Drivetrain 05 exhaust on 02?
Old Sep 13, 2006 | 06:40 PM
Wake|MCS's Avatar
Wake|MCS
05 exhaust on 02?
Ok well, my question is, people modify 02-04 exhausts to fit their 05-06's. Is the same possible to make an '05 exhaust fit an '02 S? What would be required? Too difficult? Or a simple task for a QUALIFIED exhaust shop (Miami Muffler, best in Miami). Not your typical rinky dinky shop on a random corner somewhere.
Old Sep 13, 2006 | 08:00 PM
aminicooper's Avatar
aminicooper
All you need is to keep the hangers from your '02 and replace them on the '05 so that the mounts are in the proper angle.
'03 hanger on top, '06 still mounted.
Old Sep 13, 2006 | 08:12 PM
Wake|MCS's Avatar
Wake|MCS
I was referring to aftermarket exhausts but the answer is the same, it can be done. Thanks a lot! Now I finally know the difference between the hangers, it's only 1 of the hangers so it shouldn't be difficult.
Old Sep 20, 2006 | 05:56 AM
1FSTMINI's Avatar
1FSTMINI
Yes, it can be done....All you have to do is bend the hangers accordingly.
Old Sep 20, 2006 | 06:41 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
We make it work all the time - no problem at all. For reference, it is easier to cut the inner hangers, turn them, and weld them in the correct orientation.
Hope that helps!
Randy
Old Sep 21, 2006 | 11:57 AM
fueledbymetal's Avatar
fueledbymetal
Originally Posted by RandyBMC
We make it work all the time - no problem at all. For reference, it is easier to cut the inner hangers, turn them, and weld them in the correct orientation...
Depending on the exhaust you're using, you don't even need to do that much. I test-fit my Scorpion exhaust without hooking up the inside hangers and determined they weren't needed. It worked like that for 22k rattle free miles
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
embiggenedmini
Oct 15, 2015 12:36 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
