Drivetrain Can't get WOT reading
Old May 20, 2005 | 04:55 PM
spillman's Avatar
spillman
I have been using car chip recently for some data logging. It only records 90% throttle openings. The unit only records every 5 sec but I have been at wot for longer then this.
Does the unit just not reconize 100% throttle settings or am I having a big problem here.
I am currently using MTH software. I do believe he changes the Egas map... Well don't want to start any conspiracies... However whenever I recieve my ECU back from Helix (with GIAC) I will do some tests.
Does anyone on here use a car chip?
Ryan
Old May 20, 2005 | 04:58 PM
Cooper_Si's Avatar
Cooper_Si
i think if you search this subject you will get ure answer...as far as ive seen on here...you wont get 100% WOT
Old May 20, 2005 | 05:13 PM
spillman's Avatar
spillman
Did a couple of searches... Didn't find anything with much relevance. Perhaps you could point me in the right direction.
Old May 20, 2005 | 05:16 PM
minimonkey's Avatar
minimonkey
Ryan
I too have the Car Chip and also am running MTH. I would be curious to know what you find after going with GIAC. Thanks.
Old May 20, 2005 | 05:32 PM
Cooper_Si's Avatar
Cooper_Si
ive had a look but cant find it :(
Im sure one of the other techies here will let you know ASAP
Old May 21, 2005 | 06:02 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
The throttle body uses a pair of potentiometers to measure the angle of the throttle plate. This is a redundancy feature in case one potentiometer fails. There is a similar pair of pots in the accelerator pedal. Anyhoo, the deal with potentiometers is you shouldn't use the very lowest or highest areas of their range. Potentiometers become inaccurate at their extrema. So, the range from closed throttle to WOT may go from 12% to 88% or something like that. I would never expect to see 0% or 100%. The throttle is definitely fully open even when it's not "100%":
Old May 21, 2005 | 07:19 AM
Cooper_Si's Avatar
Cooper_Si
phew thanx for backing me up there
and what are them white wires/pipes u have andy ?
Old May 21, 2005 | 08:39 AM
spillman's Avatar
spillman
Ah! It's all so clear now. Thanks for the clear up andy.
Ryan
Old May 21, 2005 | 05:10 PM
jlm's Avatar
jlm
my rig, back in '03: those white wires are gone now
Old May 21, 2005 | 06:16 PM
minimonkey's Avatar
minimonkey
Does anyone know why the CarChip doesn't record or plot speeds over 90 MPH?
Old May 21, 2005 | 09:08 PM
spillman's Avatar
spillman
You have to change your settings on the graph to above that. I think the max is like 158mph.
Old May 24, 2005 | 05:38 AM
kaelaria's Avatar
kaelaria
I just picked up a unit and had this same question - unfortunately all the threads that look like they may have some meaningfull information are referenced in the old phpBB, and none of the links work. Luckily I found this one.
I'll post to this one when I get some more data.
Man this would be SO SWEET if it could log faster rates...too bad. It's still a really cool tool though!
Pker
Apr 11, 2017 12:14 AM
ShadyCoop
Sep 20, 2015 08:57 AM
gzaos
Sep 14, 2015 04:21 AM
potterstein
Sep 13, 2015 09:57 PM
potterstein
Sep 11, 2015 09:24 PM
