Drivetrain 20hp?
Old Apr 26, 2006 | 06:38 PM
mcsdmn's Avatar
mcsdmn
20hp?
i am trying to get the most hp for the buck.....
without risking reliability.
mini mania advertises 20hp from their 15%
Old Apr 26, 2006 | 06:46 PM
ronburton's Avatar
ronburton
A 15% pulley is a 15% pulley as far as power to be gained. In other words all pulleys that are the same size give you the same power gain.Ron
Old Apr 26, 2006 | 06:47 PM
mcsdmn's Avatar
mcsdmn
but it does give you 20hp gain?
Old Apr 26, 2006 | 06:56 PM
qwertmonkey's Avatar
qwertmonkey
I'd say that a 15% would give you +/- 20 HP. Probably closer to 18. But, yes. This is the best bang for your buck.
Old Apr 26, 2006 | 06:57 PM
MINIotaple's Avatar
MINIotaple
Depends on the dyno you use I suppose. In Europe, you might be getting 30hp+. Don't worry about numbers, it's the best thing you can do for your MINI.
[edit] Are 15% pullies really created equally, WMS says theirs is the best. I don't really understand their explanation so...
Old Apr 26, 2006 | 07:06 PM
Scooby03's Avatar
Scooby03
15% pulley, alta intake, and borla sport, I got a gain of 22hp.
Old Apr 26, 2006 | 07:11 PM
mcsdmn's Avatar
mcsdmn
so its about 18. 2 more for alta. 2 for borla..... more or less?
at least in that combo.
Old Apr 26, 2006 | 07:12 PM
MSFIT's Avatar
MSFIT
19% will give you a lot more than 20hp.. :P
Old Apr 26, 2006 | 07:18 PM
mcsdmn's Avatar
mcsdmn
but i heard so much about over-reving and need for injectors.....and so on and so on
Old Apr 26, 2006 | 07:23 PM
MSFIT's Avatar
MSFIT
psh...i dont see anyone with 19% pulleys complaining about any problems whatsoever... at that your s/c is only rated for what...100k miles...with a 15% 85k miles...19% ~80K miles...
And you can get the jcw intake and injectors for like $450?? that with a 19%...you should be golden..
Old Apr 26, 2006 | 07:24 PM
camelpilot's Avatar
camelpilot
Randy Webb is having a pulley party in L.A. next weekend in Long Beach. Sign up for it here if you like.
400 bucks installed. (includes parts and labour, and a job that won't be a eff up.)
And yeah, you get about 20 horsepower from it.
Old Apr 26, 2006 | 07:31 PM
mcsdmn's Avatar
mcsdmn
may 5th weekend?
Old Apr 26, 2006 | 07:34 PM
camelpilot's Avatar
camelpilot
may 5th weekend?
Yeah.
Old Apr 26, 2006 | 07:47 PM
MINIotaple's Avatar
MINIotaple
Do the 19%. Look at my sig and save your money.
That aside, I dynoed mine and I didn't even hit 10hp with the 15% pulley so I must've dynoed it on a conservative dynojet... However, I did gain 20 hp or so at some points in the rev range, just not at the peak. The magic number is my torque though, I gained 18lb-ft at the peak.
Old Apr 26, 2006 | 07:49 PM
mcsdmn's Avatar
mcsdmn
man i cant make that weekend....
MINIotaple, i would just go all out but i am 17 and limited founds...... besides the way i drive i shouldn't have sooo much power on tap.......
Old Apr 26, 2006 | 08:19 PM
sprp85's Avatar
sprp85
do 17%... keep it in between. See what its like...
and btw, 20hp at the wheel?
Old Apr 26, 2006 | 08:22 PM
MSFIT's Avatar
MSFIT
Im 20...and spillman is 19...he has twincharge...
Old Apr 26, 2006 | 08:31 PM
MINIotaple's Avatar
MINIotaple
See, I'm the rational one of the group. I'm 21 and I'm nowhere near MSFIT or Spillman.
Do the 19% and then get the JCW injectors for $250, then save up for some software, GIAC, MTH, whatever. It's not that bad. You did get the MCS. Stop seeing your girlfriend or postpone getting a girlfriend and you'll find some newfound wealth.
Old Apr 26, 2006 | 08:42 PM
mcsdmn's Avatar
mcsdmn
hahaha i actually HAVE thought of that (the girlfriend thing) like i always say my MINI is more dependable anyway!
what about 17%, JCW injectors, and the MTH tuner file...... how much HP do you think that could get......might as well your only young once right?
Old Apr 26, 2006 | 08:45 PM
MINIotaple's Avatar
MINIotaple
No waffling. This country hates wafflers. "Better ten years as an eagle than a hundred years as a pigeon." (This is the way my 50-yr old co-worker rationalized buying a motorcycle without telling his wife) 19%, you might as well, you've already put in the extra money with the injectors. I would personally recommend GIAC if you have a dealer close, but MTH tuner is good too I suppose.
mcsdmn's Avatar
mcsdmn
sprp85, thats what mini mania advertises granted it would be a little modest seeing as they sell it.
Old Apr 26, 2006 | 08:50 PM
mcsdmn's Avatar
mcsdmn
i guess wouldn't want to be a waffler.......god i knew this was going to be a money pit but i can't say its not worth it
Old Apr 26, 2006 | 08:52 PM
Tüls's Avatar
Tüls
Turbius Maximus
I would say yes...but I never checked it with out the intake and exhaust
I gained a total of 26 WHP
I had BenFer Performance stage III intake, UUC Exhaust, 15% pully By Global Motor Werks
MINIotaple's Avatar
MINIotaple
It has to be okay when it feels so good. That said, I'm done after these next few mods. I need to start being rational.
You're young. I remember when I was in high school. I wouldn't eat lunch to save my lunch money so I could use it for spending money, but I also had girlfriends for all four years of high school. It's okay, I dated my fiance for two of those four years.
Old Apr 26, 2006 | 08:53 PM
sprp85's Avatar
sprp85
i see...
Well when you go 17%, u do not need the injectors.
Go 17%, HAI or CAI, and ECU.. like MTH, GIAC...
Turning 21 this November..
