Drivetrain Need a little more info from you guys that have a Apexi SAFC
Old Jun 27, 2006 | 06:15 PM
SSMini's Avatar
SSMini
I have one on my Turbo Cordia, but Ive noticed where some of you have recommened using a Apexi SAFC on the MINI. Those of you that have one, how hard was it to install? Was there a big diffrence after tuning?
Thanks....
Old Jun 29, 2006 | 08:31 AM
Trickle X's Avatar
Trickle X
Its not hard to install. Its basically 7 wires that tap into the stock wire harness. I took the tops off the connectors to get a better view of what wires are what. Once all cut in, then you just need to go through the setup of Knock, how many cylinders, and so on. Then you need to setup up your fuel maps. To get your most out of it, you would need to take it to the dyno to get the most out of the tune. You need to make sure you get the Apexi Select, which is designed for the German cars including the Mini.
Old Jun 29, 2006 | 12:53 PM
SSMini's Avatar
SSMini
Thanks for the info.
Old Jun 29, 2006 | 01:57 PM
YellowBellyMini's Avatar
YellowBellyMini
IMO, You'd be better off going with MTH. I have one and it robbed me of 3whp. It helped a little in the midrange, but there seems to definately be more to be had with the more involved tune from a MTH reflash. Plus, by the time you pay to have it tuned on a dyno you'll be in for about the same price.
Old Jun 29, 2006 | 02:22 PM
SSMini's Avatar
SSMini
If I were to go with the MTH, no tuning would be needed? Just get it reflashed and go?
Old Jun 29, 2006 | 10:03 PM
trickedmotoring's Avatar
trickedmotoring
how about using both..... get the timing and dsc from the mth and a/f from the afc.
Old Jun 29, 2006 | 11:35 PM
MiniCooperMan37's Avatar
MiniCooperMan37
I like my AFC, basically you have to have the ***** to cut into your wiring. Other than that its all good. With my header, cat-back, crank, and AFC, i went from 163hp to 196hp. Don't really know if that is good though.
Old Jun 30, 2006 | 11:24 AM
kalbone's Avatar
kalbone
same here.... kind of.... 158whp to 185whp....then added header no cat 195whp.
Old Jun 30, 2006 | 02:33 PM
trickedmotoring
did you go somewhere to get it dyno tuned.
Old Jun 30, 2006 | 03:36 PM
SSMini's Avatar
SSMini
What do you mean by crank?
Old Jun 30, 2006 | 04:07 PM
Minirowski's Avatar
Minirowski
Has anybody a wiring diagram for 06 spec? I heard 06 have a different Ecu than earlier ones.
Old Jul 2, 2006 | 11:42 AM
J0kER's Avatar
J0kER
crank pully
Old Jul 10, 2006 | 07:05 PM
1FSTMINI's Avatar
1FSTMINI
Originally Posted by joker
crank pully
thanx pumpkin.
Old Jul 11, 2006 | 02:42 PM
MiniCooperMan37
Yeah, throw it on a dyno that graphs the a/f ratio, run it once, see what the ratio is, adjust, run again, adjust, run again, adjust,.......
Old Jul 11, 2006 | 05:47 PM
J0kER's Avatar
J0kER
Originally Posted by 1FSTMINI
thanx pumpkin.
no prob. honey bunny
Old Jul 11, 2006 | 05:55 PM
kalbone's Avatar
kalbone
ditto
Old Jul 11, 2006 | 06:08 PM
SSMini's Avatar
SSMini
We need to get someone to do a write up on how to install one....
Old Jul 11, 2006 | 08:09 PM
1FSTMINI's Avatar
1FSTMINI
just go by the diagram and make sure your connections are PERFECT or ull ruin the dme wires n cause shorts.
Old Jul 12, 2006 | 06:49 AM
etalj's Avatar
etalj
As i understand it, SAFC leans out the A/F ratios, whereas MTH advances the ignition timing, while maintaining a rich mixture. Can you run MTH and SAFC at the same time while staying safe?
Old Jul 12, 2006 | 07:38 AM
Dr Obnxs's Avatar
Dr Obnxs
You better be carefull.
run the low cost MTH for traction control and rev limit, and the Apexi for fuel tune.
But I think you nailed it, there are two philosophies for tuning minis, more advance while running rich, or less advance while running leaner than stock. If you go much leaner and more advanced, then make sure your knock sensor is working!
Matt
Old Jul 12, 2006 | 07:57 AM
ChocolateAZ's Avatar
ChocolateAZ
I am getting ready to install a safc2 and I am running the MTH Tuner file. I have been real impressed with the MTH, but after having it dyno'd a couple of times, it is running way rich, even for the advance it is running. We wills ee the result in a couple of weeks!
Old Jul 12, 2006 | 08:05 AM
Dr Obnxs's Avatar
Dr Obnxs
Excellent!
I'm looking forward to your results!
Matt
Old Jul 12, 2006 | 08:45 AM
1FSTMINI's Avatar
1FSTMINI
No
The point of a SAFC is to control your a/f yourself. The MTH program is a general map which isnt accurate which most people have seen on there wideband when runnin the dyno....The SAFC lets u fine tune the MTH flash. And yes....Of coarse you can run the SAFC with the MTH.
Its a stand alone fuel controller
Old Jul 12, 2006 | 09:27 AM
defylogik's Avatar
defylogik
as for installing the safc, we installed one on my friends supra with good results using piggy back wire clamps and quick change connectors when connecting it to the wiring harness. worked fine. we didnt have the first clue how to tune it, but hey it wasnt my car lol.
the piggyback wire clamp has a razer wire cutter dealy inside of it and when you close it , it pinches the wire and slices a hole in your outer wiring casing making a connection. ymmv
Old Jul 12, 2006 | 09:38 AM
SPIKE FRIEDMAN's Avatar
SPIKE FRIEDMAN
APEXi
Thanks....
I have a new APEXi controller which is necessary for installation . . . $50
