Drivetrain Short Shift Kit
Old Sep 12, 2005 | 04:13 PM
kapps's Avatar
kapps
Short Shift Kit
Hi all. I'd like to ask what my options are for a SS kit for my '02 MCS. I'm leaning towards the B&M or Alta...the ability to use a Whalen **** is a must. In reading another thread, it seems like onasled is able to make an extension for the Alta to give it a very short throw but at a nice height. Is this a feasible option for the street? Onasled, would I be able to use the Whalen with this adapter? Also, do the aluminum bushings on the B&M make a noticeable difference?
Any other comments would be greatly appreciated.
Old Sep 13, 2005 | 04:41 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
I have the Helix SS and love it. It maintains the shifter height, but make the shifts shorter and more crisp. It's less expensive than most. The only down side is that the heat shield need to be removed so the leather shifter boot tend to get pretty warm.
Old Sep 13, 2005 | 04:16 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I just installed the BMP/ProMINI SS. I think I like it. It will take the factory shift ****, so a Whalen should work fine. It also fits happily inside the shifter box, so you can use the factory dust cover and heat shields and not add any heat to the car.
Old Sep 13, 2005 | 04:36 PM
racinbmw's Avatar
racinbmw
Anybody know about the PILO racing SS? I mean for the money that thing looks like it is a replica of the B&M. But who cares it is cheap for a SS. ANy info regarding this one would be helpful too.
Old Sep 13, 2005 | 04:52 PM
kapps's Avatar
kapps
Agro, how does the height compare to stock on the Promini setup? I'm pretty tall so a low shift **** would not be a good for me. That's why I was interested in onasled's setup.
Old Sep 14, 2005 | 05:33 AM
garretwp's Avatar
garretwp
BM makes some great products. I would deff. look into one of there products. Cheap does not always mean its a great deal. There are a lot of posts on SSK. Look on the forums and see what others have suggested and or had success/problems with.
Garrett
Old Sep 14, 2005 | 08:58 AM
tennis_man's Avatar
tennis_man
Get the Alta short shifter. It is height adjustable and Whalen makes a **** to fit it.
Old Sep 14, 2005 | 02:53 PM
kapps's Avatar
kapps
I like the Alta but to get a good reduction, don't you have to lower the height?
Old Sep 14, 2005 | 03:52 PM
GRENDEL's Avatar
GRENDEL
I just had the Alta installed and I love it. I wish I would have done it earlier.
I have it set as low as it can go with the heat shield. I didn't think it would make much of a difference but it really does.
Old Sep 14, 2005 | 05:24 PM
early_apex
Alta adjustable for sure. To reduce the throw you lower the height of the ****. I think it looks better that way.
Old Sep 14, 2005 | 05:27 PM
not-so-rednwhitecooper
Fidanza makes a nice one! its polished with a screw on **** or you can use a stock ****.
cheap on ebay, 89 bucks or so.
Old Sep 14, 2005 | 06:54 PM
onasled's Avatar
onasled
The Alta is my choice as like others here, I like the adjustability. I also drop it to the heat shield but use my extension to bring the **** to a better location. This of course lengthens the throw but it works out great. Check my video on my sig and you can see it in action.
The Whalen **** can be made to fit this lever easily.
Old Sep 14, 2005 | 07:21 PM
kapps's Avatar
kapps
Wow onasled, that was another amazing video...s2000's give no respect . Your Alta SS with extension really looks sweet. What (if anything) has to be done to the extension for it work with the stock/Whalen ****?
(edit) also, how does the throw compare to stock? To me, the video makes it appear that the throw is just a little shorter than stock. Is this correct or is it just the angle of the camera?
Old Sep 14, 2005 | 10:20 PM
FUEGO's Avatar
FUEGO
Another great vid Onasled! Was the SS extension custom made, or off-the-shelf?
Old Sep 15, 2005 | 08:55 AM
Agro's Avatar
Agro
It's a little lower, but not a lot. Certainly less than in inch. I'm now pretty much used to it and it's been about 5 days.
Old Sep 16, 2005 | 01:27 PM
trickedmotoring's Avatar
trickedmotoring
great vid, but can the stock **** fit.
Old Sep 18, 2005 | 06:58 PM
KevinBaker's Avatar
KevinBaker
ALTA supply the SSK with either their own ****, or a screw on adapter that makes all stock ***** (including Whalens) fit perfectly. I'm using an Alta with a Whalen on my car.
Old Sep 18, 2005 | 11:25 PM
1nf3rn0's Avatar
1nf3rn0
How is the height? Like kapps, i am a tall person and i would like to have a longer shifter...
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
jziran
Aug 24, 2015 04:50 PM
