Drivetrain Looking for intake suggestions...
I'm new to the Mini scene, or any sport car scene in fact. My previous cars were V6 Camaros, and because I was under 25, I didn't want to pay insane car insurance rates, nor tempt myself with a V8 or performance mods.
Now that I've got my MCS, one of the first things I want to do, is an intake upgrade. Down the line I may do the pulley, swaybar, ECU stuff... But for now I'd just like to get the intake out of the way.
I've seen a lot of people scooping up the JCW intakes by itself... Also seen a few people toting Alta intakes.
I can't seem to find a resource that provides comparisons of a few different intakes, and I've ran a search on these forums, and can't really come up with any real info on which intakes are preferable over others.
So if you guys could help out the new guy, and point out some good things to look for and maybe suggest some specific intakes, it would be greatly appreciated.
Good place to start.
Randy wrote a small review on each of the intakes he sells.
http://store.webbmotorsports.com/ind...x&cPath=16_3_5
If you love the sound of your supercharger's whine, and want much more of that whine, GET THE ALTA. I've heard no other intake can match the whine, except perhaps ProMini's.
I have the Alta, and recommend it highly! But then again, I love that jet engine whine!
If you want more power, but not as much whine, the JCW box might be better for you, versus an open design like the Alta.
I have the Alta and it makes the supercharger come alive
Well, if you love the Alta, but want your car to truly sound like a jet engine and to get better performance, get the M7 Air Gain System. You can even get a heatshield to project the noise more forward and make it more civilized. There are some threads with sound clips of the AGS in action. Take a look
https://www.northamericanmotoring.co...ad.php?t=43257 If you do drop triple digits on an intake, try this before your change and let me know what you think of the difference
-Jake
-Jake
-Jake
-Jake
Bodinski
-Jake
-Jake
I'm not a fan of the Alta's per say... I've just seen more of those 'in person' so far, than anything else. And I'm certainly not a fan of noise over power. If more noise comes with more power, sure... But I'm not looking to make it louder or whine more.
JCW is the quietest; even plugs the factory hole into the cowl so it may be quieter than stock below 4500rpm, and as loud as the others above that when the flap opens. Plug can be easily removed if it is too quiet for you.
Much like cat-back exhausts, there's not a lot of power differences and it comes down to which sound you prefer. But if you get the JCW upgrade kit they throw in 4 380cc injectors for just $75 more--a real money saver if you intend to go with 19% later.
It is just a circular piece of flat plastic that the rubber boot (which looks exactly the same as the one on the stock box) stretches over. You have to take the box bottom out of the car to reach it but it just "pops" out. Can be replaced if desired by snapping it back in.
Originally Posted by Wagnbat
So there's a JCW upgrade kit with the intake and spark plugs, which is (I assume) only availible from Mini dealerships?
Oh. To me it sounded like there was a kit with the intake and injectors which was cheaper and seperate than the 'complete' upgrade kit:
https://www.northamericanmotoring.co...ad.php?t=41935
On MiniUSA, after you build your own Mini, there is a JCW option, which has the JCW air filter seperate, but it's $450. Maybe this is what comes with the injectors?
Originally Posted by BFG9000
No, $450 MSRP is the airbox itself. The kit is $525 with injectors; part # 11 12 0 395 131. No spark plugs in it though.
I don't like the whine of the Alta intake. Seems like the JCW one should be very quiet. Does it make much power?
Originally Posted by matma92ser
Aren't the injectors alone usually around $400? If that is the case, the JCW intake is a bargain at $525-$400 = $125.
So would it be beneficial to grab the injectors too? I don't know the difference between JCW injectors and the MCS ones... But it does sound like it would have to be a dealership install.
If you like quiet then the JCW box is for you.
Sep 22, 2015 02:05 PM
