Drivetrain Short shifter... ANYONE??
Old May 25, 2006 | 02:36 PM
  #26
Gr8Force's Avatar
Gr8Force
Originally Posted by DrDiff
It seems that there are two different mods that we are confusing...
Shortening the height of the shift ****.
Shortening the throw distance between gears.
I guess I am interested in a Short THROW shifter.
'Zactly! I want a short THROW but I could go for making the height of the shift **** even higher than stock for ease of reach purposes. Any out there like that? None that I've seen.
Old May 25, 2006 | 02:51 PM
  #27
The MINITOR's Avatar
The MINITOR
I have the ProMINI and have no complaints.
Old May 25, 2006 | 04:46 PM
  #28
onasled's Avatar
onasled
I make these extensions for the Alta. Sold a few here on NAM, but not sure about how they like them. I couldn't do without mine.
I set the Alta as low as it could go, just before it scrapes the exhaust heat shield. That's how this on in the picture is set up. The extension brings the shifter up close to the wheel.
Video clip on the track, shows how well it shifts.
http://videos.streetfire.net/video/B...E73C025753.htm
Old May 25, 2006 | 07:10 PM
  #29
Wake|MCS's Avatar
Wake|MCS
WOW, your a quick shifter! Seems as the Alta is smooth. Your extension moves the shiftknob to the left and up some correct?
Old May 25, 2006 | 07:17 PM
  #30
onasled's Avatar
onasled
Up for sure. And yes, I have it toward the wheel, but that is done just by twisting the Alta shifter in that direction as it has a bend in it and can swivel 360 degrees. So you can really place that shift **** wherever you like.
Old May 25, 2006 | 07:25 PM
  #31
MSFITOY's Avatar
MSFITOY
and I still have the lowly Rogue SSK But it works for me...25% reduction keep me from the dreaded 3rd to 2nd 10,000rpm mistake
Old May 25, 2006 | 07:54 PM
  #32
Wake|MCS's Avatar
Wake|MCS
I have the Rogue SSK as well.. I think it's loose though, how do I check it? And I've still definitely done the dreaded 3rd to 2nd.. only I catch my mistake soon enough that the RPMs don't fly past high 7k... still scary, it's happened to me twice. But yeah, my short shifter seems very rough and as if it was loose.
Old May 25, 2006 | 11:13 PM
  #33
k-huevo's Avatar
k-huevo
Here’s a link to another short shifter discussion with a picture of my custom extension. https://www.northamericanmotoring.co...t=60745&page=2
Shifting action requires only placing the shifter in the correct position instead of a forceful shove like the stock shifter. Earlier models have sloppier shifters than later versions so there was a lot of room for improvement with mine. The short shifter still hasn’t eliminated missed shifts for me only reduced the occurrence and my trouble spot has always been 5th to 6th.
Old May 26, 2006 | 12:36 AM
  #34
AZMCS's Avatar
AZMCS
Originally Posted by Bilbo-Baggins
Do your research, ask the length of the lever inside the vehicle and compare it to the stock lever. If theirs is shorter it is not the best direction to go. During preformance driving you want your hands on the wheel as much as possible, not reaching for the shift ****. JOHO
IYHO of course.
I roll with the Webb.
snick-snick-snick
Old May 26, 2006 | 01:09 AM
  #35
Motor On's Avatar
Motor On
The two are interrelated as a result of the varitey in aftermarket kits and methods of shortening the throw; some models seem to also reduce the hieght of the **** in acheving this, which can be prohibitive in quicker shifts. I remember reading a post a few months ago where a short throw shifter was installed but because it lowered the ****, the owner fabricated an extension and managed to keep the stock **** but had it moved up much closer to the wheel.
