Drivetrain Engine swap...again: new Dodge 2.0
Old Jun 10, 2005 | 11:32 AM
  #26
jlm's Avatar
jlm
sign up at this site and check out the mini threads (my rig, mostly) and mostly under construction:
http://www.theoldone.com/forum/showthread.php?t=3237
Old Jun 10, 2005 | 02:41 PM
  #27
k-huevo's Avatar
k-huevo
As deerharb says, this block is heavy; 25 lbs. for the support ladder, 75.5 lbs. for the cylinder case and an additional 28 lbs. for the crank. I also have a block to give away. It only has two holes. To get an idea of shipping costs for the block only, from South Central Texas to say, Connecticut is $350. I agree the cooper rods may be a weak link.
Old Jun 10, 2005 | 03:17 PM
  #28
jlm's Avatar
jlm
that crank is pretty, eh?
Old Jun 11, 2005 | 07:41 AM
  #29
turbo740's Avatar
turbo740
Originally Posted by kcollins
...and you decided to simply press the AC button off. Interesting.
It's always fun when my 2 brain cells can hook up and chat for a little while
Actually, it was "wish power", not "brain power" that considered the swap. Too many other swaps in my life in "easy cars". But, as you can imagine, switching the A/C off every time I pull into traffic or climb a hill is fairly annoying.
Old Jun 23, 2005 | 08:20 PM
  #30
BFG9000's Avatar
BFG9000
Then why not wire up a disconnect so it shuts off automatically whenever the throttle is floored? Every motor home in the world with A/C already has this feature.
Old Jun 24, 2005 | 09:42 AM
  #31
turbo740's Avatar
turbo740
Hmmm...funny, but I don't "floor it" every time I start from a stop. I probably should, since I learned to drive in NJ, but it just never set in for me
Almost EVERY modern car has a WOT A/C interrupt, not just motorhomes. This will obviously not solve my particular concern. Thanks for the thought, though.
Old Jun 24, 2005 | 03:45 PM
  #32
BFG9000's Avatar
BFG9000
Originally Posted by turbo740
Yesterday I just switched off the A/C when pulling into traffic and entering my hilly neighborhood. Worked out pretty well...so mikem53's idea of altering my driving style worked after all
Then you need to alter your driving style in a different way, by stepping on the gas a little more so you don't have to shut off the A/C...
Old Jun 27, 2005 | 10:46 AM
  #33
turbo740's Avatar
turbo740
Obviously I know I could change my driving style...the point of my threads is to see where a few horsepower can be found down low. What's your major problem with trying to make the car a little better? If there was a way to get extra torque down low, i surely wouldn't be the only one interested? Did you design it? I'm not saying you're not right...I could drive it differently, but every post you make following mine is either sarcasm or doesn't address the issue. It gives some stupid little quip about your pro solution to change my driving style or forget about 10 extra hp. What's the deal?
Old Jun 27, 2005 | 01:58 PM
  #34
BFG9000's Avatar
BFG9000
Huh? Just trying to be helpful here. It wasn't clear at first that it was more part-throttle power you were after (esp with the dyno<2000rpm discussion), so my first suggestion wasn't too useful, sorry. But if you would be satisfied with just the power increase from having the A/C off and are irritated by having to turn it off, then the obvious solution would be to kill the A/C automatically. If you add your own cutout switch it wouldn't have to trip at WOT and you could put it say, at half throttle.
You got PM.
Old Jun 27, 2005 | 03:13 PM
  #35
dominicminicoopers's Avatar
dominicminicoopers
Troll alert! An old internet proverb says: Ignore the troll and it will go away...
Old Jun 27, 2005 | 03:34 PM
  #36
minimc's Avatar
minimc
I used to think Troll's only lived under bridges
Old Jun 27, 2005 | 03:58 PM
  #37
dominicminicoopers
me too
Old Jun 28, 2005 | 02:59 PM
  #38
turbo740's Avatar
turbo740
There are bridges in PA...
Old Jun 29, 2005 | 05:28 AM
  #39
turbo740's Avatar
turbo740
Well, I've apologized to BFG9000 for snapping for no apparent reason, and I've eaten crow and tried to change my driving style...moved my usual "launch RPM" up about a thousand. It's going to take some getting used to, me being a troll and all, but I think I'll get the hang of it.
I hope everyone can forgive me
Old Jun 29, 2005 | 09:37 PM
  #40
jon.k's Avatar
jon.k
stupid question - would a SRT-4 engine fit?
Old Jun 29, 2005 | 09:56 PM
  #41
myzamboni's Avatar
myzamboni
My Volvo interrupts well before WOT, so I think this is definitely something to look into.
Old Jun 29, 2005 | 11:33 PM
  #42
BFG9000's Avatar
BFG9000
https://www.northamericanmotoring.com/forums/showthread.php?t=33482
https://www.northamericanmotoring.com/forums/showthread.php?t=45294
Old Jul 29, 2005 | 01:39 AM
  #43
road_runner2's Avatar
road_runner2
Why not a diesel engine?
Just couldn't help posting my thoughts about your interesting project. Just out of curiosity, have you considered a diesel engine? You stated that you want ~135hp/215lb/ft tq.... sounds very much like a diesel configuration.
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
