Drivetrain Alta CAI question?
Old May 31, 2005 | 05:42 PM
asterix2112's Avatar
asterix2112
Alta CAI question?
All,
OK, Installed my Alta, but I am getting a wierd sound. No, I understand the supercharger sound, but this is a REALLY high pitched sound, almost like a high pitched whistle. I get it going into and coming out of the throttle, and while crusing, if I feather the throttle just right I can get it to keep going for a while. It really like nails on the chalkboard annoying, so much so that if this is normal I will remove the Alta CAI.
Is this normal, or does anyone have any ideas?
Thanks,
- John Connor
Old May 31, 2005 | 06:38 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The alta intake is often very very very oiled. In fact it's sometimes hard to install since the filter keeps slipping off.
Make sure that the filter is well seated and sealed. You can wipe off all oil from the ring it mounts to- that usually helps.
Check that all hoses are connected/reconnected. Check the seal on the silicon hose to the throttlebody.
Have someone sit in the driver's seat to hit the throttle, open the bonnet and stand in front of the MINI to listen for a source of the sound. Can you still hear it?
Old May 31, 2005 | 06:42 PM
Yellow_mini's Avatar
Yellow_mini
Mine also has a high pitched whistle sound. at about 4k-4500 rpm it sounds like a bird.
Old May 31, 2005 | 08:30 PM
rafthos's Avatar
rafthos
Yeah, I'm afraid the noise is pretty common.
https://www.northamericanmotoring.co...ght=Alta+noise
The good news is it doesn't take long to get used to the whistle. :smile:
Old Jun 1, 2005 | 08:12 AM
Pir8 97's Avatar
Pir8 97
My Alta is sitting on the shelf waiting for the install, so take this with a grain of salt. I have a similar sound that comes from the new intake on my Maxima... it's from the vacuum hoses. Man I love that sound
Old Jun 1, 2005 | 08:16 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
You can say that again.
Old Jun 1, 2005 | 08:57 AM
MyPocketRocket's Avatar
MyPocketRocket
Originally Posted by asterix2112
All,
Thanks,
- John Connor
That's normal.
Old Jun 1, 2005 | 10:18 AM
kenchan's Avatar
kenchan
Mine does it too. sounds like some toy car that needs oiling.
Old Jun 1, 2005 | 12:23 PM
asterix2112
Thanks all, and for the link to the other thread. At least now I know it's normal and there is nothing wrong with my car! I'm already getting used to it, and I usually drive with the radio on so I won't hear it as much.
- John
Old Jun 1, 2005 | 04:39 PM
vegasdan's Avatar
vegasdan
You are hearing the throttle body "whistle". It's normal and comes and goes according to throttle position, etc. You do not hear this until you do the Alta CAI, just as you do not hear the much more pronounced supercharger whine until after the mod. Be happy-don't worry.
Itsdchz's Avatar
Itsdchz
I now drive with the radio OFF, just to hear the sucking sound, S/C whine and high pitched whistle... Scares the carp out of the Honda drivers, they all think I have a S/C and a Turbo.....
Old Jun 4, 2005 | 02:16 PM
Yellow_mini
my friends started freaking out when i pulled up and revved my engines they also thought i had a turbo installed
Teh
Aug 22, 2022 04:37 AM
AWOL
Mar 28, 2016 10:51 AM
Mini7
Feb 2, 2016 07:52 PM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
