Drivetrain 16% PULLEY & COLDER PLUGS?
Old Oct 31, 2005 | 06:55 AM
prolap's Avatar
prolap
Hello All!
Do you really need to change plugs when you install an aftermarket pulley?
What would happen I you do not go to colder plugs?
The cost of the plugs isn't that big of a deal, I just want to understand why
Old Oct 31, 2005 | 08:37 AM
eMINI's Avatar
eMINI
Colder plugs will be helpful to avoid detonation. You do want to switch to colder plugs.
Old Oct 31, 2005 | 05:44 PM
whovous's Avatar
whovous
It may not be a rush item to change em, but they definitely do make the engine smoother.
Old Oct 31, 2005 | 06:43 PM
DrkSilvrMini's Avatar
DrkSilvrMini
i dont think you need em at all, i mean u could change em if u wanted too. I have a 16% on my car and the car runs real good with out em. and the car see's redline daily .
Old Nov 1, 2005 | 08:45 AM
apexer's Avatar
apexer
I'm sure you know that the Mini ECU will automatically retard timing and dump more fuel if detonantion is detected. You won't really hear any detonation.
I'd bet your Mini will run even stronger @ higher RPMs with colder plugs
Old Nov 1, 2005 | 09:00 AM
NekoWoman's Avatar
NekoWoman
From: Fulltime RVer - R53 towed behind a vintage 1979 35' MCI MC-5C Saudi
Can somebody explain how you know which level of plug to pick? I've been reading plug sites and they vary, but most say you need at least +50hp in mods to need a colder range. I'm running a 15% pulley, BMP CAI and plan to do an exhaust. I'd say I'm approaching 20-25 extra hp... so why do I need colder plugs? I have a stock ECU running 39.
I haven't lost more than 1mpg since the pully & CAI.
I've just bought (not yet installed) some NGK iridiums... I figured a step up would help, but they are stock range, I believe.
Old Nov 1, 2005 | 09:18 AM
DrkSilvrMini
Oh i know its not detonating, im just saying that my car feels strong as it is with out the colder plugs. Maybe one day ill slap them in and see if it makes any difference.
Old Nov 1, 2005 | 12:27 PM
apexer's Avatar
apexer
My point is... It won't detonate... the ECU will see to that. You could, however, lose some hp is the ecu has to retard timing/dump fuel.
NekoWoman: Denzo or NGK Iriduims OK. I went with the Denzo 22's (see sig)
Old Nov 1, 2005 | 12:28 PM
eMINI's Avatar
eMINI
Ditto.
Ditto.
Old Nov 1, 2005 | 05:04 PM
Wake|MCS's Avatar
Wake|MCS
I'm going to take the plunge into an Alta 19% pulley within the next couple of weeks and I was wondering if I should delay installation until I buy colder plugs (IK22's) or just install the pulley and put the plugs in whenever I get them...
BTW, anyone know what the cheapest place to get the Denso IK22's is? Thanks
Old Nov 1, 2005 | 08:13 PM
apexer's Avatar
apexer
If your set on making the 19% jump, I would definately wait until I had the IK22s in hand so they could be installed at the same time as the pulley.
Old Nov 2, 2005 | 07:49 AM
NekoWoman's Avatar
NekoWoman
How long will it take the ECU to figure out the plugs have changed?
I always felt immediate differences after flashes and then after about 500 miles the car would settle back down (usually going back to old, bad habits like cold start or yo-yoing)
Old Nov 2, 2005 | 10:54 AM
apexer's Avatar
apexer
Actually, the ECU won't really know (or care) that the plugs have been changed. The only thing the ECU will know is the knock sensor is no longer telling it to take action for detonation.
Old Nov 2, 2005 | 12:09 PM
Coopernicus's Avatar
Coopernicus
Correct me if I am wrong, but doesn't the JCW Tuning Kit include colder plugs because it also includes a ~14% reduction pulley and bigger 380cc injectors?
Old Nov 2, 2005 | 02:34 PM
eMINI's Avatar
eMINI
That sounds right to me. I know the JCW cars do have different plugs than other MCS. It stands to reason that this could be the reason.
JCW owners?
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
Sep 4, 2015 03:56 PM
M7Speed
Sep 3, 2015 07:48 AM