Old May 26, 2006 | 03:23 AM
  #36
ZaneGrey's Avatar
ZaneGrey
Originally Posted by chrisneal
I had the B&M short shifter installed on my '03 MC. I loved it at first, but after about a year it became very hard to shift, so much so that I actually messed up my shoulder for a little while and had to bump the shifter over with my leg to get into reverse. I'm sticking with stock on my '05.
this has been my experience as well with B&M. Shifts to reverse,5th and sixth are noticeably harder and you really have to "want" them to happen.I'm not sure this was worth the time and energy (considering you have to drop the exhaust system to do the install and if you live in the Northeast and have salt issues, it can be a real pandora's box full of problems) Wish I had gone with a system that left the original height while providing shorter throw.Some have mentioned Whalen ***** to make the shifting easier, but quite frankly the thought of trying to deal with a metal shift **** on those subzero mornings isn't all that appealing.Having watched Randy do this install,I surely wouldn't recommend this to anyone without a lift.
Old May 26, 2006 | 05:54 AM
  #37
MSFITOY's Avatar
MSFITOY
You didn't hear this from me but...a very interesting new shifter design will be introduced in the near future...This is not just another shaft replacement kit...looks to be a whole new shifter assembly with exposed mechanisms and **** closer to the steering wheel...
Old May 26, 2006 | 11:35 AM
  #38
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
The problem is that the TUNER croud seems to think that the way to lower a car is to cut the springs and then they shorten the shifter with hack saws.
Old May 26, 2006 | 12:00 PM
  #39
kyriian's Avatar
kyriian
i have a pilo short shift kit... 40$ reduction.... and i love it... although i gotta say its hard to get into gear sometimes.... and have misshifted a few times (say wanted 5th in acceleration, but got stuck in 3rd)
Old May 26, 2006 | 12:30 PM
  #40
Gr8Force's Avatar
Gr8Force
If we didn't hear it from you then who?
Old May 26, 2006 | 12:53 PM
  #41
Motor On's Avatar
Motor On
Old May 26, 2006 | 12:54 PM
  #42
MSFITOY's Avatar
MSFITOY
The fly on the wall...
Old May 26, 2006 | 12:56 PM
  #43
defylogik's Avatar
defylogik
i really like my stock shift ****, fake leather and all, are there any shift kits that allow you to keep your stock ****?
Old May 26, 2006 | 01:11 PM
  #44
Gr8Force's Avatar
Gr8Force
Maybe that accounts for all those voices in my head.
Old May 26, 2006 | 06:26 PM
  #45
Wake|MCS's Avatar
Wake|MCS
Originally Posted by k-huevo
...my trouble spot has always been 5th to 6th.
When shifting from 5th to 6th try shifting with your hand upside down. I.E. your thumb pointing towards the shiftboot and not towards the headliner. This will eliminate your arms movement towards the left so you shouldn't mis-shift any more... Just a thought....
Old May 26, 2006 | 07:31 PM
  #46
kapps's Avatar
kapps
Yeah, that's how I do it. I've heard racers do that on any upshift to lower the chance of accidentally downshifting.
Old May 26, 2006 | 08:35 PM
  #47
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
The B&M uses a stock **** right out of the box.
The Alta requires you to buy an adapter.
The Rogue one does (because it doesn't replace the shaft).
Old May 28, 2006 | 12:53 AM
  #48
christychillired's Avatar
christychillired
Another consideration is if decide on the B&M or Proimini kit is the exhaust system. It only clears the OE cooper, cooper s and from what I've seen on the net the Borla street exhaust. Many aftermarket including our factory JCW exhaust has a resonator directly under the shifter which will touch the deeper shifter box provided. To keep our short shifter I had a muffler shop cut out the large diam. resonator and put in a small cross-section unit. It is louder but sounds good. Now it sounds like a deeper version of the Leitriz exhaust systems on the early 80's VW Gti's if you know what that sounds like but louder
Old May 29, 2006 | 07:13 PM
  #49
Jray's Avatar
Jray
Does anybody have an opinion on the Mini-Madness short shifter? I won one at the dragon that I haven't done anything with yet. I had never planned to do this mod and I'm not mechanically inclined so I'm not going to try this myself. Is it worth paying someone to install it for me? From reading the instructions it seems fairly complicated, even though the whole thing is only a short (3-4") shaft and a few set screws.
Old May 29, 2006 | 07:16 PM
  #50
Jray's Avatar
Jray
Isn't this the way everybody shifts already? If I'm reading this right you mean to basically grab the shift **** with your hand which makes your thumb point down. The other way is with your hand palm up and thumb pointed at the ceiling? Who does that?
