Drivetrain Denso Iridium Plugs
Old Aug 3, 2006 | 07:44 AM
minimusprime's Avatar
minimusprime
Denso Iridium Plugs
I just picked up a 15% alta pully and an alta cai. I was thinking about picking up some denso ik-22 iridium plugs for my mcs.
I dug up these on ebay.
http://cgi.ebay.com/ebaymotors/Denso...QQcmdZViewItem
My question is even though these are listed for subaru's are they not the same plug i would put in my mini. I was kinda thinking they were prob the same but just gapped differently. I have read you can actually gap teh iridium plugs but you have to be very carefull how you do it so you don't break the element.
I was also considering ordering them from detroit tuned but they were considerably more expensive and they didn't specifically list them as ik-22's or ik-20's. I suppose i could just call and ask.
Can anyone please advise.
P.S. Yes i did use the search feature and found a few other therads similar to this one but none that were current. So sorry if this ? offends.
Old Aug 3, 2006 | 08:00 AM
ScottinBend's Avatar
ScottinBend
All of the IK22 plugs are the same. That is the plug I am running and have had no problems at all. Another place to get them is http://www.apwonline.com/shop/item.asp?itemid=98.
Old Aug 4, 2006 | 02:13 AM
Eastsidemini's Avatar
Eastsidemini
ik22
Upgraded to ik24 great plugs and is 2 range colder for the highly modded.
Old Aug 4, 2006 | 06:47 AM
JoeCool's Avatar
JoeCool
I heard that these plugs are a PITA to re-gap. The IK22's have a gap of .8mm and factory is 1.1mm (I think). Is anyone regapping these plugs?
Old Aug 4, 2006 | 06:51 AM
dmh's Avatar
dmh
IK22s are gapped at .4mm
Old Aug 4, 2006 | 06:52 AM
Yucca Patrol's Avatar
Yucca Patrol
My understanding is that these plugs are not to be re-gapped because the iridium electrode is so tiny and fine that it is easily damaged.
Old Aug 4, 2006 | 07:07 AM
dmh's Avatar
dmh
You can regap them but you don't need to. Keep them at .8mm.
Old Aug 4, 2006 | 07:54 AM
obehave's Avatar
obehave
That's ~.032
Old Aug 4, 2006 | 07:56 AM
JoeCool's Avatar
JoeCool
Nope- .8mm according to Denso's website.
http://densoiridium.com/sparkplugspecs.php
Old Aug 4, 2006 | 08:02 AM
TwOMINIs's Avatar
TwOMINIs
I tried to re-gap one....and I totally ruined it.
From what I've read here they come properly gapped from the factory for our application...If you do a search you can read about it till your eyes bleed.
Old Aug 4, 2006 | 08:13 AM
obehave's Avatar
obehave
I've gapped them. Good tools and being careful work well.
Leaving them at .035 works well though so there is really no need.
Old Aug 4, 2006 | 09:02 AM
tennis_man's Avatar
tennis_man
With the correct tools they are easy to adjust the gap. Just be carefull.
I set mine to .038 because I have a high output coil pack.
Old Aug 4, 2006 | 09:17 AM
minimusprime
specifically what kind of gapping tool did you use? I only ask as a just in case kinda thing.
Old Aug 4, 2006 | 11:12 AM
dmh's Avatar
dmh
Just keep them at .8 (I edited my earlier post.)
Old Aug 5, 2006 | 08:30 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
I have had 22s in my Mini for over a month and they work really well.
Just make sure you re-check your torque setting on the plug install several times and always when engine cold.
I torqued mine at 22 ft lbs. and have checked them 3 times - and each time they needed some more seating.
Lots of threads on this subject elsewhere.
Old Aug 6, 2006 | 08:50 AM
Petrich's Avatar
Petrich
exactly
The advice to prefer the Iridium spark plugs, use the IK-24's, and leave them at the out of the box gap setting is excellent advice for the performance oriented and tuned engine crowd. These are the current state of the art consumer spark plugs. Review this PDF file at the Sparkplugs.com website for an engineering update: http://www.sparkplugs.com/pdfs/iri.pdf
Regards,
John Petrich in Seattle
Filmy
15
Jun 6, 2023 06:27 AM
patsum
26
May 29, 2021 06:29 PM
eliseo1981
Sep 18, 2015 10:40 PM
JMF1975
Sep 11, 2015 03:29 PM
Sep 4, 2015 03:56 PM
