Drivetrain Installing an OCC
Old Aug 2, 2006 | 11:21 AM
  #76
JoeCool's Avatar
JoeCool
Cody, I think this is the diagram you should be using.
Old Aug 2, 2006 | 11:31 AM
  #77
polizei's Avatar
polizei
Edit #3. I ran the green line how it is supposed it go, BUT the valve is bigger than the hose diameter!? Now what?
-Cody
Edit* That must be why Joe. Thanks, I'll try that!
Old Aug 2, 2006 | 11:38 AM
  #78
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Cody: You're right about the diameter of the PCV and the OCC line--I used a T and simply capped off one side of the T. You can actually see it in my photo in post #70.
You're almost there...
Old Aug 2, 2006 | 11:42 AM
  #79
polizei's Avatar
polizei
Ok, is this how it's suppose to be!? I'm going insane here lol.
And does it matter which side the lines go on the OCC? As you can see, grey line is going to the LEFT side of the OCC, and the PCV line is going to the RIGHT side.
Old Aug 2, 2006 | 01:56 PM
  #80
DrPhilGandini
Looks good Cody. Im not aware of any specific line orientation on the OCC.
Old Aug 3, 2006 | 07:47 AM
  #81
obehave's Avatar
obehave
It should matter which one goes where. If the unit is designed well the inlet piping will lead towards the bottom of the unit. Normally below some filtering material. The outlet will be above this material so that oil will collect in the material and not be draw back into the outlet.
Ideally the can should set lower than the PCV line so that oil doesn't drain back into the valve. Not a huge deal but something to keep in mind for sure.
Old Aug 3, 2006 | 12:05 PM
  #82
stevecars60's Avatar
stevecars60
Polizei, this "how to" should remove any doubt as to how to hook up an OCC correctly.
Good Job
Wow, which post?
Old Aug 3, 2006 | 12:53 PM
  #83
DrPhilGandini
WRT the How To. Although it makes life much easier, and allows you to clean any oil from the IC, it's not essential that you remove the IC. With the preferred routing (my diagram above) you can access the PCV and the grey line after removing the plastic IC cover. Not a lot of room but enough.
I also installed rubber grommets in the holes cut in the cowl through which the OCC lines go. Much neater and may prevent wear over 100,000s of miles...
Although the cowl location for the OCC is neat, having it down near the front left bonnet clasp and earth strap guarantees it is lower than the PCV. Unfortunately this is not available with either the Xenon headlight washers or the engine damper, so the cowl is the next best location.
cheers,
Old Jan 18, 2007 | 06:01 PM
  #84
Bahamabart's Avatar
Bahamabart
DOES THIS SET-UP WORK as pictured below?
Originally Posted by DrPhilGandini
obehave:
I was thinking along the lines of your last question: Could we come up with a OCC venting path that used the vacuum in the grey line rather than from the inlet tube pre-TB? We could cap or plug this line, and still have the gases being drawn out of the tappet cover, through the OCC and back into the system via the grey line.
I sketched a diagram of the routing Im thinking of (please excuse the drawing--I just got my tablet and this is my first attempt at drawing with it!):
Cheers,
Old Jan 18, 2007 | 07:14 PM
  #85
Partsman's Avatar
Partsman
Legion_of_Doom
Bart, I had my catch filter installed like that and caught nothing but moisture.
Old Jan 18, 2007 | 07:18 PM
  #86
chuckt's Avatar
chuckt
Deleted.
Old Jan 18, 2007 | 08:18 PM
  #87
DrPhilGandini
Absolutely not! Listen to these people. My diagram of the **Preferred Routing** is on this thread. The diagram in post #84 above is the way that Alta, and M7 and others suggest, but it is not a good way to route an OCC. Leave the RHS vent alone, and leave it connected to the intake before the TB.
I wish I had not posted that drawing now--if the preferred routing were the only one posted then that's what people would use.
Oh, well. It should be clear by now.
cheers,
Old Jan 18, 2007 | 08:29 PM
  #88
Mr. Normal's Avatar
Mr. Normal
obehave:
Cheers,
I feel a confession is in order. A couple weeks ago I printed out a copy of this diagram. I then took it down to a local art gallery and, well, it sold for $4200! I think I owe someone a couple bucks.
Old Jan 19, 2007 | 04:18 AM
  #89
stevecars60
Dr. Phil, who knew? You are a big time artist.
Bart as Partsman said, you will collect water & there may be an unpleasent oder as well. With this setup is the crankcase venting is bad to none at all. There is a post by motonikki812 about the bomb under the hood. His valve cover exploded.
Ah, another day being a Mini owner. All you need to think about is, are my shock towers ok, will my power steering pump catch fire or will it be the ABS controler that will burn the car to the ground. Yup, life is grand.
Old Jan 19, 2007 | 04:59 AM
  #90
Bahamabart's Avatar
Bahamabart
Thanks guys . Here is my experience that will hopefully help others.
1) I did the original OCC setup like Alta/M7 suggested - trapped milky water.
2) previously when I experimented w/ my own homemade OCC, I had done the single sided setup (like obehave pictures in #81) - trapped oil nicely. I do recommend placing steel wool inside the can for it help catch more oil.
3) I decided to try the setup I questioned above - routing both engine vents thru OCC to grey tube. UNFORTUNATELY, the pretty aftermarket tubing collapsed WHICH CAUSED a) burning oder and b) developed a squealing sound. Perhaps with good tubing this will work? BUT have decided to revert to a single sided setup for it trapped oil.
I can only hope I did not do any long term damage.
Old Jan 19, 2007 | 05:33 PM
  #91
chuckt's Avatar
chuckt
Deleted.
Old Jan 19, 2007 | 08:56 PM
  #92
daleCarlsbad's Avatar
daleCarlsbad
obehave:
Cheers,
This diagram is the wrong way to plumb the catch can. There are two different "curcuits" that should be maintained. Do some research on the pressure differentials inside the Mini's engine (this forum) and simply install the catch can in-line on the PVC to gray line only.
Old Jan 19, 2007 | 09:59 PM
  #93
DrPhilGandini
Would you all please stop posting the drawing of the **not preferred** routing I drew? Geez--we've gone over this enough times. I'll pull it from my website... The preferred routing is from the PCV to the OCC back to the grey line from the SC. Enough already. There's new information, and much more experience which makes posts like the one above "out of context".
Remember: this is the preferred routing:
OK?
Old Jan 20, 2007 | 01:04 AM
  #94
motonikki812's Avatar
motonikki812
This routing that yoy all did your best Picasso imitation on post#93 is the RIGHTway to do it. I tried the other ALTA/M7 suggested routing and it was not good. To make a long story short my beautiful JCW valve cover litteraly turned into a hand grenade. BOOM!
I say that we were not getting enough vacuum or suction from the grey tube through the OCC then sucking any positive pressure out of the valve cover.
This method of yours just makes so much more sense. This is what I am running now. I learned the hardway!
Jasun
Old Jan 20, 2007 | 05:35 AM
  #95
stevecars60
Jasun
Exactly
The crankcase NEEDS venting.
THE END
Old Jan 20, 2007 | 02:21 PM
  #96
herbie hind's Avatar
herbie hind
Originally Posted by stevecars60
If you leave the breather alone ( from the VC to the intake ) there is a baffle to prevent oil from being sucked out by the intake. The bottom end needs air, after all it is a big pump...
that seems reasonable. bmw ain't too stupid.
Old Jan 20, 2007 | 02:38 PM
  #97
stevecars60
They aren't alone. Can't say I have ever seen a sealed system on any intrnal combustion engine, even a 2 cycle uses the intake port, piston, reed or rotary valve for air, all be it for fuel dilivery as well.
Old Jan 23, 2007 | 11:36 AM
  #98
DrPhilGandini
btw, I pulled my DFIC to install the airfoils, and it's so clean inside that it doesn't even *smell* of oil! I'd say the preferred OCC routing is working very well to keep oil out of the IC.
Old Jan 23, 2007 | 12:38 PM
  #99
Bahamabart's Avatar
Bahamabart
My experience is that the M7/Alta setup collected milky water and the single sided set-up (i.e. connected to grey vaccum) collected more oil for the OCC contents were much darker in color.
Old Mar 12, 2007 | 04:48 PM
  #100
jaridp's Avatar
jaridp
so the question is....do you want to trap mikly water and such or the oil?
