Drivetrain 2% crank + 15% vs 17%?
Old Jun 28, 2005 | 04:52 AM
skuzy's Avatar
skuzy
Hey all
which would be the better option?
1) 15%pulley with 2% crank; or
2) 17% pulley?>
Thanks.\
Old Jun 28, 2005 | 09:13 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
All other things being equal, you'll achieve the same level of boost with either one. Advantages of the 15+2 is you can use the stock belt, the overall tension seen on the belt is less than if you went with 17% (mechanical advantage plays in here) and the reduction of crank pulley weight allows for quicker throttle response. Disadvantages are the fact the jury seems to still be out regarding the long-term durability factors with lightened crank pulleys and the slight increase in drag by all the engine accessories being driven at a higher speed (the latter is negligible IMO).
Old Jun 28, 2005 | 09:19 AM
eMINI's Avatar
eMINI
Great question My plan is to someday augment my M7 -16% SC pulley with a Alta +3% Crank pulley to "equal" 19%. I'm in no hurry, waiting to get concrete answers about which approach puts more area "under the curve". I think Jeff @ Alta may have done some testing that would help with this, but I haven't taken time to follow up.
Old Jun 28, 2005 | 03:19 PM
skuzy's Avatar
skuzy
Ah - more or less thought so , but didnt know the reason why people wouldnt opt for the 2% crank pulley. but makes sense now - thanks!
Old Jun 28, 2005 | 04:44 PM
crazyaboutmini's Avatar
crazyaboutmini
i dunno about the lightened crank pulley because steve at dinan had an article that goes with greatbear's mention about the disadvantages. you can check it out at the dinan site under technical/forums if your pondering about it.
wildwestrider
11
Jan 29, 2016 05:06 PM
vulkandino
Oct 31, 2015 08:29 PM
dutchhome
Sep 30, 2015 07:17 AM
daviday
Sep 25, 2015 01:31 AM
Nicefeet
Sep 24, 2015 06:53 PM
