Drivetrain Aluminum valve cover mods
Old Nov 24, 2025 | 05:54 PM
MCSHATCH's Avatar
MCSHATCH
Hey I just wanted to share my mods I did to a cheapo aluminum valve cover. I’m doing this to replace a cheap plastic oe style replacement cover that had failed after around 2 years. I don’t like or want another plastic cover. I added two -10 a fittings and welded a patch over a rectangular hole that was in the center of the cover. The original aluminum cover had a stock style pcv system made of plastic with all the bits than can fail and all. I kept the little umbrella valve under the right bung and the left one is just open come to think of it I should add a baffle under it… anyways I’ll be plumbing the two fittings to a catch can I’ll be making later. The guys at the parts shop said the red wrinkle paint will add like 25hp so that’s pretty sweet 😤. Anyways I’ll check back in later to let you know if it’s working alright or if oil starts pouring out of all seals.
Attached Thumbnails Aluminum valve cover mods-img_5376.jpeg   Aluminum valve cover mods-img_5371.jpeg
Old Nov 25, 2025 | 10:49 AM
Coz3z3's Avatar
Coz3z3
I am curious how this will work for you.
I purchased the aluminum one from Speedtech and they eliminate the PCV altogether. I ran AN lines to the catch can and it filled it with oil very fast. Like a mile or 2, fast. So I'm in the process of adding an external PCV system before putting it back on. So, curious how yours will be
NoBrand
Jul 18, 2023 08:53 AM
ghaut
May 23, 2022 01:26 PM
Scooter24
Jun 19, 2018 02:08 PM
bigbacon
Jan 18, 2015 10:33 AM
RandyH
Feb 5, 2012 03:32 PM
