Drivetrain 15psi boost guage with 16% pulley?
Old Sep 12, 2005 | 10:22 PM
VoiD's Avatar
VoiD
will 15 psi boost pressure gauge be enough for a 16% pulley?
How much boost does a 16% pulley run?
Old Sep 12, 2005 | 10:38 PM
M7's Avatar
M7
Hi there....
16% sounds familiar
This could possibly start another "how many PSI" do you get thread.
You will most likely see somewhere between 14.5-15psi no more, that's
meassured with a professional boost gauge that can be zeroed out to
compensate for altitude and temp. We also used a datalogger and did see
the same boost numbers.
If you use a gauge that will indicate 0-/+ 18 PSI, you should be fine.
peter
Team M7
562-608-8123
Old Sep 12, 2005 | 11:36 PM
mhhoff's Avatar
mhhoff
I agree with Peter. I have a 17% combination and rarely get over 16 PSI.
Old Sep 13, 2005 | 06:48 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Using a 15% pulley, I've seen over 15 psi using a "a professional boost gauge that can be zeroed out to compensate for altitude and temp and a datalogger and did see the same boost numbers."
Get a gauge that goes over 15 psi.
Old Sep 13, 2005 | 07:51 AM
norm03s's Avatar
norm03s
VoiD
Get a gauge that reads vacuum/boost -30 to +30 so you are reading mid scale, it will provide a more accurate reading. Go over to beneath the bonnet forum and check out the threads on vacuum gauges.
Old Sep 13, 2005 | 12:16 PM
VoiD's Avatar
VoiD
Thanks.
Old Sep 13, 2005 | 06:12 PM
inmimini's Avatar
inmimini
get a guage that goes over 15 psi.
Old Jul 2, 2012 | 03:55 PM
motorcrossxl's Avatar
motorcrossxl
i have a 02 r53 i make 15 psi boost no upgraded pulley is that stock psi what will a 15%make in boost or a 17% or even a 19% make in under boost will u make more boost with a 15% at low rpms ?? bc im so lost with a supercharger
Old Jul 2, 2012 | 04:08 PM
Mical's Avatar
Mical
Autometer #4308
Old Jul 5, 2012 | 07:33 AM
312griso8v's Avatar
312griso8v
ummm.....
yes, you'll make more boost at low rpm's because the supercharger is spinning faster with a smaller pulley. boost measurement is also going to depend on the engine load at any rpm.
hope this helps.
Old Jul 7, 2012 | 10:34 AM
NH_MCS's Avatar
NH_MCS
Doesn't sound like it's stock to me, 15psi of boost tells me it's already got a reduction pulley on the supercharger. Stock should be around 10psi give or take. Look on the left side of the motor for the serpentine belt, look at the color of the pulleys you see and report back.
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
Mb460
35
Sep 18, 2015 06:46 AM
Mb460
Sep 14, 2015 05:50 AM
Emnotek
Sep 11, 2015 04:16 PM
