Drivetrain Installed AGS and have problems
Old Jul 20, 2006 | 12:48 AM
  #26
Dr Obnxs's Avatar
Dr Obnxs
I'm not too old a dog...
I can still learn new tricks... But only if there's a good reason to! I hope you're digging is successful.
Matt
Old Jul 22, 2006 | 01:42 AM
  #27
tech-gi's Avatar
tech-gi
Revein au nous Mouton?
Lets return to the sheepole, they are wandering.
Someone had a AGS problem?
Old Sep 8, 2006 | 04:18 AM
  #28
Kendel72's Avatar
Kendel72
Well my MCS is @ Hendrick Mini to address an issue with a busted motor mount and I had them check to see why I was getting a SES and EML light, they called back to say un-metered air flow is what is causing it! They claim that the tube is probabaly not sealing off good and causing it to throw the code.
Old Sep 9, 2006 | 07:03 AM
  #29
MSFITOY's Avatar
MSFITOY
Wow...you've driving that long with a leak? Who did the install?
Old Sep 9, 2006 | 10:01 AM
  #30
supercoopers's Avatar
supercoopers
I'm surprised that you tolerated your car running so badly for so long. I had my supercharger replaced by a tuner here in the UK and they left me with a nice big leak at the green supercharger seal...the car wouldn't idle properly and it drove me nuts! definitely took the shine off of an otherwise pleasant enough experience.
Once the leaks are gone, your car should run alot better that's for sure. Do you have a 'hunting' idle problem at the moment?
Cheers,
Henry
Old Sep 9, 2006 | 07:53 PM
  #31
Kendel72's Avatar
Kendel72
I did the install and it runs perfect!!! Other than throwing the code you would never know there is a leak and I am not so sure there is one, the throttle response is very crisp and the idle is smooth. Some times the code doesnt pop up but most of the time it does, hell if it had ben running bad I would have torn it down as soon as it happened but until the tech @ Hendrick told me it was definitely a leak YESTERDAY I was unsure of why the code was being thrown, I spoke to Peter @ M7 and he says that if it had any kind of leak it would not even idle but there is no performance problems @ all, Sorry I am not the mechanic you are MSFITOY!
Old Sep 9, 2006 | 07:55 PM
  #32
MSFITOY's Avatar
MSFITOY
I'm not a mechanic...I didn't mean to insult your ability...just asking for information so that I might be able to asess the situation and maybe help as I know that this install can be a little tricky...
Old Sep 9, 2006 | 08:01 PM
  #33
Kendel72's Avatar
Kendel72
Tricky is right and dont sweat it, the only thing I can think of that may have caused it is where you bolt the SC tube to the SC with the one bolt on the front side, it may have gotten cocked a little and pinched the gasket, the only thing that has kept me from tearing it down to fix it is the fact that other then the SES light it runs perfect and trying to find a couple of hours to play guessing games
Old Sep 9, 2006 | 08:06 PM
  #34
inimmini's Avatar
inimmini
Originally Posted by Dr Obnxs
With fine multi-strand Cu wires, the stiffness caused by the solder can lead to work hardening right where the solder stops. This might be a good reason on cars that have lots of vibration, but corrosion just doesn't seem to fit. If you can find out more of an expanation, please share! I'm always looking for new tid-bits!
Matt
Galvanic corrosion? No moisture needed then.
squawSkiBum
Oct 2, 2015 09:21 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
