Drivetrain Short shifter... ANYONE??
Old May 29, 2006 | 07:18 PM
  #51
MSFITOY's Avatar
MSFITOY
Originally Posted by Jray
Does anybody have an opinion on the Mini-Madness short shifter? I won one at the dragon that I haven't done anything with yet. I had never planned to do this mod and I'm not mechanically inclined so I'm not going to try this myself. Is it worth paying someone to install it for me? From reading the instructions it seems fairly complicated, even though the whole thing is only a short (3-4") shaft and a few set screws.
The MiniMadness short shift kit is the same Rogue kit that I have and of course I like it...I still have it...but not for long
Old May 29, 2006 | 07:41 PM
  #52
Wake|MCS's Avatar
Wake|MCS
Isn't this the way everybody shifts already? If I'm reading this right you mean to basically grab the shift **** with your hand which makes your thumb point down. The other way is with your hand palm up and thumb pointed at the ceiling? Who does that?
No, I don't think your understanding me. . . I'll take pics tomorrow and post so you can understand what I'm saying. Everyone doesn't shift this way already . . .
Old May 29, 2006 | 08:23 PM
  #53
Gerldoc's Avatar
Gerldoc
Unless I am mistaken, what 02///MCS is referring to is the manner of shifting where your palm is on the driver's side of the **** - as opposed to on the top of the ****. Having one's palm cupped against the driver's side of the **** forces the thumb to be pointing directly down at the shift boot. This hand position exerts more pressure towards the passenger side of the car when shifting, hence makes the shift from 5th to 6th more of a sure thing...
BTW, this is what Bob Bondurant recommends for shifting technique. For shifting from 1st - 2nd, and 3rd - 4th, he recommends cupping the palm over the top of the shifter ****, gently, as if it were fragile like an egg, with the fingers pointing down along the metal part of the shifter, and then gently pulling straight back, easing it into gear. He states that it is important for that millisecond pause in the neutral gate. Hard, rough shifts add to the wear on the shifiter/tranny and are more likely to cause one to grind gears. By using this technique, shifting into the proper gear is more assured - at least I have found things to be that way.
Old May 30, 2006 | 09:54 AM
  #54
Jray's Avatar
Jray
OK, now I get it. That's clear. Incidentally, that's the way I usually shift from 5th to 6th just because I've found it works best that way for me... never had anyone tell me to do it that way. I guess I was thrown off by the mention of thumb pointing at the headliner.
Old May 30, 2006 | 04:54 PM
  #55
Spikedacrzyman's Avatar
Spikedacrzyman
When is this coming out and who's going to be selling it if you don't mind me asking..... Thanks Spike
Old May 31, 2006 | 05:17 PM
  #56
bee1000n's Avatar
bee1000n
Lots of discussion about everything except for cost! What does it cost to get one of these kits installed?
Old May 31, 2006 | 05:38 PM
  #57
CustomAV's Avatar
CustomAV
It is a bit of work. I am about to do it soon but am waiting for my new exhaust to arrive so I don't have to do it twice.
You need to drop a section of the exhaust to reach the box to change out the shifter.
I'm not sure of the time but I think it is a good 3-6 hour job but could be very wrong.... Granted I don't know what it would cost to have done as I prefer to be adventerous and learn on my own
Old May 31, 2006 | 06:04 PM
  #58
Dr Obnxs's Avatar
Dr Obnxs
Which?
If you're asking about the Craven/Webb unit, it's available now.....
Matt
Old May 31, 2006 | 06:42 PM
  #59
MSFITOY's Avatar
MSFITOY
Originally Posted by MSFITOY
You didn't hear this from me but...a very interesting new shifter design will be introduced in the near future...This is not just another shaft replacement kit...looks to be a whole new shifter assembly with exposed mechanisms and **** closer to the steering wheel...
Quoting myself Hardly got a blink on this exclusive...oh well...see it in my gallery some other time...
