Drivetrain 3% and 4% crank pulleys
Old Jan 5, 2006 | 07:09 PM
jbhashem's Avatar
jbhashem
Hi All,
I am going to get a lightweight crank pulley for my 03 MCS wth Alta 15% reduction already installed. Alta now makes 3% and 4% pulleys and wondering if I should consider one of these. I can't find any posts about these; only 0% and 2%.
My basic question is does this create the same load as a 19% (or 18%) reduction pulley or is it safer? I have been cautious about any loads above the 15% reduction pulley.
I am also in the process of MTH Cartuner file...yay!
John
Old Jan 6, 2006 | 08:00 AM
THE ITCH's Avatar
THE ITCH
Yes the 3% and 4% crank pulley will change the total of the sc reduction. I.E. adding the 3% crank pulley would be equal to 18% total. The difference being that you would not have the smaller radius of using an equivilent 18% sc pulley. That is a good thing and would make you belt last longer and have less chance for failure. You also get the benifit of less crankshaft pulley weight which should get you a slightly faster throttle responce. The downside is you will not have a crankshaft dampener. There has been many threads on this subject as to wether or not it is needed. So far as I know there have not been any failures directly linked to this mod. I hope this helps.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
VanisleRyan
Sep 30, 2015 08:35 PM
daviday
Sep 25, 2015 01:31 AM
