Drivetrain new alta top mount/direct flow intercooler
Old Nov 21, 2006 | 01:38 PM
  #101
ALTA2's Avatar
ALTA2
Manufacturer
Oh MAN! And we spent hours cleaning up! Just kidding. That is too bad, make sure you have time in a couple of weeks!
Old Dec 2, 2006 | 05:42 PM
  #102
sideburns's Avatar
sideburns
Questions to Alta(Jeff):
What is your opinion of using 2006 Mini Cooper S JCW GP software with your v2 intercooler? I have a 2005 MCS with a JCW kit. I understand the only engine change done to the GP was an enlarged intercooler and software upgrade. My guess is that the software advances the timing somewhat and there may be a remapping of the injectors. Do you think the Mini dealers would have a problem performing this upgrade? I just emailed JCWorks in England with this same question - no answer yet. It seems like this would "bump" up the horsepower of your intercooler by two or three (or more??). Hopefully another plus would be that the JCW/MINI/BMW warranty would still be in effect.
Old Dec 2, 2006 | 11:12 PM
  #103
Dr Obnxs's Avatar
Dr Obnxs
There are few changes to the sw...
it takes into account the 380 cc injectors, and has a different red-line. I honestly don't know if they go any deeper into the tune, but I'd be surprised if it were much different than the standard works software.
As far as getting it loaded, Minis position is no, they won't do it. But one of the dealerships I've spoken with has loaded JCW sw onto customer modded cars. It's a roll of the dice.....
But SW per se isn't really going to make an IC generate more or less power, really.... At least I've never seen a custom tune done for just an IC, much less one that has generated any increase in hp.
Matt
Old Dec 3, 2006 | 04:40 PM
  #104
sideburns's Avatar
sideburns
JCW GP Software
Dr O:
The MCS JCW GP advertises 214 horsepower which they get from a larger intercooler and software. My understanding is that this is the total of all the engine mods done by Mini on the GP. If the intercooler itself gives no more horsepower, it has to come from the software!! If the software does advance the timing and flows more fuel to the injectors(380's) then this is where the added 7 horsepower (above current JCW kit) is coming from. If there is another explanation - let us know. Thanks
Old Dec 3, 2006 | 11:27 PM
  #105
Dr Obnxs's Avatar
Dr Obnxs
I don't understand...
If this were the case, we wouldn't have an IC at all! An IC increases air density by cooling it, but the price of running throught the IC is some loss of boost. The GP has an IC that has a lower pressure drop. That means that basically you get the same cooling, but with a smaller pressure drop and a correspondingly higher air density. This is what makes the power.
Matt
Old Jan 21, 2007 | 07:06 PM
  #106
robino's Avatar
robino
so basically, for those of us with an aftermarket (Alta V2.0) IC ...the GP re-flash would most likely be a closer tune than that of a JCW?
Old Jan 21, 2007 | 09:52 PM
  #107
Dr Obnxs's Avatar
Dr Obnxs
Are they different?
if so, yes it would be closer.
Matt
IQRaceworks
Jul 15, 2022 05:51 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
