Drivetrain safc
Old Apr 24, 2006 | 09:51 PM
trickedmotoring's Avatar
trickedmotoring
safc
so im looking to do some ecu tuning of some sort... I have read postes here and there on different forums... I would like to get the low down on the safc's. I hope for some that are using to chime in.
thanks, tim
Old Apr 24, 2006 | 10:05 PM
jm6001's Avatar
jm6001
I too am very interested. Can it be properly used by someone with a tutorial of some sort?
Thanks,
Jm
Old Apr 25, 2006 | 05:49 AM
Soul Coughing's Avatar
Soul Coughing
the AFC can be a good way of fine tuning your fueling. May it be just getting the last bit of power out of your car on the basic mods(pulley, exhaust, header etc..), or if you've added larger injectors and you have no way of gaining access to changing the mini code yourself. idealy you want to have it done at a dyno, basically because its in a controlled environment with no distractions from driving and doing the tuning yourself. Of course, you would want the dyno to have a technician knowledgeable on how to use the afc. You could do it yourself, you would just need a wideband reader to test your A/F ratios while you drive. You would basically do a 3rd or 4th gear pull from about 2000 rpms at WOT to redline and fine adjust the air fuel ratio to the ideal numbers on your WB. This is alot cheaper, but you run the risk, in your ignorance of tuning, to run ultra lean and do permanent damage to your motor.
In the next few months i will be adding a turbo to my car, which will facilitate larger injectors, for the money, the AFC is a combination which is hard to beat. You just need to treat the AFC with respect and know when its worth spending the money for a proper tune at a dyno. The AFC only does fueling so keep that in mind. I already have the GIAC, with the increased redline and better ignition profile, so the addition of better fueling will hopefully give me a tidy increase in power.
Old Apr 25, 2006 | 06:07 AM
MiniCooperMan37's Avatar
MiniCooperMan37
i have a SAFC, i had it fine tuned on the dyno and then i just let it sit in the glove box. its great though because it can be done right then and there, no waiting for some guy in germany to send you some files or whatever. Time on the dyno does cost money though.
Old Apr 25, 2006 | 10:12 AM
trickedmotoring
so using the safc and some other tune, like mth or giac will be the best way to go. Im just trying to find a safe ecu mod the can get the most power out safely.
thanks, tim
nicksmf
Nov 12, 2012 09:16 AM
Malcon
Sep 9, 2008 10:56 AM
SSMini
Electrical
Jun 26, 2007 01:45 PM
Minirowski
Dec 9, 2005 02:48 PM
