Drivetrain Filter Shootout
Old Feb 21, 2003 | 12:48 PM
macncheese's Avatar
macncheese
We had some nice (relative to last week) weather here in NJ so I performed a little experiment today at lunch with some filters and my OBDII logger.
I ran the car at WOT from 2000 RPM up to redline in second gear, on the same road, in the same direction, from (approximately) the same starting point.
The filters were:
Stock Paper
2 stage Foam POD filter 2.5" x 6"
K&N Oval 4.25" x 7"
The filters were attached to the stock rubber intake tube via a short length of 2.5" exhaust pipe and a hose clamp. No heatshield was used in this test. I will post a heatshield version later next week, weather permitting.
Old Feb 22, 2003 | 11:21 PM
JellyBaby's Avatar
JellyBaby
Man, that is really great! I need to get that ODBII gadget. What city you in?
Old Feb 23, 2003 | 07:43 AM
dominicminicoopers's Avatar
dominicminicoopers
Is that one of those Car Chips I heard about on TechTV ?
Old Feb 23, 2003 | 09:25 AM
Sleepless's Avatar
Sleepless
Kinda odd that you are not seeing 11PSI at redline; that is where it should be.
Old Feb 23, 2003 | 11:22 AM
macncheese's Avatar
macncheese
Im in Point Pleasant Beach, NJ. The data logger is a lot of fun and you can learn a lot from it. Its similar to the CARCHIP thing but its alot nicer, i think the carchip samples once every 5 seconds and I'm sampling at 20 samples per second.
Cheese
Old Feb 23, 2003 | 11:46 AM
dominicminicoopers
You're right, the carChip product really lags on each read @ 5 seconds. Who makes the data logger that you're running that records every 1/20th of a second?
Old Feb 23, 2003 | 03:38 PM
macncheese's Avatar
macncheese
I'm currently logging with some Palm based software called Pocket Logger, and a cable provided by them. This is one of the few logging programs designed for performance, instead of diagnostics, so it optimizes the sample rate for each car. The limit of the cable is around 20...
Cheese
Old Feb 23, 2003 | 09:56 PM
Ryephile's Avatar
Ryephile
amazing graphs macncheese!
I wonder what other types of data you can log with your palm...could get interesting.
The K&N seems to have about a half PSI peak advantage; what does your butt-meter tell you in terms of power?
_________________
Wisdom is not a function of age, but a function of experience.
*Keeper of the CWFAC list*
Old Feb 24, 2003 | 05:37 AM
macncheese's Avatar
macncheese
speed, rpm, manifold pressure, IAT, throttle position, engine load, timing, coolant temp, O2 sensor 1 and O2 sensor 2. and I think thats it.
Cheese
Old Feb 24, 2003 | 06:04 AM
asodestrom's Avatar
asodestrom
>>Cheese
Cheese
What kind of palm device are you using? I just sold my 515 and upgraded to a tungsten and I see from pocketlogger.com that it doesn't support OS 5.0 yet.
Where is the plug-in in the MINI?
Do you have a car mount for your pda?
This sounds really cool!
Andy :smile:
Old Feb 24, 2003 | 06:37 AM
macncheese's Avatar
macncheese
Andy,
I picked up a VIIx from Office Depot for like 46 bucks, I use it just for datalogging (ok maybe a little bit of Palm SimCity :smile
The mini's plug is under the dash on the driver's side, to the left. There is a little cover you pop open and plug it in. I dont have a car mount, just the driver's side parcel shelf so I start my logging and place the palm on the shelf while' I'm zooming around.
Cheese
Old Feb 24, 2003 | 06:42 AM
asodestrom's Avatar
asodestrom
Thanks Cheese,
I could probably pick up an older palm device on ebay for next to nothing.
How did you make the chart?
Andy
Old Feb 24, 2003 | 06:48 AM
macncheese's Avatar
macncheese
I convert the pocket logger data to CSV data and import it into Microsoft Excel and graph away. Your best bet is to get a palm that has a syncing cable and not a cradle, unless you wanted to mount the cradle in your car somehow, which might be kinda neat or kinda cumbersome.... otherwise you'll have to buy a sync cable. good luck with it.
Cheese
Old Feb 24, 2003 | 02:32 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Cheese,
Could you e-mail me the specifics of where to get the logger?
Thanks,
Randy
randy@mini-motorsport.com
Old Feb 24, 2003 | 02:50 PM
asodestrom's Avatar
asodestrom
pocketlogger.com.
There is also another product called pdyno (http://www.pdyno.com), I am chekcing on them both.
Andy
vulkandino
Oct 31, 2015 08:29 PM
monkiboy
Oct 16, 2015 09:58 AM
simo711
Oct 8, 2015 07:07 PM
dutchhome
Sep 30, 2015 07:17 AM
Nicefeet
Sep 24, 2015 06:53 PM
