Drivetrain stuff it with what? (oil catch can)
Old Apr 4, 2006 | 08:17 PM
rrdusek's Avatar
rrdusek
i know alta has some kind of foam pellets to put inside their oil catch cans to help condense the vapors, and i know lots of you put steel wool inside for the same reason. what i don't know is can it be any kind of steel wool (without the soap ) and is there such a thing as stainless steel wool? how much should i put in there? (why do i feel stupid asking this?)
Old Apr 4, 2006 | 08:59 PM
lhoboy's Avatar
lhoboy
Yes, you can buy stainless steel wool. If not at the hardware store you can get it at an industrial supplier like Grainger.
Old Apr 5, 2006 | 04:41 AM
onasled's Avatar
onasled
Do NOT put steel wool in your OCC. It will rust very fast and disintegrate and possibly get pulled through the system.
Old Apr 5, 2006 | 04:50 AM
petecrosby's Avatar
petecrosby
Bronze wool might be a good option. You should be able to
find it at most hardware stores.
Old Apr 5, 2006 | 07:53 AM
Outbackbob's Avatar
Outbackbob
I didn't put anything in mine as the container is pretty large and I check it often.
If you have one with a small container and it fills fast then a little steel wool won't hurt.
About the steel wool rusting-Isn't the liquid condensed oil vapors? I have yet to see oil cause steel to rust. Stainless would be a better option though.
Old Apr 5, 2006 | 05:40 PM
rrdusek's Avatar
rrdusek
does anyone know of any alternatives to use? i definately don't want to take the chance of little pieces of steel getting into bad places. my guess is that there will be water vapor, or condensation as well as oil passing into the can.
Old Apr 5, 2006 | 05:52 PM
Outbackbob's Avatar
Outbackbob
Anything will just about do as long as it's a heavy medium that won't get sucked up the hose. I think the purpose is to soak up the liquid and break up a possible siphon.
Old Apr 5, 2006 | 05:56 PM
apexer's Avatar
apexer
I installed a baffle about 1 inch deep on the inside of the Alta top lid between the inlet and outlet holes. Just used a piece of aluminum, drilled and taped some small holes, screwed baffle to top. This makes any fluid (Oil or Condensation) drop into the CC rather than being drawn from the inlet hole directly to the outlet hole (they are very close together). Empty fairly often in winter due to condensation. Rarely have to empty in summer. Sure does keep the inside of my intercooler clean and dry
Old Apr 6, 2006 | 03:26 AM
lhoboy's Avatar
lhoboy
I would use stainless steel scouring pads available at the supermarket (not steel wool). Pieces of a scouring pad are far less likely to come loose and potentially get sucked into the breather tube when things cool down.
Old Apr 6, 2006 | 05:53 AM
rrdusek's Avatar
rrdusek
thank you all for your help and suggestions. i really appreciate everyone's input.
Old Apr 6, 2006 | 06:25 AM
petecrosby's Avatar
petecrosby
Which is why I suggested the bronze wool instead of steel wool.
Old Apr 6, 2006 | 07:54 AM
ScottinBend's Avatar
ScottinBend
Copper wool is another alternative. And I love the fact that you can empty the can with the view tube, don't have to yank it out to empty it.
TBRoye
Feb 14, 2021 05:16 AM
tacticalbacon02
Aug 22, 2015 06:05 PM
Chasp
Aug 22, 2015 01:27 PM
Aug 21, 2015 12:59 PM
M7Speed
Aug 6, 2015 01:48 PM
