Drivetrain How can I stop my exhaust from "farting" ?
Let me make my first statements with, I absolutely love my 05 Mini! It's nearly the best car I've ever owned.
But with any car there are it's flaws for each person. The most recent annoyance is the <pop, pop, pop> of my exhaust when i let out of the gas above 3000 rpm. That little backfire is almost embarrasing when cruising through a parking garage and hearing the echo.
I'm 29 yrs old and missed the whole loud-exhaust-on-4-cylinder-car phase although love a loud exhaust on V8's and a few V6's if done right.
Is there an exhaust product that is QUIETER on the market? Just in terms of the backfire, not the sound itself. It seems to be more noticeable when the engine is cold for some reason, it's more like marbles in a tin can, then warms up to sound a little different... muffled marbles in a tin can.
Any constructive feedback?
Well just realize that the sound was designed that way. It's a British MINI thing that they wanted to keep and for most people it's distinctiveness is nice. It isn't the same type of sound that the ricey mufflers make.
That said, it's understandable that you want a replacement for it since you don't like the sound. And I think there are quite a few muffler systems that our vendors sell that will meet your requirements. Hit up Randy at Webb Motor Sports or Ryan at Detroit Tuning for more specific advice.
Best of luck
Best of luck
Originally Posted by paul_
WHAT!?!?!?!?
The exhaust sound is one of the best parts of the MINI, IMHO. You definitely missed something.
Odds are can get an '04 or earlier exhaust for free or really cheap and just swap them out. If you were on my coast I'd swap out in a minute!
what's the actual difference in the 2 exhaust systems. I like the sound except for the "backwash". :smile:
I'll have to listen to an 02-04 model exhaust and see what the difference is. Maybe a swap isn't a bad idea.
I think exhaust "farts" are good for your MINI.
Burbling and exhaust pops are a good thing and while minimal (nonexistant) in most cars and in the older 02'-03' MINIs, it is present in the newest MINIs.
I don't think there is much difference in the exhaust itself.
I guess you could design a "fart" silencer tip for your exhaust. Porcelain finish would be nice.
It would match white wheels, roof, and mirrors.
the exhaust has almost nothing to do with the burble, its designed in the computer to do that. I am 99% sure of this, here is how I tested it several times.
Coming down a long grade ( not steep but a grade ) I let off the throttle to let it burble, it burbles for a couple seconds and stops, tap the gas and it will burble for the exact same amount of time and stop. Also if you tap the brakes while its burbling it will stop. Definatly in the software.
If you change exhaust it will only get louder or more pronounced. I love the way my car burbles :-)
Originally Posted by camelpilot
You cant be serious.
Originally Posted by Greatbear
With a Milltek exhaust the burbling takes on a nice, low rumble, compared to the stock system. I love the sound!
Another burble lover here...
:smile: I LOVE the way it sounds....
Donna
02' CR/W MCS (gone to MINI heaven - burned up)
05' Cool Blue MCSC "Ariel"
05' HB/W MCS on it's way - no name yet
Donna
Both of my 03's had the burble with stock exhaust. It is a little quieter and has a lower tone compared to the 05's. The 05's seem to be higher pitched.
Considering how long the revs "hang" when you let up on the throttle, I wouldn't be suprised if the burble is part of the programming.
And it does sound alot beter with the milltek
Originally Posted by steebo777
Actually he is very serious and nearly correct. It is designed into the engine not software to do this. IIRC, it is dure to the A/F mixture that creates this effect.
If I turn on the A/C, yes, the A/C, my burbles stop, and I have an aftermarket exhaust (i love the loud burbles).
Plus I believe the burbles stop when you let off the gas after a few seconds because when the engine is well over 2k RPM's the computer stops feeding the engine fuel. That's why if you coast down or brake slowly down until around 1800 RPM's, the exhaust sounds very different all of a sudden (it's combusting again!). I'm sure someone can clarify this further.
