Drivetrain 19%...Wow
Old Mar 20, 2006 | 06:45 AM
SilverBullet3687's Avatar
SilverBullet3687
19%...Wow
I just had Eric @ Helix install a 19% on Friday. Wow. THe car is much much much much faster, and a lot more fun. Very happy I did it.
However, the one downside is that my fuel consumption dipped to about 22.4 MPG from 24.... So I seem to be using a little more gas than I'd like, and I really didn't think about this before. So those of you out there, careful when you get the pulley if you can't afford the gas. Other than that, the car is amazing.
Old Mar 20, 2006 | 07:08 AM
qwertmonkey's Avatar
qwertmonkey
If you dont mind me asking, how much did the whole procedure cost? (Parts and instalation)
Old Mar 20, 2006 | 07:24 AM
saakey's Avatar
saakey
is that the only mod you've done to your car?
Old Mar 20, 2006 | 07:34 AM
mbcoops's Avatar
mbcoops
Congrats! What's next?
mb
Old Mar 20, 2006 | 09:31 AM
Krut's Avatar
Krut
if 19 percent pulley - i would expect bigger injectors, and remapped ECU software.. correct no?
Old Mar 20, 2006 | 10:28 AM
coopercrazy's Avatar
coopercrazy
Cool, another happy Helix customer. I'm looking forward to my visit.
Did you do any other mods?
You can see helix pricing on their website.
www.helix13.com
Old Mar 20, 2006 | 11:42 AM
SilverBullet3687
in response to the questions:
the pulley with a new belt was $410
it was my second mod, I also have an HAI...
eric is awesome, and helix is a great little shop. you also need to go to pat's for cheesesteaks.
what's next is a jcw shift **** and also maybe tints...what's needed is tires...
I will probably do an ecu flash when I have the cash... injectors I am skipping out on...
Old Mar 20, 2006 | 12:00 PM
coopercrazy
SB, i see you have a boost gauge, what psi before and after?
Old Mar 20, 2006 | 01:38 PM
SilverBullet3687
funny you should ask... I actually blew out the vacuum line on the way home... went from 9psi at redline stock to about 19 psi at 5.5k with a 19%
Old Mar 20, 2006 | 01:49 PM
coopercrazy
Thats some difference...
What do you mean you blew out the vacuum line?
Is that just the line for the mechanical gauge?
Don't make me nervous about my upcoming pully upgrade.
Old Mar 20, 2006 | 02:01 PM
Bahamabart's Avatar
Bahamabart
$410 - seems a little steep.
Old Mar 20, 2006 | 02:13 PM
Morales's Avatar
Morales
That's the installed price.
Old Mar 20, 2006 | 02:20 PM
SilverBullet3687
$410 is kinda high, but he was a professional and helped rotate my tires and gave me a new belt and decals... so it was worth it
don't be nervous about the upgrade, my gauge is fine now... don't be afraid to go to 5.5k and 6 k, that's where you're really gonna feel it if you wanna give it some juice
Old Mar 20, 2006 | 02:32 PM
MINIotaple's Avatar
MINIotaple
I've been averaging 20MPG before and after my 15% pulley.
Old Mar 20, 2006 | 02:45 PM
trackster's Avatar
trackster
10 lbs of added boost from a 19% pulley ? Thats a new worlds record
Old Mar 20, 2006 | 02:47 PM
not-so-rednwhitecooper
if it was at only 9psi stock, your car has a serious air leak somewhere. stock is around 10.5-11 psi
Old Mar 20, 2006 | 05:06 PM
coopercrazy
So it was just the guage? At first i thought something went wrong w/ the car, then i thot about it.
Old Mar 20, 2006 | 07:31 PM
SilverBullet3687
Oh yeah, just the gauge.....and Rick, Idk man, I just read what the gauge tells me....
Old Mar 20, 2006 | 09:17 PM
i push 10.5 stock, and now over 12 with my crank pulley.
your gauge isnt reading right or theres a problem with your car.
Old Mar 21, 2006 | 04:06 AM
ingsoc's Avatar
ingsoc
Be forewarned, larger injectors will probably make you take another hit in mileage. The software will absolutely need to be added at the same time, or else you'll be running really rich [gobs of extra fuel] most of the time. With properly leaned out software, you could get that mileage back [and maybe improve on it!], but that depends on how much work went into the software. I don't have much experience with the GIAC that helix sells, but I have heard good things about it's driveability. Good luck!
Old Mar 21, 2006 | 07:08 AM
Bahamabart's Avatar
Bahamabart
yes, I understand its installed. While prices may vary depending on where you live, I did a RDR pulley for 325.00 installed witha new belt (no decals however) .
Old Mar 21, 2006 | 08:42 AM
day96's Avatar
day96
if you are boosting 19 psi, i would believe your engine light on the tach should be turning on like crazy. my guess is that you are making around 17 psi or maybe a little more with a 19%. at 18 psi the light go on and the car go into limp mode.
Old Mar 21, 2006 | 01:15 PM
coopercrazy
So how much faster can the car be? Works fast? or faster?
My bmw 330i was 6.0 to 60... you think w/ a 19 you could be close to that?
Old Mar 21, 2006 | 04:21 PM
18psi only turns on the SES and the DSC lights, not limp
Old Mar 21, 2006 | 10:07 PM
etalj's Avatar
etalj
does boosting 18+psi turn on the ASC light ?
