Drivetrain oil catch cans
Old Jul 5, 2006 | 07:07 PM
  #226
Malcon's Avatar
Malcon
im sorry obehave...your out. post all the smiley faces you want. but you got yourself on that one.
Old Jul 5, 2006 | 07:50 PM
  #227
pure&simple's Avatar
pure&simple
Originally Posted by DialM
Yes, I am saying that as the air is accelerated into the inlet from the atmosphere, the pressure must drop. I guess you could view it as "stretching" in that the gaps between molecules increases as those entering the inlet are accelerated away from those behind them.
Forget the static vs. dynamic pressure issue, as I can't recall enough to argue the point with certainty (that is why I wrote, "correct me if I am wrong").
I think that just before the supercharger, the air is less dense than atmospheric, but will be affected by stacking that may occur due to a roots supercharger taking somewhat discreet gulps, and other obstruction-related slowing. The air travelling down the inlet duct will be less dense than atmospheric. Pretend you have a line of MINIs doing a rolling start as they cross a starting line. This line of cars travels at five miles per hour until they cross the starting line, then, upon crossing the line each car accelerates to some higher speed. The line of MINIs began with a "density" of ten MINIs per 100 feet travelling at 5 MPH and ends up with a "density" of one MINI per 500 feet travelling at 50 MPH (numbers made up, not calculated, but you get the drift).
Your example makes perfect sense, and I'm sure there's something like that going on. Also, I would guess that it could be better explained by the static vs. dynamic pressure equations. The one thing I don't get is why the MAP sensor on a NA engine is reading atmospheric pressure at WOT. If the supercharger is making vacuum at the inlet, so should a NA engine, especially at WOT. Can you explain this, or offer some evidence supporting your assertion that a supercharger makes vacuum at its inlet?
Old Jul 5, 2006 | 08:03 PM
  #228
obehave's Avatar
obehave
Oh well. I'll live.
Just one more loser like you that I can ignore from here on out. No biggie.
I see you pussed out on the argument about superchargeres creating vacuum.
At least you were decent enough to bow down before your betters.
Old Jul 5, 2006 | 09:13 PM
  #229
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
OK, 229 posts and I *still* have this question:
I installed an M7 OCC as per the instructions, including capping the grey "vacuum" line from the SC. After 4 months there's not a drop of oil in the CC, so should I revert to stock? The OCC doesn't take up much room or present any real downside to under-bonnet access, but is it harmless? Some posts suggest that capping the grey line is *bad*.
Can we get some answers after 200+ posts?
thanks,
Old Jul 6, 2006 | 06:11 AM
  #230
Mr. Pep'r's Avatar
Mr. Pep'r
Originally Posted by obehave
Bernoulli's has little to do with the discussion about whether or not the supercharger develops measureable vacuum in the intake path of a MINI.
And it would be air over a curved surface. A flat surface would demontrate no pressure differential between upper and lower surfaces.
But hey, what do I know.
Helps a ton with carburetors though. And those in the air wingy things
Really, thanks for letting me know how Bernoulli's principle helps with the wingy things.
I really do not think they had wings to work with in 1782
http://home.earthlink.net/~mmc1919/venturi.html
****Bernoulli's principle states that in fluid flow, an increase in velocity occurs simultaneously with decrease in pressure. This principle is a simplification of Bernoulli's equation which states that the sum of all forms of energy in a fluid flowing along an enclosed path (a streamline) is the same at any two points in that path. It is named after the Dutch/Swiss mathematician/scientist Daniel Bernoulli, though it was previously understood by Leonhard Euler and others. In a fluid flow with no viscosity, and therefore one in which a pressure difference is the only accelerating force, it is equivalent to Newton's laws of motion. It is important to note that the only cause of the change in fluid velocity is the difference in pressures either side of it. It is very common for the Bernoulli effect to be quoted as if it states that a change in velocity causes a change in pressure. The Bernoulli principle does not make this statement and it is not the case.****
DialM was stating that as velocity increases pressure decreases and in a tube I think that is correct.
I see no wing or carb in the above picture.
Old Jul 6, 2006 | 06:23 AM
  #231
Mr. Pep'r's Avatar
Mr. Pep'r
I will say it again and what has me involved with this NEVER ENDING thread.......
TAKE IT EASY KILLER!!!! :impatient
Old Jul 6, 2006 | 10:35 AM
  #232
DialM's Avatar
DialM
Wow, who has been saying this all along? It is not like the atmosphere is pushing all that air into the supercharger.
