 at wheels though this too is just another dyno number ;i'm happy. but a good head porting while it's off anyway can't hurt.
Old Nov 10, 2006 | 07:44 PM
  #29
obehave's Avatar
obehave
Wiseco and Roller Wave are 2 units of interest.
Dry lubed skirts would be a nice option.
Old Nov 10, 2006 | 07:59 PM
  #30
herbie hind
huh?
Old Nov 10, 2006 | 08:02 PM
  #31
herbie hind
you know they didn't mention the weight of um. how do the rollers and wisecos compare weight wise to the stock? lets be fair to the stockers; i'll bet they're pretty good.
Old Nov 10, 2006 | 08:04 PM
  #32
herbie hind
see if i've got only one bad if at all then my deal's done i'll pop in another stocker . follow? but i can see someone wanting better if the stockers are heavy.
Old Nov 10, 2006 | 08:16 PM
  #33
Johan's Avatar
Johan
I've heard that Weisco makes the roller wave for the mini. I don't know if theres any truth to that.
If it were me I would use SWAIN for thermal coating. I use them for snowmobile parts and they turn out well. $32 for a Thermal Barrier Coating the crown and Poly Moly on the skirts per piston.
Old Nov 10, 2006 | 08:28 PM
  #34
herbie hind
let me ask you johan; are the stock pistons okay? or would a good aftermaket be worth the money?
Old Nov 10, 2006 | 08:44 PM
  #35
obehave's Avatar
obehave
huh?
2 different piston manufacturers.
The Roller Waves are from The Old One but are actually manufactured by Wiseco.
You had mentioned coatings. Dry lube coatings on pistons help with minimize heat buildup. Good stuff.
Edit:
Missed Johan's post.
Yea, what he said
Old Nov 10, 2006 | 08:46 PM
  #36
Johan's Avatar
Johan
Worth the money...It's hard to say. They're expensive to install. There are turbo guys out there with stock pistons running 250-300HP. I've heard that in Mr. Webbs mule he ran stock internals without a hitch. However some tuners say you will see a gain on a moderatly modded mini due to the effeciency of their piston(they also raise compression to 9:1 which has got me ) I don't know for sure since not many people done this or they're not willing to share. Will I get aftermaket pistons, yes...but my end goals might be different then yours.
My opinion, turbo with a lot of boost, nitrous or money burning a hole in your pocket the stock ones are fine. I hope this helps -- Johan
Old Nov 10, 2006 | 08:51 PM
  #37
ChrisW's Avatar
ChrisW
Bigger Values mean's less power at lower RPM's, everything with these cars is a trade off.
Old Nov 10, 2006 | 09:06 PM
  #38
herbie hind
i like torque . lots of torque . i rarely drive at anything above 5000 rpm. thx johan ,i'll more likely stick with stock pistons . good enough for webb...
Old Nov 10, 2006 | 09:07 PM
  #39
obehave's Avatar
obehave
There's been threads for years that all seem to agree that the OEM units have poor quench and a thin upper land. At higher boost levels these become more of an issue.
Randy never ran/runs a lot of boost so it probably wasn't an issue for him.
Start running 18+ psi and you're probably going to need them.
Improved quench even on a stock motor will gain you HP. Would it be worth the money though? Not really.
Old Nov 11, 2006 | 05:25 AM
  #40
caminifan's Avatar
caminifan
Don't set unrealistic expectations for the MINI's 1.6 liter motor. If you are looking for something like the BMW335i's output (300 ft/lbs that is billiard table flat from 1,400 to 5,000 rpm), I doubt that is achievable. BMW is using a combination of direct injection, turbo charging, variable valve technology for both intake & exhaust and about twice the displacement to get to that performance level. All of which are just not available for the R53. (Not even on the aftermarket; someone had a thread going about swapping an R56 engine into the R53 MINI, but that is also doubtful absent some serious integration effort.)
Old Nov 11, 2006 | 05:53 AM
  #41
herbie hind
thx obe. just figured i'd throw it out there as the head and pan will be off come summer and if i was gonna need a piston well..... hey .
Old Nov 11, 2006 | 05:55 AM
  #42
herbie hind
300's too much for this car imo . i'd be happy with say 175 . that'd work awsome on this (little) car.
Old Nov 11, 2006 | 07:20 AM
  #43
obehave's Avatar
obehave
I'm there at the crank.
Still wanting more.
Old Nov 11, 2006 | 07:37 AM
  #44
stevecars60's Avatar
stevecars60
Still wanting more.
More is better. 175 - 200 would be perfect for what I want & those are reasonable numbers. Also, you are right about the stock pistons although they are pretty durable but 18lbs of boost is about as much as they can stand for extended periods of time ( IMHO ). You're taking the motor apart anyway? Why not some better pistons?
Old Nov 11, 2006 | 11:31 AM
  #45
caminifan's Avatar
caminifan
Still wanting more.
175 hp at the crank is a 7 hp increase over stock. Conceivably that could be achieved with a real good CAI and cat-back implementation. (I though you were producing higher numbers?) More can be had for relatively not too much $. Anything north of 200 (at the crank) is going to start to cost $. And driveability will likely suffer.
Old Nov 11, 2006 | 11:36 AM
  #46
caminifan's Avatar
caminifan
If 175 hp at the crank is what you are looking for, that is easily achievable with a 17% s/c reduction pulley. (If you are looking for 175 ft/lbs., that is still easiily achievable with a 17% s/c reduction pulley.) And, with a 17% s/c reduction pulley, the torque happens lower on the rev range.
My personal goal is somewhere around 210 & 200 (hp & ft/lbs) at the crank with the output occurring in the 2,500 - 5,500/6,000 rpm territory (otherwise known as maximizing the area under the curve).
Old Nov 11, 2006 | 01:16 PM
  #47
Johan's Avatar
Johan
Honestly you need an engine dyno w/ climate controlled room to measure HP at the crank, we can argue until were blue in the face about drive train loss...I've heard of a stock mini running 135 at the wheels and my dyno runs an 06 stocker at 157HP. I'm not really sure where I'm going with this but thought I'de put it out there.
And we had a mini with just a CAI, Exhaust, 15%/2% combo lay down 185 HP and 165 TQ 72*F 71% humidity.
Old Nov 11, 2006 | 01:27 PM
  #48
stevecars60
Those are the kind of figures I'm looking for. It's easier to get 220hp at the crank with low 170'lbs, but it won't be any where near flat with OE pieces. You're looking for the same kind of driveablity that many would want as a DD. A better head & maybe a cam could put this 1.6 in the ball park. 2500 might be a little optimistic, 3K to 6K+, IMO, is doable ( only 500 rpms but that's big on the street ). There is a ton of value in a good head & header.
We'll just have to wait till Johan & Obe give us some #s.
Old Nov 11, 2006 | 01:31 PM
  #49
obehave's Avatar
obehave
We were talking torque not HP.
Old Nov 11, 2006 | 01:39 PM
  #50
stevecars60
If you had the sheet for this car, I would be very thankfull to see it.
Dyno numbers have been talked to death. I guess people insist that they need those numbers. If you had a dyno that only produced numbers 1 - 100 & did a pull with an output of 56 & installed a head, did another pull with an output of 68, that works for me. All I care about are those 2 lines. The stop watch will tell me the rest.
