Drivetrain CravenSpeed short shifter help
Old Aug 3, 2006 | 07:27 AM
Darxar's Avatar
Darxar
Can someone link some how-tos i cant seem to find any so i can install my new SS. also, the only items included in the box was the shifter, zip tie, and realy basic instuctions.... i would assume i dont need any other parts or any lube? of any kind? anyone have any issues breaking or re-using the existing parts int he car? i have an april/03 build.
Old Aug 6, 2006 | 07:28 PM
1FSTMINI's Avatar
1FSTMINI
Its pretty simple
Drop the exhaust from the header and let it hang from the back.....remove the heatshield and unbolt the box
from the top....yank up the ****....pull the boot off.....and unclip the cables......if its like the B&M shifter which im sure it is...You will need to remove the WHITE bushing which has THREE tabs ( it was a pain when I did it ) and pop that off the old rod and re-install it on the new one ( MAKE SURE YOU PUT IT BACK ON THE SAME WAY CUZ IT GOES ON 2 WAYS) and reverse instructions. Make sure you grease the ball where the white bushing sits very well with white lithium grease
hope that helps
RobbyD
Jan 29, 2019 01:22 PM
OutMotoring
Mar 3, 2017 06:29 AM
02miniSguy
Nov 17, 2015 10:29 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Samhillrocks
Sep 29, 2015 12:55 PM
