Drivetrain 2003: Power steering noise
Old Sep 11, 2006 | 10:47 PM
englishbloke's Avatar
englishbloke
Does anyone get a whine when you move the steering wheel. Well I do I my 2003 MC and so does my mum in her 2003 MC. Anyone have/had this problem? What did you do to stop it?
Old Sep 11, 2006 | 10:57 PM
Eric_Rowland's Avatar
Eric_Rowland
It's not a problem, it's an 'idiosyncracy'.
Yes, they all do it.
No, nothing is broken.
No, the dealer isn't blowing smoke up your electric steering pump.
Old Sep 11, 2006 | 11:09 PM
goin440's Avatar
goin440
Well, like Eric said, but it should be noted that the pumps and steering rack eventually will fail and need replacement (you won't lose control, so don't freak). There is a whine with normal operation, however, symptons of them going out include an increase in volume of the whine and a looseness in the steering wheel. I suggest you have it checked out just in case. Since the dealer would charge for this, I would join a local MINI club and have one of the members listen to it, preferably someone with a MINI mechanical expertise.
Yes, the fix is expensive. Atleast $900 (out of warranty).
Old Sep 18, 2006 | 01:04 AM
trackster's Avatar
trackster
Thwey all do tend to whine but keep a eye on your fluid level. If you find you are losing fluid but its not showing up on the ground check the boots at the end of the steering rack. Some cars have a problem there and the boots fill up with fluid.
Old Sep 20, 2006 | 05:42 AM
1FSTMINI's Avatar
1FSTMINI
Id make sure you have the updated ventilation fan on the pump. You will notice it by a screen covering the blades. if you dont have this type id def get one right away or put something in its place to prevent road debris from seizing the fan which will knock out the pump and engine fan if they never did the resistor recall on the car.
Manny_cooper
Sep 10, 2015 11:09 AM
bansasn
15
Sep 4, 2015 01:24 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
