Drivetrain M7 Tuning --180F Thermostat
Any feedback out there on experience with the M7 180F Thermostat.
Everything makes sense on the claims, but have read little on NAM on such results.
Any and all input is appreciated.
Brad
Brad
Brad
Brad
Originally Posted by caminifan
What are you wanting to accomplish with a 180 degree thermostat?
Seann
Lot's of opinions, both Pro and Con. Check out these threads.
https://www.northamericanmotoring.co...ght=thermostat
And here:
Hope this helps,
Jim
And here:
Hope this helps,
Jim
It does reduce the coolant temperature and (on my car) reduced ignition timing retard. It will cause a cel, and that fault is emissions related. I check and clear my codes frequently enough that the fault is not stored long enough to turn the light on. If you aren't into that aspect of cars the t-stat is probably not for you.
There are some threads about this topic.
matthewbrakeii
May 13, 2021 08:39 AM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
PSIChocolate
Aug 13, 2015 12:46 PM
