Drivetrain LSD - is it installed already?
Old Oct 3, 2005 | 04:58 PM
mattduncan's Avatar
mattduncan
Just got a 03 mcs. Is there a "for sure" way to know if a LSD has been installed on my car (besides rev/dump cluch)? I know the engine has had some mods, but I'm not sure about the differentials. thanks
Old Oct 3, 2005 | 05:05 PM
Steeroidz's Avatar
Steeroidz
Something like jack up the front of the car, put it in Neutral? or maybe it has to be in gear. And try spinning one of the front tires, and then something is supposed to happen, what that something is I don't remember =) Either the other wheel is supposed to turn the opposite way, not turn at all, or turn together with the wheel you're turning, I don't remember.
Old Oct 3, 2005 | 05:34 PM
mattduncan's Avatar
mattduncan
hehe. I think it doesn't matter what you have in the car on the "jack-up" test, I believe the tires will turn in opposite directions. Could be wrong though. Now you're gonna make me do MORE research...lol
Old Oct 3, 2005 | 07:56 PM
Paul Webster's Avatar
Paul Webster
Go to the parts department at your local dealership and give them your chassis number and they can print you out your build sheet.
That or turn off the asc and lay some rubber but you might be
Old Oct 3, 2005 | 09:09 PM
Bugs's Avatar
Bugs
Build sheet wouldnt tell you if one was added after the fact. Besides, he said its an 03. I thought LSD became an option for 04? I could be wrong on that though
Old Oct 3, 2005 | 09:18 PM
camelpilot's Avatar
camelpilot
The best way to tell is just drive it.
Like so:
Find a corner (or a parking lot), and travelling at around 20-30mph, turn the steering wheel slightly about 30-45 degrees, then gently hold the steering wheel at that position, and floor the gas pedal. If the car "digs in", i.e. starts to turn into the corner as if you turned the steering wheel, then you have LSD.
You can use LSD (via accelerator) to steer the car in corners, just fyi.
Keep in mind, your car never came with LSD, so if it does have it, someone had to add it.
Old Oct 3, 2005 | 09:43 PM
Gabe's Avatar
Gabe
LSD was/is only available from the factory from Jan. of 2005 production onward. You don't have factory LSD if you have an '03.
http://www.motoringfile.com/2004/12/...p_differential
http://www.motoringfile.com/2004/05/...s_2005_changes
Old Oct 3, 2005 | 09:44 PM
Hyper!!!Blue!!!'s Avatar
Hyper!!!Blue!!!
LSD is a factory option on 05 and up, not 04.
Old Oct 3, 2005 | 10:53 PM
early_apex
Do that on a gravel road. Get out and see if you made one track or two. Easy to do and easy on the car.
Old Oct 4, 2005 | 07:53 AM
camelpilot's Avatar
camelpilot
Not easy on the paintwork though.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