Old Jul 6, 2006 | 11:53 AM
  #233
Malcon's Avatar
Malcon
Oh well. I'll live.
well check it out man.
i wasnt involved in the argument, all i was doing is explaining what the catch can did, and put some pics on the forum. your the one who really got involved with the vacume thing. i hate that fact that YOU of all people think im a loser because i really do care what you think...i really do.
oh and you better keep your promise about ignoring me!
(i thought name calling was for third graders...well i guess it still is.)
Old Jul 6, 2006 | 05:54 PM
  #234
pure&simple
Not time to declare victory quite yet. The issue was never whether or not there was a pressure differential. The issue was whether or not there was a measurable vacuum in the supercharger inlet. You seem to be choosing to ignore my question:
Old Jul 6, 2006 | 06:02 PM
  #235
obehave's Avatar
obehave
Not the first time that question has been ignored.
Old Jul 6, 2006 | 06:15 PM
  #236
DarkMiniCooperS's Avatar
DarkMiniCooperS
obehave,
Don't waste your time with those stupid e-wars... I'll always respected you and I know that you're a MINI king.
btw, I've seen your races movies and I must admit that you know how to drive! Awesome driving skills and knowledge.
Let the kids in their playground and don't waste your keyboard's keys on them.
My 2cents...
Now, back to the topic, does anyone has a detailed (with pics) how-to on installing an OCC ?
Old Jul 6, 2006 | 06:43 PM
  #237
obehave's Avatar
obehave
Originally Posted by DarkMiniCooperS
obehave,
My 2cents...
You know. You're right.
Which OCC and where do you want to install it?
Here's a link to how I mounted mine. There were some issues I corrected with the mod I did but I like the location. It sets below the valve cover vent so any drain back is eliminated.
For now mine is single sided and returns to the gray line that is being debated here. Based on some of the, on topic, questions raised in this thread I'm going to revisit the routing. My OCC does trap oil but I have also found that some still collects in the IC. For one reason or another I have the IC off at least twice a year so keeping it clean isn't an issue.
I do want ot see if I can get the OCC to do a better job.
It's a GT Tuning piece BTW. Very nice. Not cheap but it was a tax return gimme from a couple years back.
If you get no good responses feel free to PM me and I'll do what I can.
Old Jul 6, 2006 | 07:08 PM
  #238
DarkMiniCooperS
Thanks a lot Obehave!!
but you forgot to include the link lol
Old Jul 6, 2006 | 07:38 PM
  #239
obehave's Avatar
obehave
It's all in the details isn't it?
Try this one
Old Jul 6, 2006 | 07:54 PM
  #240
Malcon's Avatar
Malcon
obehave,
My 2cents...
hey MIAMI, your on sunshine mini's?
come down to the tower shops fri.
Old Jul 6, 2006 | 09:38 PM
  #241
Revolver's Avatar
Revolver
Checkit, sum fings mus be said innit.
Now, we talkin about...techmology, what is that all about?
Fo real, respek.
Old Jul 6, 2006 | 09:43 PM
  #242
ScottinBend's Avatar
ScottinBend
You can see my install in my gallery.
Old Jul 6, 2006 | 09:44 PM
  #243
ScottinBend
Fo real, respek.
Attachment 13706
Huh?
Old Jul 6, 2006 | 11:07 PM
  #244
ingsoc's Avatar
ingsoc
Originally Posted by ScottinBend
Huh?
That's how Ali G (the guy pictured) speaks... Why it's spelled that way on a MINI forum...well...
Old Jul 7, 2006 | 06:19 AM
  #245
Mr. Pep'r's Avatar
Mr. Pep'r
obehave,
My 2cents...
Dude, he WAS THE ONE WHO STARTED THIS "stupid e-war".
Someone pissed in his Cheerios and he was the one who started the belittling about spelling and supercharger knowledge. Also if you look back at page one I was the one who was most interested about the OCC and how Arly installed them, brother I was wanting to learn.
Then he had to be a complete **** towrads Malcom....who I do not know. This is how this thread got to this point. So go back and read ALL the pages your hero wrote.
Also I am glad you put obehave on a pedestal and just by the tone of his postings that is just what he needs. I do not care if someone is the best driver, mechanic, or whatever in the world....if you show no respect towrads others, belittle, and have zero humbleness that person is crAAp in my book and I will have zero respect for him/her!
WHY the mods have not shut this thread down is beyond me!!! It is so far off-topic and some threads are just down right badgering.......yes and like mine.
Old Jul 7, 2006 | 07:07 AM
  #246
dave's Avatar
dave
pug poo picker-upper
TBRoye
Feb 14, 2021 05:16 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
stellaherself
Aug 13, 2015 03:48 PM
M7Speed
Aug 6, 2015 01:48 PM
