Drivetrain MTH SAFC II 380cc
Old Dec 9, 2005 | 11:12 AM
Minirowski's Avatar
Minirowski
MTH SAFC II 380cc
If I have MTH Tuner file on my car, am I gonna be able to use SAFC II with 380cc ?
If I use SAFC with MTH how many more ponnies will I gain?
Old Dec 9, 2005 | 12:42 PM
Minirowski's Avatar
Minirowski
I guess nobody has a clue.
Old Dec 9, 2005 | 01:01 PM
BMDoubleU's Avatar
BMDoubleU
forgive my ignorance.. what is SAFC?
Old Dec 9, 2005 | 01:07 PM
JeffS's Avatar
JeffS
Why would you use both? If the MTH map was correct, then you'd gain absolutely nothing with the SAFC. If you did gain anything with the SAFC, it just means that your MTH map is off.
Old Dec 9, 2005 | 01:13 PM
Minirowski's Avatar
Minirowski
I was searching thru forum and I found a someone mentioned SAFC II will give more horsepower with the 380cc JCW.
Old Dec 9, 2005 | 01:14 PM
Minirowski's Avatar
Minirowski
It's like Vtech controler piggyback to tune the Air Fuel ratio.
Old Dec 9, 2005 | 01:38 PM
Johan's Avatar
Johan
Try asking in the MTH Official Support forum. You may get more support there. -- Johan
Old Dec 9, 2005 | 01:40 PM
Dr Obnxs's Avatar
Dr Obnxs
It will with base, but not as much as from stock..
I was thinking about a combo like this. just get the base MTH for the DSC and red-line mods, and then tune A/F with the Apexi. But you should have a wideband on the car as well, otherwise you won't have a good way to tune mixtures.
Matt
Old Dec 9, 2005 | 02:18 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
The MTH chip alters the ignition timing, something that the SAFC does not.
Old Dec 9, 2005 | 02:48 PM
ingsoc's Avatar
ingsoc
Andy put it perfectly- AF/fuel trim is only half of the battle. You can and most [all?] softwares do alter ignition timing to optimize power extraction.
KinetechMW
Sep 10, 2015 03:12 PM
Manny_cooper
Sep 3, 2015 05:48 AM
Manny_cooper
Aug 31, 2015 05:04 PM
BluMiniMe
Apr 24, 2005 11:02 PM
