Drivetrain A Minor Mod
Old Sep 1, 2006 | 09:51 PM
  #26
Motor On's Avatar
Motor On
Originally Posted by ignote
Of course. Free research for the vendor.
I typed a rant, then tought about it, I'm keeping my mouth shut until I see it. For all we know its just a re-desgin so that someone else can manufacture the box with out infringing on anyones rights.
Old Sep 1, 2006 | 11:41 PM
  #27
markldriskill's Avatar
markldriskill
Parts from...
Originally Posted by polizei
Uhhh, I'm interested in that CAI lol. And Mark, where did you order all your parts from?
-Cody
The metal caliper bushings, ATE Super Blue Brake Fluid, and stainless steel lines from Turner Motorsports. I just checked and you can get Hawk pads from there too. I have heard a lot of good things about those, and I think I would try them the next time I buy (instead of Greenstuff) even though I have no complaints.
The Greenstuff pads, I recommend you google, as they are available many places and you can probably find the price du jour that way.
When I did it, I thought the best way to go was slotted (NOT cross-drilled, as I had heard that there was some tendency toward warpage of same!! ) rotors also. At that time, I also thought that the drilled appearance looked kinda cool also (they still do, BUT...) slotted is the best performance way. Sok, I got the EBC slotted with "dimples" that make it appear that the rotor is also cross-drilled. If I had it to do over again, I think I would wait and give stock rotors a chance to perform with the other upgrades before getting the slotted rotors, and get Power Slots instead of the EBC's. Hope that makes sense.
Motor on.
Old Sep 2, 2006 | 12:27 AM
  #28
Minirox's Avatar
Minirox
Originally Posted by JJ Blue
I don't plan on racing my 2006 MCS. I just want a bit more HP. Im thinking of a JCW CAI, a 15% Ultrik pulley and a 19mm rear sway bar. Anyone see any problems with this setup?
Ya once you start it is hard to stop.
Old Sep 2, 2006 | 07:17 AM
  #29
polizei's Avatar
polizei
Motor on.
Thanks, I'll check it out.
-Cody
Old Sep 2, 2006 | 11:04 PM
  #30
JJ Blue's Avatar
JJ Blue
I've made my decision to get the Alta 15% pulley , CAI and a 22mm rear sway bar all to be purchased and installed at Webb Motorsports. My question is......I am now planning on having these mods done right after purchasing the car. Is that wise?
Old Sep 2, 2006 | 11:09 PM
  #31
caminifan's Avatar
caminifan
Well, since you can get a JCW package straight from the factory, there shouldn't be any adverse consequences from the mods you are considering. Just be sure to follow the break-in period limits.
Old Sep 3, 2006 | 12:33 AM
  #32
Motor On's Avatar
Motor On
Don't think you'l;l do any harm but it might be worth it to drive the car in stock form for the break in period so that you can feel the effect the mods have on the car.
Old Sep 3, 2006 | 12:57 AM
  #33
JJ Blue's Avatar
JJ Blue
I'm going to follow the break in procedure like it was law. I even plan on an extra oil change right after the break in.
Old Sep 3, 2006 | 10:58 AM
  #34
caminifan's Avatar
caminifan
That is the best advice I could give! Just be sure to change the filter at the same time you do the oil.
Old Sep 4, 2006 | 07:50 AM
  #35
JJ Blue's Avatar
JJ Blue
Motor on said
"Don't think you'l;l do any harm but it might be worth it to drive the car in stock form for the break in period so that you can feel the effect the mods have on the car."
My wife agrees with you. She wants to know if the car is a lemon before we start the mods.
Old Sep 4, 2006 | 12:43 PM
  #36
caminifan's Avatar
caminifan
You might also do your mods sequentially (as opposed to all at once). That way, you can get an appreciation of the relative contribution each mod makes to the overall fun factor. I am following that approach (sequential modding) and it is giving me a new insight into how my MINI is being "woken up".... The SSRs and non-runflat tires were a great start (my neck thanks me each time I take the car for a drive). The FSDs were the icing on the cake ride-wise. The 17% Alta really was an eye-opener. I am wondering if the SSRs have acted to magnify the benefit of the Alta, since I was able to loose so much rotational mass (~80 lbs). And the sound of the Gatorback belt (installed with the Alta) is a kick....
