Drivetrain Official ALTA Q&A thread!
Old Nov 8, 2007 | 12:54 PM
  #1151
brownflyer's Avatar
brownflyer
Absolutely,
Feel free to call me at 707-330-5823 to discuss further.
Thanks,
Everardo Valadez
Old Nov 8, 2007 | 01:53 PM
  #1152
ALTAPerformance's Avatar
ALTAPerformance
Will do!
Old Nov 13, 2007 | 06:51 AM
  #1153
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
bump for djkajo
Old Nov 13, 2007 | 07:08 AM
  #1154
djkajo's Avatar
djkajo
Thanks...
Old Nov 15, 2007 | 01:11 PM
  #1155
SuperMINIs's Avatar
SuperMINIs
Just a basic question, and I am new to mods.
I like the better mileage of course, but I love the sound of the my Supercharger.
Probably better than the Turbo.
I was going to go for a 15% pully reduction only but am worried about the gas mileage hit. Will that happen? Will Engine or Supercharger longevity be affected as well? How much HP can I expect and will it be "seat of the pants" noticeable.
Old Nov 15, 2007 | 02:05 PM
  #1156
Dr Obnxs's Avatar
Dr Obnxs
The 15% pulley (no matter the vendor)
is the best single mod to your car! The gas mileage hit is purely dependant on your foot! You will put more turns on the SC, but the JCW SC is the same with a 14.something% pulley, and it's a so-called 100k mile part. HP gains are 15-20, and without a doubt you will be feel it for sure!
Matt
Old Nov 15, 2007 | 03:45 PM
  #1157
ALTAPerformance
Dr Obnoxs already summarized this pretty good BUT I would like to say the brand does matter in terms of long term belt wear, etc. From a performance standpoint, obviously anyone who makes it the correct size will = the same HP gains. I strongly suggest ALTA (but since you posted in our thread I think you have already made up your mind )
On the mpg comment. You will get nearly identical MPG if not a bit better, but based on your right foot and how judiciously you use it not the pulley itself. PLUS Jeff and I have been finalizing the ALTA P-n-P ECU for the R53 and working with changes in the cruise sections as well as the WOT maps.
Look for dyno plots here and other places on NAM in a few days.
If I can help further PLEASE let me know!
Adam@altaminiperformance.com
Old Nov 15, 2007 | 07:24 PM
  #1158
SuperMINIs's Avatar
SuperMINIs
Being new to modding, I am not sure what "ALTA P-n-P ECU for the R53 and working with changes in the cruise sections as well as the WOT maps" is all about. The ECUs have to be programmed by some shop? Or do they come pre-programmed requiring just a simple piggyback plug in and just go?
I have an R52 anyways. Not sure how that is affected.
Is the install easy enough for the pulley only kit and are all required parts included in the kit? And will I actually feel a big difference in off the line acceleration?
Old Nov 16, 2007 | 06:53 AM
  #1159
ALTAPerformance
Yes it is pre-programmed and simply plugs in using the instructions provided. The mapping is done by Jeff and Myself here in house. My point was we were making changes to the mapping to both improve HP and economy. Again sorry for the confusion.
Yes the pulley is a self contained installation. If you order directly from ALTA you can rent our pulley puller for free with just a small deposit for the tool. (Refunded when the puller is returned.)
If you have ANY questions or concerns, we highly encourage you to call us or e-mail. We always enjoy helping out a fellow enthusiast.
Thanks again!
Old Nov 17, 2007 | 04:50 PM
  #1160
auscoops's Avatar
auscoops
Hi
Does the new airfilter (R53) fit the JCW Airbox?
Cheers
Old Nov 17, 2007 | 04:52 PM
  #1161
auscoops's Avatar
auscoops
Hi
I'd be interested in this product.
My main question being can it be mapped for use of RON98 fuel... Over here in Australia RON98 fuel is as common as regualar... I'd like to take the advantage of using a higher octane fuel.
I'd say if there were options for the fuel type, you might hit a larger market - like europe, australia etc...
Keep up the development of new parts!
Cheers
Thanks again!
Old Nov 17, 2007 | 07:54 PM
  #1162
ADAMSALTAMINI
Originally Posted by auscoops
Hi
Cheers
Haven't tried it. But I have one out of my GP and I can certainly check. E-mail me for results on Monday!
Thanks for asking!
Old Nov 17, 2007 | 07:56 PM
  #1163
ADAMSALTAMINI
Hi
Cheers
CERTAINLY! We will keep doing more and more mapping in the coming months. I need to query Jeff on how the RON scale crosses over to the octane ratings here, but we can certainly do that. Certainly more aggressive timing can be used in that situation.
Thankfully, with the newest software we have for the UniChip even existing clients can now send their ECU's to us and we can update the firmware and put proper mapping on it to gain more HP etc.
Thanks again for asking!
Old Nov 17, 2007 | 08:06 PM
  #1164
scolburn79's Avatar
scolburn79
Hi
Cheers
I have the Unichip PnP for the R53 and I live in australia. The safest way is to just get it custom tuned to the car. I also have it turning my water/meth on to. If the unichip is the way you want to go but just get the maps they supply you might as well just get an MTH Tuner file because it is still only best guess.
Old Nov 18, 2007 | 05:46 PM
  #1165
ADAMSALTAMINI
The point is ALTA can get you tuned and properly for your application. Agreed there are some fine points to each motor, but that is when running at 9/10ths or 10/10ths which is always not recommended anyway. With our mapping a client could run at a very safe level with a ton of improvement. Then in the spring when we release the add on to the ALTA / UniChip Flux unit, you can add a wideband O2 sensor and fine tune the car on the road.
We do recommend using a Q or Q+ with extra drivers to operate our PERRIN PWI-1 if you can get it tuned as such. We will be offering this for local clients, then internet clients down the road.
Hope that helps clarify!
Let me know how Jeff or I can help further!
Old Nov 18, 2007 | 06:25 PM
  #1166
scolburn79's Avatar
scolburn79
Ok, You didn't really understand me and of course I didn't really explain it. As your climate over there is quite abit colder or just different, the way you tune your cars is different to the way we tune our cars. Tuning cars is tuning cars, i get that, it is all the same process. But you guys would have different atmospheric pressure to us, the climate is different, the petrol is different etc. So taking something that you guys have tuned for your minis and putting it on ours just won't work. When the guys saw the maps that my Unichip came with, they said that if I had of used them my car's dash would have lite up like a christmas tree and I may have very well got detination. They deleted all the maps out and started from scratch. Mine is driving a Water/Meth kit and it made 20whp, and it is the Q version, but I do have to take it back as it isn't finished properly yet. All I am saying is for people that live outside of the states, it is still just a best guess, A very good best guess mind you. I love your parts, I have heaps of them but wouldn't spend that amount of money just to wipe the maps out and start from scratch
Old Nov 19, 2007 | 01:34 PM
  #1167
ALTA2's Avatar
ALTA2
Manufacturer
Thanks for asking!
98 is like 93-ish octane.
I would agree that outside the US will be hard to do a whole lot for custom mapping. But Unichip has dealers all over the world, and qualified tuners all over the world that can take care of you. BUt the ALTA maps for the normal guy should still yeild more power. BUt as time passes, we would like to get some Aussies to test it out. It might take a couple times to get it just right, but i think we could build specific maps for certain areas of the world.
Old Nov 19, 2007 | 04:46 PM
  #1168
auscoops's Avatar
auscoops
Are you sure about the octane scaling? Because our 98 fuel over here is sold/marketed as 98 octane fuel?!
Old Nov 20, 2007 | 07:30 AM
  #1169
ALTAPerformance
Jeff will certainly chime in here. BUT the difference he is referencing involves how the numbers relate. So your 98 RON = our 93 here.
Sorry for the confusion!
Old Nov 27, 2007 | 07:27 PM
  #1170
Charles325i's Avatar
Charles325i
I recently bought the Alta OCC and about 3 days ago i found a huge amount of oil comming from my car. Took it to the dealership and they said that they hoses are becoming kinked when the hood is closed, i set it up the way you told me, and i now realize that many other people have had this issue. The dealership said i had oil commin out of the intake, and it was alot. So now i owe $200+ to the dealership for stock parts and labor. This doesnt sound like something i should be paying for, i am very disapointed and would like a refund for the OCC, what are my options?>
Old Nov 28, 2007 | 06:50 AM
  #1171
tavis1's Avatar
tavis1
What is a OCC?
Old Nov 28, 2007 | 08:02 AM
  #1172
efancher's Avatar
efancher
Oil Catch Can
Old Nov 28, 2007 | 09:28 AM
  #1173
ALTAPerformance
JEFF>>>>>>>>>Where did you go?!!!!!!
Ok he was working on the Turbo System for the R56 yesterday. Sorry for his delay.
Something must be a miss on the OCC, but Jeff can certainly explain better. As a side note I have our original OCC on my 02 MCS in the original configuration since 2003 and no issues no concerns. SO, must be something awry!
Thank you for your post and Jeff will be here ASAP!
Thanks again folks!
Old Nov 28, 2007 | 09:38 AM
  #1174
ALTA2's Avatar
ALTA2
Manufacturer
CAn you take a shot of the engine bay and email to us?
If installed correctly, the hoses shouldn't get pinched when the hood is shut. A picture would clear this up for us. Was your OCC full of anything?
Old Nov 28, 2007 | 11:18 AM
  #1175
Charles325i
sure, i believe i follow all directions correctly, if u want an email whats the address? - and the Lbracket is turned with the longer flat side up, with it the opposite way the Occ was resting on the body,
