Drivetrain P1498
Old Dec 9, 2005 | 04:23 PM
Johan's Avatar
Johan
P1498
I'm getting this code after I installed a TB. I did a search and found that this has happend to another guy after installing a AGS. Usually just my EML light will pop on, but sometimes the check engine light too.
Here is the code: P1498 Manufacturer Controll Auxiliary emission Controls
Any Ideas? Thanks -- Johan
Old Dec 9, 2005 | 05:04 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
you have an air leak somewhere.
Old Dec 9, 2005 | 07:55 PM
ingsoc's Avatar
ingsoc
It's probably in the vacuum tube leading to your tb. Did you use a new clamp or did you try the old one or no one? Check the clamp on that line....
Old Dec 11, 2005 | 01:30 PM
Johan's Avatar
Johan
torque setting
Anyone know offhand the Torque setting on the 4 bolts holding the TB
Thanks -- Johan
Old Dec 11, 2005 | 01:41 PM
ingsoc's Avatar
ingsoc
Thanks -- Johan
You won't need it. It hardly moves. Just tighten them as much as you can, doing the screws diagonal each other in series once more after they seem to be tight.
Old Dec 11, 2005 | 01:53 PM
Johan's Avatar
Johan
Thanks for all the help but I keep getting the damn code and it's really starting to irritate me because I can't seem to fix it. I replaced the vacume line and put on new clamps. I do tighten the bolts in a cross pattern to get even torque, I was thinking mabye there weren't tight enough. I don't want to really wrench on them and break a bolt though. Again thanks for the support -- Johan
I'm starting to think that my car has a Gremlin living under the hood LOL
Old Dec 11, 2005 | 03:01 PM
BigBrownDog's Avatar
BigBrownDog
check this post from 1FSTMINI on another thread -
https://www.northamericanmotoring.co...0&postcount=17
Old Dec 11, 2005 | 03:08 PM
ingsoc's Avatar
ingsoc
Sorry to hear that this isn't fixed. Did you by any chance move the pre-SC tube much when you took off the TB? IF you did, you could get a leak right at the SC to tube interface, and that's a tight one to fix [you'd need to pull the radiator shroud forward and stuff, take off the tube [it's held on by one screw], and re-seat it]. That's a lot of work, but you could easily be getting the leak there. Sorry I don't have better news.
Anyone else have any ideas before he does this?
elcapitan
May 30, 2020 07:25 PM
1ofoneR52
Dec 20, 2014 08:04 AM
ccccPUNISHER
Feb 28, 2014 07:09 PM
bnferguson
May 20, 2013 11:29 AM