Old Sep 4, 2006 | 12:51 PM
  #37
JJ Blue's Avatar
JJ Blue
Caminfan
Your trying to get me hooked on the mod addiction aren't you? There should be a law against mod pushers.
Old Sep 4, 2006 | 12:53 PM
  #38
Motor On's Avatar
Motor On
Caminfan
Mods = Crack
Old Sep 4, 2006 | 01:29 PM
  #39
caminifan's Avatar
caminifan
Caminfan
Well, not really.... You made the decision to mod all on your own without any help from me. I am just suggesting ways that you can get maximum enjoyment out of the experience....
Old Sep 4, 2006 | 02:20 PM
  #40
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Originally Posted by caminifan
..., since I was able to loose so much rotational mass (~80 lbs)...
How did you do this? The average weight reduction going from 17" Slites and runflats to lightweight 17" rims and non-RFs is about 45lbs total. Are you running superlight 15"s? I'm sure there's interest in the products and weights that can get an 80lb wheel weight saving!
cheers,
Old Sep 4, 2006 | 09:56 PM
  #41
caminifan's Avatar
caminifan
Originally Posted by gandini
How did you do this [Emphasis added.]? The average weight reduction going from 17" Slites and runflats to lightweight 17" rims and non-RFs is about 45lbs total. Are you running superlight 15"s? I'm sure there's interest in the products and weights that can get an 80lb wheel weight saving!
SSR 16x7 weigh in at 11 lbs each (per Tirerack.com). The S-lites that were replaced weighed in at ~32 lbs. 20 lbs per corner x 4 gets me to 80 lbs of rotational mass reduction.
Old Sep 5, 2006 | 09:30 AM
  #42
DrPhilGandini
caminifan: Yes--you had to replace those SLites if they weighed that much! Most 17" ers that I've weighed were around 26lbs each, so yours were considerably heavier than normal. Well worth changing out.
Now if you get a BBK, you can nearly get another 20lbs off the unsprung weight, and better fade resistance to boot!
cheers,
Old Sep 5, 2006 | 10:57 AM
  #43
caminifan's Avatar
caminifan
Yeah, I really noticed the difference in weight when I was removing the original wheels/tires and replacing them with the SSRs....
I noticed you have the TCE BBK on your MINI. Did Todd even up the brake stopping balance front and rear to match the factory setting (too much grip in the front can actually lengthen the stopping distance as the ABS steps in and modulates things)? I have been considering a TCE BBK, but have held off for the moment because of the balance issue. Also, I don't know if the TCE BBK kit will work with my 16 inch SSRs. Lastly, is there really a 20 lb difference between the TCE BBK and the stock calipers and rotors? I thought it was 10 lbs.
Old Sep 5, 2006 | 11:09 AM
  #44
Bahamabart's Avatar
Bahamabart
AND, it is easy to justify..."But, Honey, if I make the car go faster, shouldn't I make sure it's safer too? You don't want the wheels always looking like *&^%, do you?"
I can top this - I needed to replace my scoop because the original blew of the car (see what happens when you fiddle with it ). My wife said order a new scoop the car look ridiculous!!
SO
I went to M7 and ordered a scoop with DFIC (the rest of you ordered DFIC w/ Scoop) - so my wife thinks the replacement scoop cost 800 bucks. AND
that is how you get a DFIC was free .
Old Sep 5, 2006 | 09:21 PM
  #45
JJ Blue's Avatar
JJ Blue
Uh, I think I called the thread Minor Mods. That is way more calculus than I expected.
Mod on
Old Sep 5, 2006 | 11:50 PM
  #46
vsmini's Avatar
vsmini
i agree with research NAM and go with what you like. the things i looked for are steel pulley, otherwise i am happy with all of my mods. just got back from a drive around the block...
Old Sep 6, 2006 | 04:06 AM
  #47
markldriskill
Brilliant!!
SO
Wait. So, HOW did you get the original to "blow off"?
Unless I win the lotto, there is no other way I'll get my DFIC and M62. Uh, the supercharger IS integral with the scoop and intercooler, isn't it?
vulkandino
Oct 31, 2015 08:29 PM
Ovrclck
Oct 5, 2015 09:45 AM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
eliseo1981
Sep 30, 2015 07:57 PM
