Drivetrain 15 to 19 without jacking up motor possible?
Old May 17, 2006 | 07:04 PM
rough68fish's Avatar
rough68fish
I currently have my 15% pulley on and it looks like there is space to loosen and remove the outer part to put on the 19% without loosening the mounts and jacking up the motor. Can anyone confirm that the bolts and pulley will slide out of there?
Old May 17, 2006 | 08:51 PM
MINIotaple's Avatar
MINIotaple
Since you have a helix, you can do it. I did it without jacking up the engine. It'll take a lot of patience though since there's very little room for your hands...
Old May 17, 2006 | 09:20 PM
SRTech's Avatar
SRTech
And no room to properly get a torque wrench in there.
Steve
Old May 17, 2006 | 10:33 PM
MSFIT's Avatar
MSFIT
Steve
german torque = good-n-tight
Old May 17, 2006 | 10:53 PM
MINIotaple's Avatar
MINIotaple
Steve
I suppose, but all the guys who want to switch to 15% for track and 19% for the road do it this way so... If it's good enough for them, it's good enough for me.
Old May 18, 2006 | 03:13 AM
rough68fish
Excellent. This weekends trip through the PA mountains should be alot of fun. I love it when the wife just keeps asking, "do you have to drive like this?"
Old May 18, 2006 | 06:44 AM
omascow's Avatar
omascow
I get that too! Except her line is, "I bet you wouldn't have to fill up your car as often if you didn't floor it all the time." I then respond with evil death glare.
Old May 18, 2006 | 08:08 AM
ted leist's Avatar
ted leist
How about, "I thought you said that this was an economy car, why do you
buy the most expensive grade of gas"?
Old May 18, 2006 | 08:14 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
If you remove the inner fender liner it helps, so you can see the belt to get it back on. Also if the pulley sticks to the shaft, insert 2 screws into the 2 threaded holes and it will push the pulley off the hub.
Old May 18, 2006 | 08:24 AM
MINIotaple's Avatar
MINIotaple
Is it possible to do without removing the inner fender well? I think he's going to have to remove the passenger front wheel and the wheel well before even starting to do it.
Old May 18, 2006 | 08:41 AM
th3118's Avatar
th3118
I've always removed my inner fender, it just makes it easier.
Also having a ratcheting tool like a Chapman helps.
Old May 18, 2006 | 09:51 AM
MINIotaple's Avatar
MINIotaple
... I used my hand... I didn't know they made such a thing...
Old May 19, 2006 | 07:45 AM
omascow's Avatar
omascow
I had my pulley installed at a shop because that install looked too intense for me to do on my own. But now that I know I can swap out my 17% without lifting the engine, maybe I'll have to upgrade down the road. My question is does the pulley center it's self when you tighten the bolts?
Old May 19, 2006 | 07:55 AM
Dr Obnxs's Avatar
Dr Obnxs
But lifting the motor is so easy...
why NOT do it? IT's a few bolts and a jack.... If it really is a fight to get everything done without lifting the motor, I don't know if it will be any faster to skip that step...
Matt
Filmy
15
Jun 6, 2023 06:27 AM
molala
Oct 2, 2015 01:53 PM
gmonde
Sep 28, 2015 05:22 PM
WayMotorWorks
Sep 16, 2015 08:45 AM
offroadratfabricator
Sep 6, 2015 09:54 AM