Old May 31, 2006 | 07:21 PM
  #60
onasled's Avatar
onasled
... I know about it... Look forward to seeing it soon.
We are building a trick shifter for the race car, amoung some other cool stuff. Hope to be able to show it off in a couple of months.
Old May 31, 2006 | 07:26 PM
  #61
MSFITOY's Avatar
MSFITOY
Me too...I hope
Old May 31, 2006 | 07:47 PM
  #62
obehave's Avatar
obehave
Sorry, I work in IT and hints and vaporware puts me into an instant coma
Just kidding though. About 2 years ago I tried to get interest in a redesigned shifter tower or spacer to raise the shfter height and yet keep the short stroke. Ala WRC.
No interest from anyone. Of course now someone will come out with one and it'll cost me $350.
Old May 31, 2006 | 08:19 PM
  #63
CustomAV's Avatar
CustomAV
Matt
this is the one I have... won it at the dragon so I figure it is worth a try. Worse case scenario it gives me a chance to learn the install process so I can try something different when it comes out....
Old Jun 1, 2006 | 04:48 AM
  #64
MSFITOY's Avatar
MSFITOY
Oh this is no vaporware...trust me...I have the math data
Old Jun 1, 2006 | 05:06 AM
  #65
CustomAV's Avatar
CustomAV
If its what I think it is I have the tech drawing of it so I second the no vaporware statement
Old Jun 1, 2006 | 05:20 AM
  #66
obehave's Avatar
obehave
Lift up the skirt and let us see the ankles or just stop teasing
Old Jun 1, 2006 | 08:30 AM
  #67
Dr Obnxs's Avatar
Dr Obnxs
If you stop at just the ankles...
I'm not interested. Bring on the fur!
Matt
Old Jun 1, 2006 | 08:51 AM
  #68
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I had a B&M short shift kit installed that cost me ~$500. Which is about par considering it did take quite a while to get installed, probably on the order of 3 hours.
Old Jun 1, 2006 | 11:33 AM
  #69
obehave's Avatar
obehave
Took me a couple hours.
I also took the time to polish the pivot *****. They do/used to ship with a machined surface. 600 and then 1000 grit did a nice job.
Old Jun 1, 2006 | 12:59 PM
  #70
MSFITOY's Avatar
MSFITOY
Matt
IBTL
Old Jun 1, 2006 | 01:03 PM
  #71
discodan's Avatar
discodan
ok msfitoy, i give!! uncle, uncle. please give me another option for me to ponder. this is a mod i wanted to do before the end of the summer so should i wait? or go with the Craven/Webb?
Old Jun 1, 2006 | 01:18 PM
  #72
MSFITOY's Avatar
MSFITOY
I think it should be out by then but I'll check and get back to you...I'm just saying that for those of you considering shifter options, there is a very inovative and functional design out on the horizon...It has been designed (I have actual CAD data in hand) and probably will be prototyped very soon...maybe this interest will put a fire under the producers butt I'm pretty certain Onasled will have it in his race car and hopefully me second
Old Jun 2, 2006 | 05:19 AM
  #73
sdv515's Avatar
sdv515
i was originally goiing to do the webb shifter but now that you have put forth another option i guess i'll wait a little bit.
Old Jun 2, 2006 | 05:51 AM
  #74
obehave's Avatar
obehave
Click....tick...tick...tick....
aaaaaand the "I'm sick of waiting, I'm going elsewhere" countdown begins
Old Jun 3, 2006 | 01:38 PM
  #75
sdv515's Avatar
sdv515
i'm sick of waiting, i'm going elsewhere
Doc Pain
Mar 10, 2021 04:50 AM
minimofo
Dec 26, 2015 12:03 PM
02miniSguy
Nov 17, 2015 10:29 PM
ToroPerro
Oct 1, 2015 12:54 PM
Samhillrocks
Sep 29, 2015 12:55 PM
