Drivetrain Crank Pulley removal without holder tool
Old May 15, 2009 | 06:28 PM
Arly's Avatar
Arly
Has anyone removed the crank pulley without the holder tool? This is the tool that keeps the crank from turning. I have the rest of the BMW tools, but I do not have the holder tool. Will putting the car in Reverse and then apply the brakes with the ignition in the 2 pos(not start) work? I have read that when installing the harmonic balancer and bolt that you can put the car in 6th and apply the brakes while the ignition in 2 pos (not start).
Appreciate any good tips.
Thanks!
Old May 15, 2009 | 06:33 PM
onasled's Avatar
onasled
Not that I like using them, but an impact gun can usualy do it without the lever.
Old May 15, 2009 | 06:46 PM
Arly's Avatar
Arly
will using a impact gun damage the crank possibly?
Old May 15, 2009 | 06:47 PM
Arly's Avatar
Arly
I am planning on doing this tomorrow AM. I could make a holder from scratch, but I wanted to see if there are tricks out there.
Old May 15, 2009 | 07:42 PM
onasled's Avatar
onasled
I would imagine that anytime you don't use the right tools, you chance damage. As I said, I don't like using impact guns like this, but I've seen it done this way maybe twice, and it's worked with no damage
Old May 15, 2009 | 09:00 PM
k-huevo's Avatar
k-huevo
Remove the left wheel also, place a thick shaft screwdriver in the brake rotor vein of each side, use as a brake against the caliper, at the bottom for one way and at the top for the other.
Old May 16, 2009 | 04:05 AM
NoRe's Avatar
NoRe
I don't know if it is the same with mini's but in my previous car (mx-5),putting 5th gear in the gearbox stopped the crank from turning.At least that way i had replaced the crank pulley without any holder tool...
Old May 16, 2009 | 05:36 AM
Arly's Avatar
Arly
k-huevo,
Thanks! I assume that I place the car in 6th. Confirm please.
Old May 16, 2009 | 07:17 AM
k-huevo's Avatar
k-huevo
6th will be fine.
Old May 16, 2009 | 12:37 PM
soccerbummer1104's Avatar
soccerbummer1104
you could also try using a strap wrench instead of a crank holder. can be bought at lowes or the home depot.
Old May 16, 2009 | 07:52 PM
herbie hind's Avatar
herbie hind
i did the 5th gear with an asst. holding brakes .
Old May 16, 2009 | 09:24 PM
Arly's Avatar
Arly
I made my own holder tool using some scrap metal in my shop. Worked great. The only issue I had was a faulty BMW install tool. Gauled my 2005 crank pulley a bit, but I was able to use a hardened washer to space the install tool to finish the job. Mightmare. The tool is still workable, but I was really mad that the tool failed. I ended up using a hardened washer on the bolt to make sure I had a good surface on which the bolt could rest on. I used the screw driver in the brake veins method that worked awesome.
I measured the difference between the 02 and 05 crank pulleys. The 05 is 1 pound lighter. I will be testing using the but dyno and see if it make a difference. I will be posting the whole story in another thread.
Old Jun 1, 2009 | 07:41 AM
dannys's Avatar
dannys
Arley,
I need the puller & install tool, but can't find the BMW part numbers for these. Where did you get yours & do you know the BMW part numbers? BTW I've got a 2005 MCS.
Thanks!
Old Jun 7, 2009 | 12:42 PM
Daktaklakpak's Avatar
Daktaklakpak
This may sound like dumb question but is the bolt for crank pulley does it losen to the right or the left?
Old Jun 10, 2009 | 04:53 PM
madscientistr53's Avatar
madscientistr53
I just did the crank pulley swap with the minimals in tools.
I gunned the bolt out and was able to pull out the pulley with a cheap sears puller and the appropriate bolts for the pulley. Of course i cranked on the puller by hand its pretty easy to gouge the crank snout. to hold the crank in position I placed a screw driver in the vents of the brake rotor and let it rest against the caliper bracket. I used a towel between the to so as not to scratch the brackets paint. I also put the car in 6th gear. Make sure to chock the wheels securely!!!! To protect the cranks threads and provide a surface to push off of, I slipped a 1/4 ratchet extension into the crank. Its strong enough not to break and thin enough to fit into the hole and not damage the threads. I had one long enough to bottom out and just stick about 3/4 of an inch out of the crank.
Now, installing the pulley was another pain. At my local hardware store i was able to scrape up a metric bolt with the same thread and diameter of the crank bolt. It was the longest one they had at about 1 1/2 inches longer than the original. With daylight fading I went with it and a grade 8 washer to fit it. I lubed up the washer and after cleaning the new pulley and crank snout I drove the pulley on with the longer bolt and lubed washer by hand, slowly making sure not to bottom out the long bolt. I finished it with the original bolt then removed it to clean up the grease and check the pulley was fully seated then torqed on the bolt to spec. This of course with the screw driver in the rotor again.
Total cost of tools= $35
Plus $7 for the 6pack ;-)
Old Jul 7, 2012 | 01:08 PM
brettjameson's Avatar
brettjameson
Funny how it dudn't work for others
I had an assistant do exactly and we followed your instructions to the T, yet the crank still turns. Funny how many others say the exact thing as I am saying about your info being flawed.
Old Jul 7, 2012 | 01:12 PM
brettjameson
wow....couldn't have figured that out
Can't believe you would post such nonsense....
Old Jul 7, 2012 | 03:43 PM
Da_Ghost's Avatar
Da_Ghost
And I can't believe you're replying to someone who's banned (according to the little banned thing under his name)
As for the crank pulley, unless Minis have something special, an impact wrench can do the job, I always use one for crank pulleys and never had a single issue (both on my cars and on multiple customers cars)
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
mackedmini
Aug 20, 2015 02:35 AM
keck.j
Aug 18, 2015 08:18 PM
Lt. Dan
Aug 10, 2015 12:46 PM
