Drivetrain oil catch cans
Old Jun 25, 2006 | 05:12 AM
Arly's Avatar
Arly
oil catch cans
Here is my set up for 2 oil catch cans. One is hooked up to the pvc side nd the other is hooked up to the air intake side. Tthis way the original plumbing is kept.
questions are welcomed
Old Jun 25, 2006 | 07:27 AM
polizei's Avatar
polizei
How do you drain it? And why do you need two catch cans?
-Cody
Old Jun 25, 2006 | 09:53 AM
Mr. Pep'r's Avatar
Mr. Pep'r
Nice install!
The black mounting bracket, did that come with the ALTA or did you fab that yourself?
Rick
Old Jun 25, 2006 | 10:02 AM
Malcon's Avatar
Malcon
i didnt even worry about the intake tubing. it was completely dry when i checked it out. so i only routed my can to the rocker cover, and pvc. here is a pic
Old Jun 25, 2006 | 10:08 AM
Mr. Pep'r's Avatar
Mr. Pep'r
Arly, I only see one can in your picture.
Malcon, you used the same connection pionts as Arly correct?
Old Jun 25, 2006 | 10:11 AM
Malcon's Avatar
Malcon
yes, only he has a second can (behind the fire wire wall) and the other two hoses are running from the rocker cover to the intake tubing. i had no buildup or anything in that hose.
Old Jun 25, 2006 | 10:36 AM
Mr. Pep'r's Avatar
Mr. Pep'r
I see it now thanks for pointing that out.
I do not understand how there would be any oil in the intake other than the oil coming off the CAI fitler if it was over serviced. What other reason would oil show up in the intake?
Thanks.
Old Jun 25, 2006 | 02:44 PM
Malcon's Avatar
Malcon
same reason oil may be found in the IC. it may excape the rocker cover through the vents. i have nocited a puddle of oil in my catch can that i have stopped from going into my ic, but there was no residue in the intake. it would just get pushed in there every once and a while because of the vacume, etc.
Old Jun 25, 2006 | 04:13 PM
Mr. Pep'r's Avatar
Mr. Pep'r
So, once you install the catch can between the PVC and rocker cover it should keep all oil out of the IC?
Installing the other can would be for additional insurance then?
Old Jun 25, 2006 | 05:26 PM
sddave's Avatar
sddave
Arly, are you getting any oil in your 2nd can?
I am curious as I have seen several different ways to attach OCCs on NAM and it seems that the one config that always seem to catch oil is on the PVC side, while the other does not seem to catch much if any at all.
Malcon, swanky hoses , where did you get them? I am having the hardest time finding hoses to fit my can, everyone seems to be out of 3/8" hose
Old Jun 25, 2006 | 05:27 PM
Malcon's Avatar
Malcon
exactly. or you could just add more hoses and just use one catch can (just add T fittings etc) but the steal braided hose is a bit expensive once you get into adding more of it .
thanks man, i got the hose from a local performance chop its the russel steal braided hose. then i just got the fittings to connect to the catch can (i had to go with the 45 and 90 degree so that i could screw the second one on withought getting in the first fitting's way...i hope that makes some sence) but yeah they are great, the hoses that came with my catch can would implode do to the vacume of the supercharger. so it may be a smart thing to do. and yes there was zero build up in the intake side (this was after 5000 miles of driving)
hope this helped
Old Jun 25, 2006 | 05:50 PM
obehave's Avatar
obehave
hope this helped
Must ....control.....myself.....
Old Jun 25, 2006 | 06:21 PM
apexer's Avatar
apexer
uh-oh... there he goes
Old Jun 25, 2006 | 06:27 PM
obehave's Avatar
obehave
Nope...I'm calm. Watching a good western
Old Jun 25, 2006 | 08:14 PM
Arly's Avatar
Arly
I fabbed the bracket. I catch oil on the PVC side. I have not yet seen oil on the intake side even after a hot track day redlining most of the day. Before I installed the intake OCC I checked the IC and found oil in the boots and there was film on the inside of the IC. Clean the parts and reinstalled the IC and then added the 2nd OCC. I will check if adding the 2nd OCC has prevented the oil collection. If this does not work, I will try to baffle the inside of both cans and then reinspect the IC.
Old Jun 25, 2006 | 08:45 PM
Malcon's Avatar
Malcon
whats that about?
