Drivetrain Ignition Wire touching Intercooler back
Old Mar 20, 2005 | 02:16 PM
kyriian's Avatar
kyriian
I was wondering if it should be a concern...
my new livewire ignition wires have started to burn a very small hole.. the outer coating is a nylon coat... and it is burning into the inside when it touches the intercooler.. the GRS intercooler is alot bigger and its my main concern is that it will burn through whatever's inside..
any recommendations? the giant intercooler im not removing...
Old Mar 20, 2005 | 02:24 PM
kyriian's Avatar
kyriian
let me try and rephrase this...
the new GRS intercooler reaches behind slightly of the ignition wires... but since it's thicker... it also touches the nylon outer coat of my new livewire spark plug wires... after about a month, the intercooler's heat seems to have burnt into the inside of the spark plug wires... i cannot see any visible damage... but any damange is not good
i was thinking of spacing it... maybe put in a small silicone tube that will be placed on the wire so it will be properly spaced...
anyone have any suggestions?
Old Mar 20, 2005 | 03:22 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I doubt the heat of the intercooler has damaged your wires (it doesn't get hot enough). More likely, the intercooler is rubbing against the wires and has worn through the covering. You may want to zip tie your wires away from the IC (or swap back to the stock wires).
Old Mar 20, 2005 | 07:44 PM
onasled's Avatar
onasled
If you look closely you may see that it's not a burn, but is oxidation from the wires rubbing on the aluminum IC.
I am guessing that the problem here is that you did not route your wires correctly through the top of the 'Beru' connectors. Are they just coming straight up out of the (spark plug) connector, or are they coming out at the 90 degree angle that they are supposed to be. That connector has a slit in the top with an exit hole to make that 90 degree exit.
PS, should have asked what wires you are using. Maybe the brand you have do not offer that 90 degree outlet. ?
Old Mar 20, 2005 | 08:59 PM
kyriian's Avatar
kyriian
i figured it as much when i looked at the oem wires! stupid me! i looked at them and was fiddling around at 11:30 at night... figured it all out!
thanks for the help.. they are livewire wires...
surfblue
Oct 24, 2018 01:20 AM
blackie
Oct 2, 2015 07:41 PM
Getrieben
Aug 15, 2015 09:09 PM
Lt. Dan
Aug 10, 2015 08:23 AM
