Drivetrain dyno'd my car
Old Apr 7, 2006 | 08:40 PM
RIPPER's Avatar
RIPPER
dyno'd my car
I dyno'd my mcs on tues at new german performance and it dyno'd 156whpat 6500 rpm's on the first run and 161 whp on the 2nd run at 6800 rpm's. I know that's on the high side but I did break it in as suggest in the (motomans method). NGP sent the dyno's to me through an email and the numbers were lower than what I saw on the dyno screen ,so I callled and asked them about it and they said that the program that converts the file to be emailed causes something called smoothing. they said that it might not pick up a spike of one or two hp an smooth it out to the clearest number it reads. I don't know if that's ******** or not ,but even with lower #'s it's still strong. I have the dyno's but I don't know how to post. If someone can post for me I wil send them in an email
Old Apr 7, 2006 | 08:54 PM
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
I'll be doing the same to merlin on the 15th April
Old Apr 7, 2006 | 09:13 PM
RIPPER's Avatar
RIPPER
my car has 2200 miles and is stock. I wanted to get a base line beforew I have a pully and intake installed next week. I will dyno again after that
Old Apr 7, 2006 | 09:21 PM
lhoboy's Avatar
lhoboy
I'm planning on doing the same with my stock JCW as soon as Eric gets the dyno fixed at Helix.
Old Apr 7, 2006 | 09:44 PM
TheWrks's Avatar
TheWrks
When you post a reply scrool down the page. you should see a botton "manage Attachments" click on that and attach the dyno file(same it to your hard drive first)
Scott
etalj's Avatar
etalj
nothing really unusual about dynoing a little high with our little cars. Most ppl agree that the 170bhp from BMW is just a little bit understated . 161whp is about 183bhp, and i've heard a lot of ppl saying that they reckoned that the real bhp figure is more like 180-185.....
Old Apr 8, 2006 | 08:47 AM
chows4us's Avatar
chows4us
Check out MINI2 ... someone claiming to have dyno 100s of stock MINIs say every car is different with a range of maybe 15 bhp between engines. For a $20K car, that is far more realistic.
On the other hand, Porsche ppl will claim that ALL, as in EVERY engine that leaves the factory will be 3 - 4 bhp greater than advertised ... then again they cost 4 times as much.
Old Apr 8, 2006 | 08:49 AM
dominicminicoopers's Avatar
dominicminicoopers
Are these #'s SAE corrected? How much smoothing has been applied? What manufacturer of dyno? These play an important factor in understanding the numbers.
Another critical issue is that your HP numbers should continue to increase all the way to redline. So the higher RPMs you go on the dyno, more than likely unless something is outta tune, the higher the HP you'll get. Best yet is to compare torque numbers over the entire RPM range between dyno runs. :-)
Old Apr 8, 2006 | 09:29 AM
Cooper_Si's Avatar
Cooper_Si
Heres my figures for, what was, my stock MCS, so the first post figures are amazing !! :D
Old Apr 8, 2006 | 11:45 AM
RIPPER's Avatar
RIPPER
it was a dynojet dyno and yes they are sae corrected. I tried to upload but the jegpeg is to big and I don't know how to reduce the size to be able to post
Old Apr 8, 2006 | 11:47 AM
RIPPER's Avatar
RIPPER
I just looked at the dyno's again and it say's SAE smoothing 5. not sure what that means?
Old Apr 8, 2006 | 08:35 PM
RIPPER's Avatar
RIPPER
I finally figured out how to get the dyno's on this site. they are in my gallery.
Old Apr 9, 2006 | 01:02 PM
RIPPER's Avatar
RIPPER
hey whatup? no one has any comments/suggestions/criticism on my dyno's.
Old Apr 10, 2006 | 08:42 PM
lhoboy's Avatar
lhoboy
The curve looks a bit ratty over 5000 rpm. If the MINI had points, I'd suggest replacing them or going to an electronic ignition. (Oh wait, this is a BMW MINI, not an Austin Healey). I've not seen a stock dyno curve before, so they may all be a bit rough over 5000. (or you might need new ignition wires)
Old Apr 10, 2006 | 08:55 PM
MINIotaple's Avatar
MINIotaple
Looks similar to mine. My guy just said that it was timing retard.
Old Apr 11, 2006 | 05:10 AM
mdsbrain's Avatar
mdsbrain
Yah mine is a bit too. But that would be due to alot of things.
Dyno runs. Green is @ about 30F with crank pulley and car was still pretty warm from the drive. Red and Blue are after the stock crank pulley reinstalled and Unichip was installed. To me the car feels smoother and just as stronge. I don’t notice the power drop and I think it was temp or due to the tranny for power flux. The crank pulley didn’t make that much more power. It was a stock size not oversized.
Dyno graph.
Video of dyno run
Old Apr 15, 2006 | 07:27 PM
TheWrks's Avatar
TheWrks
As promised https://www.northamericanmotoring.co...ad.php?t=66224
Old Apr 16, 2006 | 11:55 PM
Coop d'etat's Avatar
Coop d'etat
Porsche also does a bench break in for each of their engines...so there is no need for a break-in when you buy the car. I think part of the variation is due to the break in style, or variation of the suggested break in for the mini. I also did a "non-suggested" break in, and my car seems to pull very strong compared to other MCS's I've driven.
elightbo
Aug 17, 2015 01:50 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
PatrikKN
Aug 5, 2015 09:10 PM
sungjk
Aug 5, 2015 08:23 PM
