Drivetrain Milltek vs Invidia
Old Jan 31, 2006 | 09:28 PM
  #76
ScuderiaMini's Avatar
ScuderiaMini
ooops
Old Feb 1, 2006 | 05:33 PM
  #77
ScuderiaMini
here is couple of pics
Old Feb 1, 2006 | 08:01 PM
  #78
weezer2282's Avatar
weezer2282
Originally Posted by ScuderiaMini
That does look nice Berk.
Old Feb 1, 2006 | 08:18 PM
  #79
weezer2282's Avatar
weezer2282
Kellzir, I can't get the sound to work on your videos. I get something about a codec error that was used to compress the file isn't supported.
Old Feb 2, 2006 | 07:09 AM
  #80
pooch1's Avatar
pooch1
Looks good we got for hyper blue s convertible its as close a match in colour as you are going to get.
Old Feb 2, 2006 | 12:40 PM
  #81
MyPocketRocket's Avatar
MyPocketRocket
Originally Posted by discodan
hey MPR! did you get a new MINI. thanks for your Invidia! i vote for the Invidia as well by the way. quality of welds and overall construction are out of this world! installing mine in the spring.
Actually, my sister did get a new 2006 MCS. I'm on another project now...as you may see.
Here are some sound clips. This server is kindda slow. Download the movie before viewing is recommened.
Inside
outside
takeoff
Old Feb 2, 2006 | 05:02 PM
  #82
saifa's Avatar
saifa
I just got off the phone with someone at Invidia USA. Apparently the system is less than 2.5". Is stock not 2.25" ? Thats seems kind of price for the little size difference.
Anyone have any hard numbers of the Invidia. It's not listed in the "exhaust info sticky". I rally want this system but am still leaning towards the Magnaflow because of the power it gives over the other systems.
Old Feb 2, 2006 | 05:11 PM
  #83
saakey's Avatar
saakey
Inside
outside
takeoff
sound ...almost
Old Feb 3, 2006 | 08:45 AM
  #84
tennis_man's Avatar
tennis_man
The tubing size on the Invidia exhaust is 60mm which is 2.362 inches. I believe the stock tubing size is 57mm which translates to 2.244 inches.
Old Feb 3, 2006 | 09:49 AM
  #85
pooch1's Avatar
pooch1
Also you should consider the size of y pipe and the secondarys after the y.Most companys cut that down substantially to 1-3/4 or less.Noticed the Invidia retains good size secondarys.
Old Feb 3, 2006 | 05:51 PM
  #86
saifa's Avatar
saifa
So around $650USD for an increase of 0.118 in piping diameter? Also although quite lovely a system those bends restrict flow a little more than others.
The Milteck on the other hand is not quite as pretty design wise but because of that it should flow a little more. Of course it's flowing into 1 3/4 secondaries which kind of sucks.
My conclusion: For $650ish USD I want to see a little power plain and simple! I am going with the Magnaflow system! I will deal with a little more noise for the extra HP for my buck! Plus I just found out I can get it for $775CDN!
Thanks for the thread fellas! Helped make my mind up!
Seann
Old Feb 3, 2006 | 05:58 PM
  #87
Smokey's Avatar
Smokey
When it comes to $$$ vs. Horse Power all of the exhausts for the MINI's are a poor decision. What are folks seeing (not what the seller says) when it comes to HP gain?? Maybe 3?
I've got the invidia, bought mine for $425 new, picked it up for the tone and the look. Not the HP.
Old Feb 3, 2006 | 08:05 PM
  #88
saifa's Avatar
saifa
To each his own is the exhaust theory IMO.
I would not waste $600+ on "looks" considering the only thing you see are tips...unless you have a habit of crawling under peoples cars.
The Invidia system is bad *** for sure I wish someone had some dyno info. I just believe I would see more of a gain from the Magnaflow.
Old Feb 3, 2006 | 08:11 PM
  #89
ScuderiaMini
magnaflow makes more hp, maybe 2-3 more, but wayyyy tooo louder as well, and not a direct fitment on 05s-06s
Old Feb 3, 2006 | 08:17 PM
  #90
Smokey's Avatar
Smokey
Neither would I (see my post ref my cost), additionally you will note it's (looks) was #2 on my list.
As for the Magnaflow, I've heard it and it wasn't for me, certainly not worth the difference between what I paid and what they want for it. Even if you get 5 hp with it as I said making a HP argument when discussing exhuast on a MINI is foolish, there just isn't enough gain to justify the cost.
Good luck and you should really try looking under other folks cars! Never can tell what you might learn
Old Feb 3, 2006 | 08:20 PM
  #91
ScuderiaMini
hey Smokey, our mods look alike buddy good path
Old Feb 3, 2006 | 08:31 PM
  #92
Smokey's Avatar
Smokey
I hear Ya!
I've even changed my struts and springs but went with updated OEM, not that Big money H-Sport
When you say "blacked out" do you mean all the way, like this? Tints, bodyline or have you done more???? BTW, that's my son's car behind mine - nice color huh?
Old Feb 3, 2006 | 08:48 PM
  #93
trickedmotoring's Avatar
trickedmotoring
where did you pick them for that price.
Old Feb 3, 2006 | 09:21 PM
  #94
ScuderiaMini
check this one
I hear Ya!
Old Feb 4, 2006 | 04:28 AM
  #95
pooch1's Avatar
pooch1
I guess if all the systems put out 5-6 hp, the most economical decision with the best looks and sound would make sense.Besides that, its impossible to get the same car running at the same temp,humidity,altitude,dyno,etc to do a true before and after never mind a different car with different tuning.Any one going to dyno day can figure that out.In the end its a personnel decision,but the Invidia sure sounds good just look for the best deal.
Old Feb 4, 2006 | 06:05 AM
  #96
Smokey's Avatar
Smokey
I bought mine off of eBay from a seller down in Miami FL back on November 1st. I just did a search for this seller and can't find him anymore, I might not have his name correct, since all I have is a email address from my paypal account, but you're more then welcome to try. His contact info is bargainpartsbin@yahoo.com
Good luck, I still can't believe what happened on your last deal
Old Feb 4, 2006 | 06:07 AM
  #97
Smokey's Avatar
Smokey
check this one
ScuderiaMini, My brother from a different mother. Nice ride, although I like the other wheels on the car in your gallery
Old Feb 4, 2006 | 05:09 PM
  #98
WorldOnePerformance's Avatar
WorldOnePerformance
$425!!! How the heck did you get that!! I saw you got it on Ebay, but that is very strange due to the fact that we are in very deep with Invidia and that is WAY below cost! No joke fellas! I am happy for you if it is indeed Invidia and not a knockoff.
I also want to let you guys know that as much as I like the Invidia exhaust, there really isn't any catback that gives you incredible gains...
When you buy an Invidia, you should really be looking at about 8-10hp depending on other mods, the best engineering and construction and IMHO sound...nothing sounds quite like this
If you have any questions as I have said before please ask me and I will do my best to offer you a solid response, but I want you guys to know that I am here for you guys and it does me no good to sell you a product you will not be happy with as I want to retain your business for a future relationship! I do not sell anything I do not believe in
I also want to thank everyone that has replied to this thread as I really believe it is a very good quality thread with great suggestions and thoughts!
Jonathan W1
Old Feb 4, 2006 | 05:24 PM
  #99
ScuderiaMini
I am glad I listened to Jonathan, also wanted to try something else so it worked for me. the engineering of the catback is top notch
Old Feb 4, 2006 | 05:26 PM
  #100
ScuderiaMini
black ones or the OZs? i really liked the OZs, however, now getting another set of different rims, so will see