Old Jun 26, 2006 | 05:05 AM
obehave's Avatar
obehave
hope this helped
Well since you asked.
1. Atrocious spelling
2. You really shouldn't "steal" braided hose it's against the law. (see #1)
3. How on earth can a hose "implode"? Collapse maybe but implode?
4. Normal "vacuum" hoses will work fine. Mine have for thousands of miles.
5. And since when does a supercharger create "vacuum"?
6. Don't get all angry because you asked
Old Jun 26, 2006 | 06:23 AM
Arly's Avatar
Arly
the OCC on the PCV side, which routes to the SC does make the OCC to collapse because that is how the system works when there is no can attached. The SC is sucking air from the topside through the PCV. I placed a pvc tube in it to prevent the can from collapsing into itself. ALTA offers a Stainless tube to address this issue. Jeff, from Perrin(Alta) suggested this as well as others who run the can from the pcv side.
ARLY
Old Jun 26, 2006 | 06:43 AM
Mr. Pep'r's Avatar
Mr. Pep'r
Easy there 'killer'!
Didn't someone ever tell you "if you have nothing nice to say, do not say anything at all"?
FWIW, superchargers do make vaccum....check out the boost gauge Mini offers, it has both +/- boost. Turbo chargers I believe do not produce vacuum, but then again I could be wrong.
Old Jun 26, 2006 | 07:26 AM
Malcon's Avatar
Malcon
oh so it really has nothing to do with the issue. your just being a smart ellic
great contribution.
anyway, the hose that came with the catch can was a cheap clear hose, and it would collapse (hey thanks for the spell check), im pretty sure it wasnt from the pvc blowing into it...
anyway i guess you dont have the same hose that came with my catch can, or for thousands of miles, yours has been worthless.
anyway lets put our CHILDISH behavior aside.
Old Jun 26, 2006 | 07:48 AM
Jdewey's Avatar
Jdewey
Positive Crankcase Ventiliation plumbing functions.
The hose TO the PCV (then to the manifold) is ALWAYS drawing air from inside the engine.
The hose from the Air intake to the engine is pulling in fresh air into the engine at low engine revs, but at high revs where there is some blow by it is VENTING crankcase fumes INTO the intake.
These lines should NEVER be teed together to the same catch can as that stops the circulation of fresh air through the engine. Crud that should be pulled out of the crankcase and burned (or caught in a catch can) stays in the oil, contaminating it, and requiring more frequent oil changes.
Depending on the amount of blow by your engine has, and the amount of time you spend at high revs, the "supply" tube may never show oil.
John
Old Jun 26, 2006 | 07:50 AM
obehave's Avatar
obehave
He asked. I said nothing until then.
Superchargers produce boost. It's what they do.
All engines produce vacuum, that is why that gauge shows vacuum.
Here's a primer for you
FYI a turbo is properly called a turbine driven supercharger.
If you want to be taken seriously, learn to spell and know what you're talking about when you make empirical statements like "superchargers do make vaccum....check out the boost gauge Mini offers, it has both +/- boost".
You're basing your argument on the picture of a gauge? There is no such thing as negative (-) boost and it's still spelled vacuum. The use of vacuum in this instance is actually a common usage misnomer. Vacuum is a state. What is actually being stated is pressure above and below atmospheric. Doesn't sound as cool or is it as easy to say as vacuum and boost.
This is going way OT so I'm done. No more wasting bandwidth for me.
Old Jun 26, 2006 | 08:41 AM
Mr. Pep'r's Avatar
Mr. Pep'r
Malcon was answering questions and you had to stick you nose into a thread because you had spelling issues. YOU HAD NOTHING CONSTRUCTIVE TO ADD!!! And now you have spelling issues with me.....so sorry I was the first to sit down durnig the spelling bees and do not meet you high standards!!!
Like you never had a typo!! So sorry for the two C's rather then two U's!!!
Go away you pompous @$$!
Old Jun 26, 2006 | 08:44 AM
Mr. Pep'r's Avatar
Mr. Pep'r
And one more thing, thanks for the lesson on how turbochargers and superchargers work....I do not know how I got my A&P never mind know how the airplanes I fly work without you!
Old Jun 26, 2006 | 08:47 AM
Mr. Pep'r's Avatar
Mr. Pep'r
great contribution.
Malcon, thank you for answering my questions in the earier posts.
