Drivetrain JCW Intake, How to check if my flap is opening?
Old Aug 26, 2005 | 09:13 AM
Abbett's Avatar
Abbett
I'm not sure if the cowl induction flap is opening on my JCW Intake. The intake/supercharger noise form my car builds steadily to redline but the volume does not suddenly increase at 4500rpm. Does the flap pop open or slowly open? What's the best/easiest way to check if it is opening?
Old Aug 26, 2005 | 09:28 AM
Tüls's Avatar
Tüls
Turbius Maximus
just get someone to rev to motor for you....with the bonnet open...and you just reach in where the opening is....you will feel the flap...it should be closed...then when your friend revs it make sure they go pas 5k and make sure they are reving it aggresively...you should feel it open right as you get to 4500
Old Aug 26, 2005 | 09:30 AM
Abbett's Avatar
Abbett
Thanks Tuls,
When you say reach in there, do you mean the cowl area or take the top off of the air box and reach in?
Edit: I've read this before but have been reluctant to free rev the engine that high. I now have over 2000 miles on it so I guess no harm will be done, although my old V8 hotrod buddies say that revving an engine with out a load is not good.
Old Aug 26, 2005 | 09:44 AM
kaelaria's Avatar
kaelaria
Your hotrod buddies are clueless.
Yes you reach in the cowl hole.
How did you attach the sending wire to the harness?
Old Aug 26, 2005 | 09:58 AM
lsd05jcw's Avatar
lsd05jcw
rev it
just have someone rev it for you, and carefully put your hand near the flap... you can feel flap open at about 4500.... The flap is electrical not based on load....
I ended up taking the flap out so air gets in there all the time...................
Old Aug 26, 2005 | 10:21 AM
Abbett's Avatar
Abbett
[QUOTE=kaelaria] How did you attach the sending wire to the harness? /QUOTE]
My intake was installed by my dealer before I took delivery of the car, as part of the complete engine tunning kit.
Old Aug 26, 2005 | 10:30 AM
kaelaria's Avatar
kaelaria
Then take it back - if you don't hear a loud distinct sound change above 4500, they missed something.
Old Aug 26, 2005 | 11:13 AM
red rage's Avatar
red rage
Actually, I think you have to be driving it to hear the Opening WHINE above 4500 rpm
Don't trust it in park, drive it and listen
Old Aug 26, 2005 | 11:38 AM
supersand's Avatar
supersand
I don't think you even need to have a hand down there to verify that it's opening up (with the bonnet open). Its gets pretty loud once the flap opens... I did a similar experiment (having a friend listen carefully) and sorta scared my him... as the sound is very noticable. Not completely sure but as I understand it the engine needs to be at a higher throttle angle to build up enough vaccuum to open the flap, but others here probably know more.
Erik
Old Aug 26, 2005 | 11:43 AM
Abbett's Avatar
Abbett
Hey Red, I've driven it to redline many times and listened with the windows down and the volume just seems to evenly grow as rpm's increase. I haven't tried sticking my hand in the cowl area while I'm driving though .
Thanks everyone who posted help, I'll check to see if my cowl flap is opening tonight.
Old Aug 26, 2005 | 11:50 AM
red rage's Avatar
red rage
Take it in, part of the wiring make be incomplete, works off vacuum hoses too.
Also, it has to be programmed with software flash too
Old Aug 26, 2005 | 12:01 PM
Tüls's Avatar
Tüls
Turbius Maximus
it does not need any software to function...I have installed one...worked jsut skippy with out any fancyness
Old Aug 26, 2005 | 12:21 PM
red rage's Avatar
red rage
Well, BMW dealership said it needed to be "programmed", maybe just BS
kaelaria's Avatar
kaelaria
You clearly don't have one and have no experience with one - why are you commenting like you have facts?
No you do not have to be driving to hear it - at ALL. No it does not take, nor is there any, special software for it.
Old Aug 26, 2005 | 12:35 PM
red rage's Avatar
red rage
Thanks for the support and understanding "K" , I do have one and chill out please
Old Aug 26, 2005 | 12:42 PM
meb's Avatar
meb
Mine hasn't opened since the install...the dealer cannot figure out why...going one last time. 29,000 miles since the install with a siezed(?) flap Time for an Alta!
Old Aug 26, 2005 | 01:03 PM
bonz's Avatar
bonz
I had a Rouge intake before I upgraded to the JCW intake. With a Rouge or any open intake you will hear the supercharger whine at all RPMS but with the JCW no whine until 4500 and you will definately hear that glorious noise eminating from under the bonnet. Sounds like Victory!!
Nice
Old Aug 26, 2005 | 01:24 PM
Green Giant's Avatar
Green Giant
Nice
yes, I concur. However, sometimes the noise on my car is more noticeable after 5,000 RPM.
Old Aug 26, 2005 | 01:29 PM
Tüls's Avatar
Tüls
Turbius Maximus
heh heh...yeees...hmmmn "programmed" mmmhmmmm cha ching!...well the other thing is most of the SAs do not know....they are simply doing a job which is cutomer service...alot of times they have no Idea what goes on in the back...as in...they dont' do the work...so...it's not thier fault...eh...
Old Aug 26, 2005 | 01:31 PM
lsd05jcw's Avatar
lsd05jcw
volume
Yes you can hear the increased whine, but in my opinion it is a modest increase in volume... I remember after hitting 1300 on my breakin period, I was so psyched to hear the increased sound.. couldn't really hear it and then had to check it by putting my hand near the flap.. yes it was opening.... As I said above, I removed the flap, and lower plugged intake.. which helps sound... I may actually change back to my turner/rouge/madness cai to compare and see which is better... i think the jcw may keep a cooler charge but wonder if it is really better than a alta or rouge with airbox mods.... Just some thoughts.... a dyno test would be great on this issue
Tüls's Avatar
Tüls
Turbius Maximus
meb...there are only four variables to the flap...vacume lines, ignition power, ground and 12 volt power
if they did it right it should work...if it doesn't it's broken...tell them to get you a new one...
annoying isn't it...
Old Aug 26, 2005 | 01:39 PM
kaelaria's Avatar
kaelaria
Wow then that's incredibly sad, that you can only give such wrong information.
Old Aug 26, 2005 | 02:21 PM
Col.Bobby's Avatar
Col.Bobby
Flap open - no whine
I had the JCW intake installed on my MCS by the dealer a few days ago. Of course I tried to hear the surge in decibels above 4500rpm. It didn't happen, or I am deaf. I figured, what the heck, the dealer certainly must know what he's doing... But reading your post and the simple "hands on" method of testing, I gave it a try. My "flap" works just fine, and there is no dramatic increase in the volume or character of the sound. Perhaps it will happen after I install the 15% pulley?
Old Aug 26, 2005 | 05:03 PM
kaelaria's Avatar
kaelaria
The pulley does make it louder, yes.
You can most easily hear the sound with the windows up, wide open, radio off. It's very obvious, gaining at least 100% volume.
Old Aug 27, 2005 | 06:33 PM
Green Giant
well, save your money on JCW cai dyno; according to factory, this airbox is suppose to generate 5hp. Other companies will boast various figures for their intakes, but I doubt any of them are any more credible than the good German (and some British) folks behind Mini. Just my $.02.:smile:
