Drivetrain Official ALTA Q&A thread!
Old Oct 15, 2007 | 06:51 AM
  #1101
ALTAPerformance's Avatar
ALTAPerformance
Good question:
Originally Posted by veggivet
Just finished the install of my adjustable lower control arms on my 02 MC and 02 MCS. They were installed as close to stock by eye. What setting would you recommend when I have them aligned? Neither car sees winter driving conditions The MC sees no track days and the MCS sees 4-6 track events a year, with less than 3k put on regular roads. The MC racks up about 5k a year. Thanks
For the track car, I would recommend closer to 1.75 or 2 deg negative camber to help with cornering. You may want to fiddle a bit with these numbers to maximize YOUR fun/performance.
For the street car .75 deg neg.
Thanks for the business and for asking!
adam@altaminiperformance.com
Old Oct 15, 2007 | 07:02 AM
  #1102
veggivet's Avatar
veggivet
Thanks. I also did the upper control arms on the track car. How would you set the caster, assuming I do 1.75 neg for the camber?
Old Oct 15, 2007 | 07:17 AM
  #1103
ALTAPerformance
I haven't personally fiddled with the caster/toe in the rear. Maybe ALTA2 (Jeff here in Tech) can provide more light:
Jeff you here yet?
Old Oct 15, 2007 | 01:11 PM
  #1104
HABUTGO's Avatar
HABUTGO
CAI silicone hose FITMENT
hello Alta,
Very Simple mod, but very mechanically challenged guy here need help
1) does some hose require trimming the bottom? (toward throttle body)
I already have ruined 1 Blue hose which I over trimmed, so i try with Red one this time to no avil I just gave up.
2) compare to throttle body opening, Silicone Hose has bigger opening (too lose) is this normal?
no matter how much i try to tighten it my silicone hose just slides right out, if I pull it with very little force.
3) and the tiny middle hose (fresh air... ??) does not line up with my factory hose. my factory line is running side ways and Silicone hose has its middle tiny hose facing up, toward the winshield. (I align my tube per your "Alta" logo to be on top not turn side ways)
I have seen most "Alta CAI how to's" here but I guess i am the only one having trouble installing my Hose. my 2nd attempt failed this weekend.
I have 05 MCS Manual, thank you.
PS: and How do I install that factory Air inlet plstic tube back on? (tube that feeds fresh air from front) Is it silicone hose install, before or after?? I got so frustrated I almost threw it all away~ arggggg :impatient whats a best way?
Last edited by HABUTGO; Oct 15, 2007 at 01:14 PM. Reason: my spell check wont work. sorri.
Old Oct 15, 2007 | 01:30 PM
  #1105
ALTAPerformance
HABUTGO: Sorry you are frustrated and having problems. As you have already seen by other members this is NOT a common problem. The inlet hose will be slightly larger than the stock one at the T/B. (We did this base don requests from clients with larger T/B kits. The extra is not a gross amount and the clamp provided (when tightened properly) will make the hose TIGHT! So simply recheck that.
On the fresh air tube coming from the radiator support. After tightening the inlet hose to the T/B and before it is tightened to the air box, pull the inlet tube forward (kinking it temporarily) and then slide the aformentioned hose into place. Much better than throwing it across the room!-)
Don't align the tube based on logo placement. The logos can be in different spots from part to part. (not an excuse just an explanation.) Best to make the PCV connection before installation of the fresh air tube.
As always let me know how I can help in anyway further! Thanks again for choosing ALTA!
Old Oct 16, 2007 | 09:21 AM
  #1106
HABUTGO's Avatar
HABUTGO
Thanks Adam,
Maybe I should go to Local Meet and ask for helping hand.
PS: Yes, I LOVE YOUR Product! please send gift
my 3"Alta Exhaust hanger got loose and fell off somewhere on the 405 FWY
Old Oct 16, 2007 | 09:56 AM
  #1107
ALTAPerformance
Anytime I can help I am happy to do it! Thanks again!
Adam@altaminiperformance.com
Old Oct 16, 2007 | 05:11 PM
  #1108
HighSchoolzMINI's Avatar
HighSchoolzMINI
how do I get the excess oil out of my catch can?
Old Oct 17, 2007 | 07:05 AM
  #1109
ALTAPerformance
Good question! Depends on where it is mounted. If you can access the site tube, simply drain the can into another container and place the waste with other waste oil.
If you can't do that, I recommend removing the top plate, and siphon out the waste oily stuff with an old turkey baster.
Also, the foam (if used) can generally be reused. Simply wash it with a degreaser and replace it in the can.
Hope that helps! Thanks for asking!
Old Oct 17, 2007 | 07:22 AM
  #1110
HighSchoolzMINI
exactly what i needed to know,
thanks a lot
Old Oct 19, 2007 | 04:02 AM
  #1111
veggivet's Avatar
veggivet
Any thoughts on the toe setting now that I have 4 adjustable control arms on the rear tires? I am planning to set camber to -1.75' on all the tires for my first track day tomorrow. How much positive caster would you suggest? Would you keep the toe at the factory recommendation? Thanks.
Old Oct 19, 2007 | 07:00 AM
  #1112
ALTAPerformance
My honest answer is I don't know. The caster (I believe) is far more crucial up front on the drive/turn tires hence the reason for our PSRS system. I can try to grab Jeff before he heads back to the dyno this morning to see if he has any answers for you.
Thanks for asking!
Old Oct 22, 2007 | 02:40 PM
  #1113
Charles325i's Avatar
Charles325i
hello alta, i recently bought the alta OCC and it came without the colored hoses, i contacted alta and told them, they asked for my invoice and i havent heard from them since, that was over a week ago, i can read that the hoses are apart of the kit and i dont know how to prove they didnt come with the kit, but they didnt :P plz where are my hoses?
Old Oct 22, 2007 | 08:21 PM
  #1114
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Well Charles are complete apologies for any inconvenience. BUT I will need more information. I will be in the office tomorrow. Direct any previous or new correspondence to me at adam@altaminiperformance.com Title the e-mail MISSING OCC HOSE and BE SURE to put your daytime telephone number, order number or ANYTHING else that could be helpful top finding the lost hose.
I just hate it when my hose goes missing!
Thanks again for your patience!
Old Oct 25, 2007 | 02:36 AM
  #1115
Charles325i
ok thanks, i got a email sayin they are on the way, also, i just won a poker game and thinkin about gettin the alta intercooler but want to know if there is a air diverter made for it or can i just cut the one for my stock intercooler to fit?
Old Oct 25, 2007 | 07:28 AM
  #1116
ALTAPerformance
Thanks for asking. The ALTA Intercooler comes with its own diverter as part of the package. Sorry for any confusion! Thanks again for your business!
Old Oct 25, 2007 | 08:07 AM
  #1117
Minifiend's Avatar
Minifiend
Any news on the Hydra EMS project?
Thanks!
Old Oct 25, 2007 | 08:52 AM
  #1118
JIMINNI's Avatar
JIMINNI
Since this thread is bumped again, any news on CARB stickers for CAI? Just asking .
Old Oct 25, 2007 | 05:31 PM
  #1119
HighSchoolzMINI
does the alta intercooler come with a different hood scoop?
Old Oct 25, 2007 | 05:43 PM
  #1120
ALTAPerformance
Thanks!
Yes and No. It is available only for clients with TWURBO sytems. I do still have a few kits available.
But we have a NEW Ecu product the ALTA PnP ECU for the R53 that will be released in the coming days. For a sneak peek at what we did for the R56 owners click here!
Thanks again for asking!
  #1121
ALTAPerformance
NOPE! But we do have a new way to skin the cat with more parts combined under one EO. Sorry for the extended delays.
Old Oct 25, 2007 | 05:44 PM
  #1122
ALTAPerformance
Nope! But works with most of the popular ones available from other vendors and mfrs here on NAM! Thanks again for asking!
Old Oct 25, 2007 | 05:45 PM
  #1123
JIMINNI's Avatar
JIMINNI
Is that info. on your website?
Old Oct 25, 2007 | 06:10 PM
  #1124
HighSchoolzMINI
is the stock scoop sufficient enough?
Old Oct 25, 2007 | 06:15 PM
  #1125
ALTAPerformance
Oh yes! Absolutely!
